Sandbird
[solved] Controlling a fan on a relay with python
Mon Jun 01, 2015 4:34 pm
I have a Raspberry pi Model B revision 2 and I've set up a mini 5v fan on a relay switch which i want to control with python now. I will be running a crontab every hour to check the temperature of the pi and if the temperature is above 50C i will be running the fan for like 10 min.
This is my current setup:
The relay is connected like this diagram here:
I've setup the relay this way, because it has a light on top of it (a red light) which i want it to be on when the fan is working...and off when its not.
Here is my script:
#!/usr/bin/python3
import time
import os
import sys
import RPi.GPIO as GPIO
# Identify which pin controls the relay
FAN_PIN = 3
# Temperature check. Start fan after 50C, Shut down under 50C
FAN_START = 50
def GPIOsetup():
	GPIO.setmode(GPIO.BCM)
	GPIO.setup(FAN_PIN, GPIO.OUT)
	GPIO.setwarnings(False)
def getCPUtemperature():
	res = os.popen('vcgencmd measure_temp').readline()
	return(res.replace("temp=","").replace("'C\n",""))
def fanON():
	GPIO.output(FAN_PIN, 0)
	print "fan on"
	return()
def fanOFF():
	GPIO.output(FAN_PIN, 1)
	print "fan off"
	return()
def getTEMP():
	CPU_temp = float(getCPUtemperature())
	if CPU_temp>FAN_START:
		fanON()
	else:
		fanOFF()
	return()
def main():
	GPIOsetup()
	getTEMP()
try:
	main()
finally:
	print ("Finish")
	#GPIO.cleanup()
Now the problem is that i am getting some warnings which i just cant get rid off:
root@raspberrypi:/home/pi# python fan.py
fan.py:14: RuntimeWarning: This channel is already in use, continuing anyway.  Use GPIO.setwarnings(False) to disable warnings.
fan.py:14: RuntimeWarning: A physical pull up resistor is fitted on this channel!
fan off
Finish
The line in question as you can see is this:
Why am I getting this error ? i have GPIO.setwarnings(False) in my code.
And also should i be using that pin for controlling the relay ? Is there optional pin i should be using ?
danjperron
Re: Controlling a fan on a relay with python
Mon Jun 01, 2015 4:42 pm
In GPIOsetup() the first command should be
You remove the warning after you set the GPIO and this is why you have them.
Sandbird
Mon Jun 01, 2015 4:44 pm
danjperron wrote:In GPIOsetup() the first command should be
hi, thanks for answering. I did what you said but half the warning is still there. Now i only get:
fan.py:15: RuntimeWarning: A physical pull up resistor is fitted on this channel!
fan off
Finish
Should i just try another pin for controlling the relay ? If so, any suggestions ? Obviously i cant use pin gpio3 so i wondering if i should avoid any other.
Sandbird
Mon Jun 01, 2015 5:31 pm
yup changing Pins fixed the errors. I am now using pin12 (GPIO018) and no more errors appear.
Here is the final script if anyone wants it.
Crontab check temperature every 1h5m. If temp > 50 then turn the fan on for 10 min.
5 * * * * sudo python /home/pi/fan.py
fan.py
#!/usr/bin/python3
import time
import os
import sys
# Identify which pin controls transistor
FAN_PIN = 18 # the yellow box ex: GPIO18
FAN_START = 50
def GPIOsetup():
def fanON():
	#print "fan on"
	return()
def fanOFF():
	#print "fan off"
	return()
def getTEMP():
		fanON()
		count = 1
		while count <= 10:
			count = count + 1
			time.sleep(60) # Run the fan for 10min
	else:
		fanOFF()
	return()
def main():
	GPIOsetup()
	getTEMP()
	fanOFF()
try:
	main()
finally:
	#print ("Finish")
	GPIO.cleanup()
New configuration:
danjperron
Re: [solved] Controlling a fan on a relay with python
Tue Jun 02, 2015 6:45 pm
Pin 3 and 5 have a pull up resistor for the I2C. This is why you have that warning.
Anyway it is better that you let the I2C free for other project ;-)
Your schematic is confusing. I know that you are using a relay with an active driver but you choose a simple relay layout. Next times put a box around it and just specify the VCC, GND and IN.
Daniel
Sandbird
Tue Jun 02, 2015 6:46 pm
yeah i used another gpio and its working fine now.
I am still a noob with all this...next project will be better detailed :)
TxRider
Thu Nov 15, 2018 7:18 am
Will the fan relay be controlled by the CPU temp, if not how could I make it read off of my CPU temp?
Thank you,
Ken
Sandbird
Thu Nov 15, 2018 10:09 am
Here you go: https://www.instructables.com/id/Automa ... an-for-Pi/
Temp functions are inside the script
raymate
Mon Jan 21, 2019 12:22 am
Want to build something like this but want to use an external temp sensor such as the DHT11, any tutorial you can recommend.
So using a replay to control external fan with external temp sensor
___________________________________________________________________
Pi model B / Pi 2 / Pi 3 / Pi 4 / Pi 400 / Pi Zero W / Pi Zero 2 W / Pico
Sandbird
Mon Jan 21, 2019 12:32 am
I know its doable with arduino, (even the arduino pro micro, you don't have to go big with the bulky arduino uno). Like this video here: https://www.youtube.com/watch?v=xD8wHXDzLkQ
Just ignore anything related to the TM1637 display, and you get exactly what you want...something to turn on a device (using a relay) over a fixed temperature and turn it off below that.
raymate
Mon Jan 21, 2019 1:07 am
Thanks for the reply, but I use Pi I dont want to start buying more controller boards, its just another thing to lean :)
Sandbird
Mon Jan 21, 2019 1:17 am
I just found this library here for the pi: https://tutorials-raspberrypi.com/raspb ... t11-dht22/
This should work just fine, with my script.
Looking at the example script here: https://github.com/adafruit/Adafruit_Py ... pletest.py
all you have to do is import the library, set up a pin number and use : humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
to get the temperature value...then use that value to return it in my function (instead of return(res.replace("temp=","").replace("'C\n","")))
You might need to play with that return value a bit, maybe it's not formatted properly (int, float etc) but i dont see why it shouldnt work.
raymate
Mon Jan 21, 2019 1:20 am
Nice, that looks a bit more like what I can start with, cheers
Sandbird
Mon Jan 21, 2019 1:27 am
Glad i could help :)
btw, you should really check the Arduino pro micro as well and/or WeMos D1 mini ESP8266. Just using the esp8266, a DHT22 and a usb cable i am sending values to thingspeak and have my own mini weather station (http://sandpi.tk), all that from a device the size of your thumb :P
Return to “Python”
