novice81
alter the shutdown and reboot sequence to shutdown the lcd
Mon Feb 05, 2018 8:44 pm
ve been trying to find a way to make it so when we reboot and/or shutdown (using a command not a button) the raspberry pi the lcd goes off with it instead of turning off when i pull the power
pcmanbob
Re: alter the shutdown and reboot sequence to shutdown the lcd
Tue Feb 06, 2018 10:23 am
Hi.
Which LCD are you talking about ? 7" LCD screen ,16x2 LCD some small LCD connected to the gpio.
Which ever it may be they will all receive power from the pi or its PSU shutting down the pi does not turn off the power ( like it does in a desktop pc )
to remove the power you have to disconnect the pi from the PSU either by unplugging it or via a switch in the PSU cable.
novice81
Wed Feb 07, 2018 6:26 pm
the 16x2 lcd. so your saying theres no way i can put some code sequence to make the screen shutoff when i tell it to shutdown or reboot
and then tun back on when i plug it in
pcmanbob
Wed Feb 07, 2018 8:55 pm
You could turn off the back light on your 16x2 LCD but that's all, because as I said it's still powered from the pi until the power is removed from the pi. The pi does not turn off or disconnect from the power it's self you have to do it externally by pulling the power cord out or fitting a switch in the power cord.
rados-dataplicity
Fri Feb 09, 2018 4:56 pm
If you can control your LCD programatically then you could add a script to turn it off from within systemd. If you'd put the script in the location below:
/lib/systemd/system-shutdown/
Then systemd would turn it off at the very end of the shutdown sequence. ;)
I tinker around with Raspberry Pis daily and make sure that people can easily access theirs remotely.
Community outreach @ dataplicity.com
novice81
Mon Feb 12, 2018 6:10 pm
thank you, would the /lib/ command work to access the reboot area too?
rados-dataplicity
Tue Feb 13, 2018 11:16 am
Yes it would
Return to “Python”
