davef
Running Python script from crontab doesn't display
Sat Apr 18, 2020 8:01 pm
Re-writing some Bash scripts in Python, the following Bash script:
echo "test" >> /dev/tty1
displays on the console when run manually in /home AND when the Bash
script is called by sudo crontab.
However, if I use this Python script:
#!/usr/bin/python3
import sys
sys.stdout.write("test")
sys.stdout.flush()
it displays "test" when run from /home BUT not when the Python script
I have tried user crontab and it still doesn't work. There seems to be
something different when running a Python script from crontab.
Appreciate any clues.
pcmanbob
Re: Running Python script from crontab doesn't display
Sat Apr 18, 2020 8:09 pm
Anything run by Cron is run in the background, so no screen output.
Your first shell command works because you are directing the output to the screen.
So to make you python program display on the screen you need to do the same.
For example
@reboot python3 /home/pi/my program.py >> /dev/tty1
davef
Sun Apr 19, 2020 12:18 am
That did it, thanks.
pcmanbob
Sun Apr 19, 2020 10:38 am
Really if you want to run you python program with output to the display you should be using the GUI auto start file
/etc/xdg/lxsession/LXDE-pi/autostart
So you would access if from the command line like this
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
and add you start line for your python program like this
@python3 /home/pi/your_script.py
thagrol
Sun Apr 19, 2020 11:31 am
Doesn't that only apply if you're both using the GUI and logged in? And won't it start a new copy of the program whenever anyone logs in whether on the console or via vnc?
pcmanbob
Sun Apr 19, 2020 11:51 am
Yes to the first question .
probably yes to the first part of question two , don't know about VNC not tried it.
Return to “Python”
