bensonsearch
bluetooth import
Thu May 30, 2013 1:28 am
Hi All,
im super new to python and my little raspberry pi (i normally use vb.net so not new to programming as a whole).
I have installed a usb bluetooth dongle and it all works fine from the command line as it should and it installed bluez as well.
in python i have
import bluetooth
and also tried
from bluetooth import *
both error saying
File "/home/pi/test.py", line 1, in <module>
ImportError: No module named bluetooth
please help
bushrat
Re: bluetooth import
Thu May 30, 2013 2:05 am
How did you install BlueZ? Like this:
sudo apt-get install bluetooth
If so, and I know it's a real cliche by now, try turning your Pi off and on again, you never know :)
bensonsearch
Thu May 30, 2013 2:17 am
Thank you so much for the reply.
It installed as part of the adaptor install, I know this as I tried
sudo apt-get install bluez
and it returned saying already installed
however i fixed the error since by
sudo apt-get install python-bluez
fixed the issue :)
thanx again so much
Return to “Python”
