gjs
Detect if running on RPi
Sun Sep 01, 2013 1:56 am
From my python program, how can I determine if the program is running on a Raspberry Pi instead of, for example, a Beaglebone?
tonyhughes
Re: Detect if running on RPi
Sun Sep 01, 2013 2:00 am
I check the output of:
$ uname -m
to at least confirm the processor version. Not a definite that it's a Pi, but certainly excludes most non-Pi hardware.
Sun Sep 01, 2013 3:11 am
You could check the contents of /proc/cpuinfo. There's a few values in there that would probably identify a Pi. I can't check right now, as my Pi is switched off and I don't have a Beglebone to compare it with.
DeeJay
Sun Sep 01, 2013 8:34 am
If it is an RPi with a built-in ethernet port (ie. won't work with a Model A with no LAN port) then the eth0 HWaddr field returned by ifconfig will probably start with b8:27:eb:xx:xx:xx if it is a device produced by the Raspberry Pi Foundation.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
Joe Schmoe
Sun Sep 01, 2013 8:43 am
As with most such things, it depends on how rigorous and/or future-proof you need to be, but, for now anyway, it looks like:
grep Hardware /proc/cpuinfo
is pretty good. On the Pi, this gives:
Hardware : BCM2708
Needless to say, on non-Broadcom-based-boards, this will give something utterly different.
gjs
Sun Sep 01, 2013 9:24 am
Thanks for your replies.
The uname command is probably the least definate as it returns unknown for the processor and hardware-platform items. Using the MAC address won't work on a model A, as stated. Grepping cpuinfo seems the best option as it returns the SOC name.
However, all of these rely on OS commands which, presumably, means they are OS dependent. Is there a Python command or technique that can be used regardless of the presence of a particular OS utility?
davef21370
Sun Sep 01, 2013 9:34 am
gjs wrote:However, all of these rely on OS commands which, presumably, means they are OS dependent. Is there a Python command or technique that can be used regardless of the presence of a particular OS utility?
You could use sys.platform to find out which OS you're running on then use the relevant command for a particular system.
Dave.
Apple say... Monkey do !!
AndrewS
Mon Sep 02, 2013 4:01 pm
Simply open /proc/cpuinfo directly in Python, read it a line at a time, and do the "grepping" yourself with http://docs.python.org/2/library/stdtyp ... startswith
gjs
Tue Sep 03, 2013 12:57 pm
Do all Linux distributions have /proc/cpuinfo ?
AndrewS
Tue Sep 03, 2013 1:51 pm
gjs wrote:Do all Linux distributions have /proc/cpuinfo ?
Yup, /proc (and /sys) is a "virtual filesystem" which doesn't actually exist on disk (even though to all intents and purposes they look like regular files), but which gets created dynamically by the Linux kernel.
gjs
Tue Sep 03, 2013 4:05 pm
Great, thanks.
paddyg
Tue Sep 03, 2013 6:07 pm
don't hack it, use platform as @davef says. It's platform independent python.
in pi3d we decided it was actually more relevant to know what shared libraries were available rather than the actual machine or operating system. We do this with ctypes.util.find_library() which seems to work well.
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
AndrewS
Tue Sep 03, 2013 6:23 pm
paddyg wrote:don't hack it, use platform as @davef says. It's platform independent python.
Yeah, I guess the pertinent question for the OP would be why does he need to know whether or not he's running on a Pi, when Python makes writing portable cross-platform code really easy :)
Tom Swirly
Sun Mar 16, 2014 8:36 pm
Coming into this late...
`platform` is definitely not good enough if you're writing real cross-platform code.
The example that led me to this discussion was wanting to know if I could use RPi.GPIO - but the best that you can get from `platform` is:
IS_DEBIAN = platform.linux_distribution()[0].lower() == 'debian'
- which allows you to tell if the platform is Debian but not specifically if it's an RPi.
Of course, you could just try to import RPi.GPIO and report the failure if it didn't work, but I want my error messages to clearly distinguish between "not an RPi" and "is an RPi but your distribution doesn't have RPi.GPIO".
If you want to see what I did for this in echomesh, the code is here (and is open source if you want to take it...) - and I basically do the /proc/cpuinfo grep as suggested above.
Return to “Python”
