HermannSW
C/C++/... TOhtml (vim)
Thu Aug 12, 2021 6:32 pm
At end of this posting I mentioned that I use "vi" editor since 1990:
viewtopic.php?f=33&t=317340&p=1901106#p1901106
And that "vi" is "vim" (vi improved) these days.
And that "vim" on Raspberry has 600(!) syntax files:
pi@raspberrypi400:~ $ ls -l /usr/share/vim/vim81/syntax/*.vim| wc --lines
600
pi@raspberrypi400:~ $ ls -l /usr/share/vim/vim81/syntax/ | grep cpp
-rw-r--r-- 1 root root   2869 Jun 15  2019 cpp.vim
-rw-r--r-- 1 root root    600 Jun 15  2019 objcpp.vim
pi@raspberrypi400:~ $ ls -l /usr/share/vim/vim81/syntax/?.vim
-rw-r--r-- 1 root root  4902 Jun 15  2019 /usr/share/vim/vim81/syntax/b.vim
-rw-r--r-- 1 root root 26451 Jun 15  2019 /usr/share/vim/vim81/syntax/c.vim
-rw-r--r-- 1 root root 28631 Jun 15  2019 /usr/share/vim/vim81/syntax/d.vim
-rw-r--r-- 1 root root  9375 Jun 15  2019 /usr/share/vim/vim81/syntax/j.vim
-rw-r--r-- 1 root root 14730 Jun 15  2019 /usr/share/vim/vim81/syntax/r.vim
I remembered that "vim" (after "sudo upt install vim") allows to export HTML files with syntax highlighting.
And I found an old bash script that makes using that very easy:
pi@raspberrypi400:~ $ cat .local/bin/TOhtml
#!/bin/bash
vim $1 +TOhtml +w +q +q
sed 's@\(<font face="monospace">\)@\1<table border="1" bgcolor="#000000"    '\
'style="color:#ffffff"><tr><td>@;s@\(</font></body>\)@</td></tr></table>\1@' \
$1.html -i
This tool can be appliad to itself:
pi@raspberrypi400:~ $ TOhtml .local/bin/TOhtml
The generated HTML file looks like this in browser:
This is application for simple C file, as said 600 syntaxes are known:
pi@raspberrypi400:~ $ TOhtml cgt.c
Browser screenshot:
GlowInTheDark
Re: C/C++/... TOhtml (vim)
Thu Aug 12, 2021 10:32 pm
I used to use this a lot back in the day to make pretty (colorful) printouts of my source code. I would use the 2html script to produced HTML, then use a browser to print that.
Nowadays, I use the :hardcopy command, which produces a pretty (colorful) PostScript file of your source code. It seems a little easier to use than 2html, but I assume the underlying engine is much the same.
Actually, I then use ps2pdf to produce a PDF as the final output of the process.
Poster of inconvenient truths.
Back from a short, unplanned vacation. Did you miss me?
HermannSW
Fri Aug 13, 2021 12:05 am
Interesting, I have not found "2html", but found and installed "c2html".
Output looks similar, but manpage states that only 4 languages are supported (C, Java, Pascal, perl).
TOhtml makes use of the 600 syntax files of vim and allows to syntax highlight nearly everything.
One of those syntax files is for Linux arbitrary precision calculator "bc", here syntax highlighted with TOhtml:
Regarding my previous posting, the sed command did not match modern TOhtml output anymore.
I fixed that, it basically creates black background, inside a table with border=1:
#!/bin/bash
sed "s/^\(pre.*\)color: #000000.*/\1color: #ffffff; background-color: #000000; }/;"\
"s/^<body>/<body><table border=1><tr><td>/;"\
"s/^<\/body>/<\/td><\/tr><\/table><\/body>/"\
 $1.html -i
The same cgt.c output from previous posting looks like this:
(you have to decide whether you prefer unchanged TOhtml output shown in previous posting or this version)
I used those black background TOhtml outputs in my 268 IBM developerWorks blog postings.
They are gone since IBM deleted all developerWorks blogs and forums end of 2019.
Here is one posting I republished, with two examples of TOhtml with black background output:
https://stamm-wilbrandt.de/en/blog/Gate ... 20AES.html
They are HTML (different to the screenshots I did post here), so you can copy&past parts from them.
HermannSW
Fri Aug 13, 2021 7:52 am
The colors are not as I want them for dark background.
I investigated, and without specifying whether background is dark or bright, vim guesses based on terminal settings.
I eliminated the guessing by providing two TOhtml versions, explicitely setting (vim) background and then doing the right stuff.
This is with bright background:
https://gist.github.com/Hermann-SW/3609 ... 18de5ee6c8
pi@raspberrypi400:~ $ cat ~/.local/bin/TOhtml_
#!/bin/bash
vim -c "set background=bright" $1 +TOhtml +w +q +q
sed "s/^<body>/<body><table border=1><tr><td>/;"\
 $1.html -i
And this is with dark background (my favorite), with colors for dark background:
https://gist.github.com/Hermann-SW/02d4 ... f47fa2f81d
#!/bin/bash
vim -c "set background=dark" $1 +TOhtml +w +q +q
sed "s/^\(body.*\)color: #ffffff.*/\1color: #000000; background-color: #ffffff; }/;"\
 $1.html -i
Return to “C/C++”
