Nolaan
OpenCV 2.4.9 compiled libraries for Raspberry Pi (RPi)
Thu Jul 10, 2014 6:48 pm
[EDIT]
Hi, for the one time posters just download and unzip the latest released file https://github.com/Nolaan/libopencv_24/releases then install it.
[/EDIT]
Here are the compiled opencv 2.4.9 libraries for the raspberry pi.
Download and put them in your /usr/local/lib directory. No need to compile. Hope it will remove some pain and save time for some, and speed up development time.
There also is a face recognition (not detection) test app for RPi and Desktop.
Enjoy!
http://www.jetsonblog.com
twitter : @nolaan_boy
darkkillerme
Re: OpenCV 2.4.9 compiled libraries for Raspberry Pi (RPi)
Wed Jul 16, 2014 4:13 am
I just have to put them in /usr/local/lib and I can use opencv in raspberry? This is awesome... I just having trouble with installing opencv. Thank a lot. You saved my work. :D
darkkillerme
Wed Jul 16, 2014 10:25 am
May I know how raspberry pi detect installed opencv? thanks.
mugiwara
Fri Aug 08, 2014 8:12 am
Really works great (need more 2 extra libs openexr and ffmpeg in my case).
chenxilinsidney
Fri Aug 15, 2014 1:19 pm
that's nice ,I think i would use it to save compile time,thank you~
dr_ill
Sat Aug 23, 2014 11:12 pm
How do you use your app example? Sorry I am new to this.
Nolaan
Mon Sep 01, 2014 4:36 pm
The apps are just a demo of what you can achieve with the OpenCV libs.
Everything is in the README
Take the demo_app dir put it somewhere on your Rpi and then browse it and launch either : qt-facetrainer-cam or qt-facetrainer-video.
You can also do the same on your computer with qt-facetrainer-x64 ( eg : you must have a 64 bits OS)
@darkkillerme : Just run on RPi => "sudo ldconfig" , you can find more information in the README files
Div
Tue Sep 09, 2014 2:54 pm
I've followed all the steps you posted here yet I don't seem able to make use of these libraries from python.
I'm trying to get this project working: http://makezine.com/projects/pi-face-treasure-box/
Source code is here: https://github.com/tdicola/pi-facerec-box/
In python the following commands:
import cv2
model = cv2.createEigenFaceRecognizer()
results in
attributeError 'module' object has no attribute ‘createeigenfacerecognizer’
Am I missing a step here? Has anyone else got this working from python?
Nolaan
Mon Oct 27, 2014 8:50 pm
Div wrote:I've followed all the steps you posted here yet I don't seem able to make use of these libraries from python.
import cv2
results in
This is normal because python use a totally different library. They compile it themselves ie /usr/lib64/python2.7/site-packages/cv2.so
Nolaan
Mon Oct 27, 2014 8:51 pm
Today I made the 2.4.10 version available, clone it from here : https://github.com/Nolaan/libopencv_24
Instructions are still the same.
janszymanski
Fri Oct 31, 2014 10:35 am
I'm thinking of installing openCV your way, but before doing so, can you tell is /usr/local/include/opencv needed
and if yes, how it will be created?
Jan
Nolaan
Fri Oct 31, 2014 9:19 pm
Hey,
The include directory is only needed for compilation. So no you won't need it. I will soon release .deb and .rpm to ease the process.
iman
Fri Oct 31, 2014 9:34 pm
Thanks a lot. It took me a full day to download and compile openCV my self and at the end, It didn't work.
You saved my project :D
Nolaan
Sat Nov 01, 2014 1:25 pm
iman wrote:Thanks a lot. It took me a full day to download and compile openCV my self and at the end, It didn't work.
Glad to read that, you made my day ;) :)
Nolaan
Sat Nov 01, 2014 5:34 pm
Okay everybody,
Now, you can just install the .deb file, that's all here it is : https://github.com/Nolaan/libopencv_24/ ... nCV_2.4.10
NOTE : it's a zip file so you have first to unzip it, then just dpkg -i libopencv_2.4.10.deb
Good day ;)
Sun Nov 02, 2014 7:36 pm
Hi Nolaan,
Is it possible to get SURF added to your OpenCV2 stuff?
Nolaan
Mon Nov 03, 2014 1:36 pm
DougieLawson wrote:Hi Nolaan,
Hi DougieLawson,
I didn't check the compilation option (just built the default without CUDA), but I'm seeing a lot of *SURF* symbols in the libs via objdump. I'll try to recompile it soon.
roman80
Wed Nov 05, 2014 6:18 am
Nolaan wrote:Today I made the 2.4.10 version available, clone it from here : https://github.com/Nolaan/libopencv_24
Nolaan, thank you very much!
You saved me a lot of time. So, can You also publish header files from /usr/include to use with c/c++?
I think those that are placing in source file not suitable for use.
roman80
Fri Nov 07, 2014 3:54 pm
When I did instruction in readme.txt and rund sudo ldconfig, it said:
ldconfig: /usr/local/lib/libopencv_videostab.so.2.4 is not a symbolic link
ldconfig: /usr/local/lib/libopencv_ocl.so.2.4 is not a symbolic link
ldconfig: /usr/local/lib/libopencv_nonfree.so.2.4 is not a symbolic link
ldconfig: /usr/local/lib/libopencv_gpu.so.2.4 is not a symbolic link
ldconfig: /usr/local/lib/libopencv_stitching.so.2.4 is not a symbolic link
etc...
What I do wrong?
Nolaan
Fri Nov 07, 2014 8:25 pm
It's not really a problem, much of a warning. It lets you know that those file should be symbolic links.
I assume you just `cp' the files. Try `cp -P' next time.
arduinopi+
Mon Nov 17, 2014 1:56 pm
hey guys,
i did download all the dependency files using wget and moved them to /usr/local/lib/opencv, then as instructed i created opncv.conf and stored /usr/local/lib/opencv in it, but when i run ldconfig , it gives an error stating that the library files such ad calib3d etc are not valid elf file-it has the wrong bytes at the start
thanking you
Nolaan
Mon Nov 17, 2014 2:04 pm
Undo all your operations and install the .deb package : https://github.com/Nolaan/libopencv_24/ ... 10.deb.zip
Unzip it first! Then,
arduinopi+
Mon Nov 17, 2014 2:35 pm
Nolaan wrote:Undo all your operations and install the .deb package : https://github.com/Nolaan/libopencv_24/ ... 10.deb.zip
thank u, so can i use these with codeblocks right away , or do i have to pre-configure it anywhere?
arduinopi+
Mon Nov 17, 2014 4:03 pm
hi,
i unzipped and used dpkg on the deb file, but do u have any idea how i can include these files in my c program
thanks again
Return to “C/C++”
