Re: lazarus
Odd. I have done exactly that on Raspian and it worked just fine. Originally the code compiled with fpc did not run but that has been fixed a few weeks back.
What error messges did you get?
Are you using sudo?
Are you using sudo?
Re: lazarus
I got it working first time, took a few apt-get to get the firebird library installed
but 5 minutes after that I had a app that talked to worked with a Database on another ip address! Lazarus has Arrived!
