latimeria
sickrage
Sun Apr 03, 2016 12:48 pm
Hello all,
is there anyone who can explain a complete setup of sickrage on raspbian jessie?
Many thanks
latimeria
Re: sickrage
Sun Apr 03, 2016 3:02 pm
I just made a mix of two tutorials found on the web:
http://www.algissalys.com/how-to/sickra ... vpi-part-2
and
http://www.htpcguides.com/install-sickr ... ian-linux/
and sickrage seems succesfully installed and working with the following comands from the first guide:
sudo apt-get update && sudo apt-get install git-core python-cheetah python-lxml python-pip python-dev git libssl-dev libxslt1-dev libxslt1.1 libxml2-dev libxml2 libssl-dev libffi-dev
sudo pip install pyopenssl
git clone https://github.com/SickRage/SickRage.git ~/.sickrage
if you have an instance still working on port 8081 ( I have motion working there for example ) search
web_port = 8081
inside file
/home/pi/.sickrage/config.ini
and change port value to a free one.
Then from the second tutorial the sickrage systemd script:
create a new file with
sudo nano /etc/systemd/system/sickrage.service
and paste the following inside:
[Unit]
Description=SickRage Daemon
[Service]
User=pi
Group=pi
Type=forking
GuessMainPID=no
ExecStart=/usr/bin/python /home/pi/.sickrage/SickBeard.py -q --daemon --nolaunch --datadir=/home/pi/.sickrage
[Install]
WantedBy=multi-user.target
then
sudo systemctl enable sickrage.service
and
sudo service sickrage start
now you should reach sickrage at
http://<your-pi-ip>:port_number
thibmaek
Re: sickrage
Tue Oct 18, 2016 3:08 pm
latimeria wrote:I just made a mix of two tutorials found on the web:…
These are actually the best instructions out there. Using systemd and cloning the sickrage repo to the home directory makes bypassing errors so much easier when it comes to permissions.
Return to “Media centres”
