I was running Shairport perfectly on RPi with iOS devices running iOS 5. I've upgraded my iPad to iOS 6 and it don't work anymore. iOS 6 bricks Shairport. When i restart Shairport I can use it from iTunes on my PC and from my iPod using iOS 5. I'm running Shairport on Raspbian!
Did you see the same using iOS 6? Any suggestions?
Thomas
Shairport with iOS 6
truehl
http://www.squeezeplug.de
Re: Shairport with iOS 6
According to:
http://forum.stmlabs.com/showthread.php ... 0#pid16140
"This is a known issue with shairport. See https://github.com/albertz/shairport/issues/157 or https://github.com/albertz/shairport/pull/152 for fix"
Don.
Don.
I wish I understood how to apply the suggested cures
Same here, I did try this this morning, without success. I think that because I don't understand what to do exactly. Could someone who's able to understand tell us exactly what to do?dontod wrote:According to:
Don.
Thanks a lot,
Thomas
truehl
I tried and failed as well trying to to fix this.
Got stuck on the cpan install Net::SDP part of the fix.
My guess with all the iOS devices moving to ios6 in the next few days this will become an issue for lots of people.
Don.
Don.
Hi
I installed the iOS6 version when I first got it, I wasn't able to install net::SDP either.
I'm sure I managed to solve the issue by upgrading cpan. I think I got to this by googling the error I got... But I can recall what that was, so try that?
I'll go through my history to see if I can find it.
I had this problem, I think I resolved it by updating cpan:
# install CPAN
# reload cpan
I did it a while ago, so if that doesn't work, say so and I'll dig back through my web browsing history!!
# install CPAN
# reload cpan
Sorry, but we need some clearer instructions! I can't get it working, did someone else succeed?simonmullan wrote:I had this problem, I think I resolved it by updating cpan:
# install CPAN
# reload cpan
truehl
Here's how I updated to the hendrikw82 version of shairport, which seems to work with iOS6. It assumes you followed the process at http://trouch.com/2012/08/03/airpi-airp ... -raspberry (and check out the comments about iOS6 on that page - maybe soon the regular version of shairport will by updated too.)
sudo su
cd /etc/init.d
./shairport stop
cd
mv shairport shairport_old
aptitude install libmodule-build-perl
git clone https://github.com/njh/perl-net-sdp.git perl-net-sdp
cd perl-net-sdp
perl Build.PL
./Build
./Build test
./Build install
cd
git clone https://github.com/hendrikw82/shairport.git shairport
# and the rest is repeating the install instructions from the trouch.com post
cd shairport
./shairport.pl -a AirPi
# check it works then Ctrl-C
make install
cp shairport.init.sample /etc/init.d/shairport
cd /etc/init.d
chmod a+x shairport
update-rc.d shairport defaults
nano shairport
# edit DAEMON_ARGS line: eg DAEMON_ARGS=”-w $PIDFILE -a AirPi”
./shairport start
sudo su
cd /etc/init.d
./shairport stop
cd
cd perl-net-sdp
perl Build.PL
./Build
./Build test
./Build install
cd
cd shairport
make install
cd /etc/init.d
chmod a+x shairport
nano shairport
./shairport start
Thanks, this worked for me and fixed the issue I was having with shairport crashing when trying to play music from ios6 on the iphone5.
Hi everyone, I've created the deb version of the perl Net::sdp library and also I compiled shairport into a deb package.
The shairport package includes a daemon that start it at boot.
At this point, dpkg may says that need more dependencies, to solve you should run:
Enjoy it!
wget http://www.inf.udec.cl/~diegocaro/rpi/libnet-sdp-perl_0.07-1_all.deb
wget http://www.inf.udec.cl/~diegocaro/rpi/shairport_0.05-1_armhf.deb
sudo dpkg -i libnet-sdp-perl_0.07-1_all.deb
sudo dpkg -i shairport_0.05-1_armhf.deb
sudo apt-get -f install
Much appreciated diegocaro!
Great work, works like a charm! Thanks a lot for it! If you don't mind, I would like to use your .deb files in my SqueesePlug project! And one other question: Is it possible to build these .deb files also for Debian Soft Float? That would be great, because the other device I'm supporting with SqueezePlug are not Debian Hf!diegocaro wrote:Hi everyone, I've created the deb version of the perl Net::sdp library and also I compiled shairport into a deb package.
At this point, dpkg may says that need more dependencies, to solve you should run:Code: Select all
wget http://www.inf.udec.cl/~diegocaro/rpi/libnet-sdp-perl_0.07-1_all.deb wget http://www.inf.udec.cl/~diegocaro/rpi/shairport_0.05-1_armhf.deb sudo dpkg -i libnet-sdp-perl_0.07-1_all.deb sudo dpkg -i shairport_0.05-1_armhf.deb
Enjoy it!Code: Select all
Thanks a lot Thomas
truehl
First, you are free to use the .deb files wherever you want, that's the idea!truehl wrote: Great work, works like a charm! Thanks a lot for it! If you don't mind, I would like to use your .deb files in my SqueesePlug project! And one other question: Is it possible to build these .deb files also for Debian Soft Float? That would be great, because the other device I'm supporting with SqueezePlug are not Debian Hf!
Thanks a lot Thomas
I think that is possible to build deb files for soft float, but for now I will not provide the sources (I'm trying to learn more about the Debian packaging system to provide a high quality deb sources).
Greetings from Chile!
I have been running the previous version of Shairport for some time with iOS5, and have recently upgraded to the iOS6 version. In both cases I have been getting a problem I would describe as "drop-out". I am streaming radio to the Pi though iTunes, and occasionally the stream will halt. By going to iTunes and disconnecting the Pi, streaming to the local PC for a few seconds, and then reconnecting the Pi it comes back to life. Has anyone else had a similar problem?
I am running wireless through an Edimax EW7811, and initially thought it was a signal drop-out, but I have a putty terminal connected at the same time, and this continues to work after the Pi has stopped responding to the Airplay stream. It seems as if something drops and it is unable to recover. Any ideas?
Added note: On running dmesg I see that Alsa is closing with:
snd_bcm2835_playback_close:167 Also close
Reconnecting with iTunes opens Alsa again, but it will play for 10 minutes and then close itself.
I had the same problem and reinstalled shairport using this tutorial http://jtech4you.com/how-to-setup-a-ras ... -receiver/ and now it works fine
