I'm using the latest image of wheezy (2012-09-18)
I want to install xbmc because omxplayer to simple is. but when i do so i get errors :
pi@raspberrypi ~ $ sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
Recommends: python-qt3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
