beardedwonder
V4L DVB-T on Raspbmc
Wed Jan 30, 2013 11:55 am
I've been trying to get a DVB-T stick running on Raspbmc. I managed to get the stick working on Ubuntu.
I have got all the dependencies to clone, build and make, I have also installed headers (3.6.11 headers don't seem to be available).
After running 'sudo make kernel-links', which completed fine. I ran ./build and got the following error:
Preparing to compile for kernel version 3.6.11
You appear to have loadable modules turned off in your kernel.  You can
not compile the v4l-dvb drivers, as modules, and use them with a kernel
that has modules disabled.
If you want to compile these drivers into your kernel, you should
use 'make kernel-links' to link the source for these drivers into
your kernel tree.  Then configure and compile the kernel.
make[1]: *** [allyesconfig] Error 255
make[1]: Leaving directory `/home/pi/temp/media_build/v4l'
make: *** [allyesconfig] Error 2
can't select all drivers at ./build line 451.
Does anyone know how I can get passed this error?
HarryL
Re: V4L DVB-T on Raspbmc
Wed Jan 30, 2013 1:21 pm
yes you need the kernel headers..
cd /usr/src
git clone https://github.com/raspberrypi/linux.git
and an symlink for build..(will get back on that when got clone is done).
im in the process to do the same right now.. dvb_2382u module
deltas take a lot off time ;-)=-
i'll get back to you
2 Model B 256MB / 2 Model B 512MB / Gertboard / HDhomerun,Anysee E30 C Plus DVB-C Tuner
beardedwonder
Wed Jan 30, 2013 2:53 pm
I have run clone now, what do I have to do next?
sblaster
Sat Feb 02, 2013 3:27 pm
Same on.
The main problem is to find the right headers. I've tried the 3.6.11+ headers, but actually i could not insmod the module...
What should I do ? try to upgrade kernel to 3.6.11+, which will compromise xbmc, or compile 3.6.11 (but i don t have enough space on my SD Card).
beardedwonder
Sat Feb 02, 2013 10:20 pm
I'm still struggling with this and haven't managed to get any further. The new version of Raspbmc might be out tomorrow, will that be of any help here?
sblaster
Sun Feb 03, 2013 8:44 am
No, but next Openelec seems because in kernel 3.7, there is support for the new Terratec Dongle... We'll see
Spid
Sun Feb 03, 2013 9:15 am
OpenELEC Testing - Raspberry Pi ARM Version:2.99.2 (3.0 RC 2) was released 29/01/2013
http://openelec.tv/get-openelec/viewcat ... -pi-builds
http://wiki.openelec.tv/index.php?title ... spberry_Pi
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
sblaster
Sun Feb 03, 2013 9:30 am
Yep but still 3.6.11. I've seen some hints that next one will be 3.7.4
beardedwonder
Tue Mar 26, 2013 1:46 am
Still haven't been able to get this stick to work. Hoping someone will be able to help.
lsusb:
Bus 001 Device 004: ID 15a4:1001 Afatech Technologies, Inc. AF9015/AF9035 DVB-T stick
dmesg:
dvb-usb: found a 'Afatech AF9035 reference design' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Afatech AF9035 reference design)
af9035: tuner ID=2e not supported, please report!
dvb-usb: MAC address: 00:00:00:00:00:00
af9033: firmware version: LINK=11.5.9.0 OFDM=5.17.9.1
DVB: registering adapter 0 frontend 0 (Afatech AF9033 (DVB-T))...
Registered IR keymap rc-empty
input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/rc/rc0/input1
rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/rc/rc0
dvb-usb: Afatech AF9035 reference design successfully initialized and connected.
usbcore: registered new interface driver dvb_usb_af9035
tvjon
Wed Feb 05, 2014 6:35 pm
HarryL wrote:yes you need the kernel headers..
cd /usr/src
git clone https://github.com/raspberrypi/linux.git......
Yes, deltas did, but sadly this is the result:
Cloning into 'linux'...
remote: Reusing existing pack: 3393260, done.
remote: Counting objects: 5, done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 3393265 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (3393265/3393265), 920.25 MiB | 1.39 MiB/s, done.
error: index-pack died of signal 999996)
fatal: index-pack failed
Return to “Media centres”
