GStreamer 1.0
Hi ,
I've had no luck getting the GStreamer 0.10 to work.
So, following some advice I've started installing the 1.0 packages.
It appears to be installed, but some packages are missing.
Such as autovideosink.
So, someone suggested that I use eglglessink instead. But, the config.log for the 'bad' plugins shows that package can't be installed because I don't have libtimemmgr package installed.
But, I can't find how to install libtimemmgr. Is there an apt-get for it ?
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
I've just tried to build the 'bad' package with --enable-eglgles on the ./configure command.
But, eglglessink is still not built.
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
What sources do you use to build?
libtimemmgr sounds like a TI-Library (OMAP etc)
Did you follow the howto?
Re: GStreamer 1.0
Try downloading the gstreamer SDK from gstreamer.com. The SDK comes with a build system called cerbero that can be setup for native an cross compilation. The result is a complete 'distro' for gstreamer.
I have the SDK working fine on Fedora 17.
Re: GStreamer 1.0
Yes, I tried the howto, but that doesn't compile.Defiant wrote:What sources do you use to build?
I get as far as doing 'sudo make install' to gst-plugins-base' but it fails with lots of errors.
One of them is:
'video-format.c:1132:7: error: too many arguments to function 'video_orc_unpack_YUV9'
There are lots of other similar errors to similarly named functions
Regards
Nick
Re: GStreamer 1.0
Maybe you are on a broken commit? Try an older one.
Re: GStreamer 1.0
How do I get an older one? Is it by using the -b option to git ?Defiant wrote:Maybe you are on a broken commit? Try an older one.
Regards
Nick
Re: GStreamer 1.0
Try tag 1.0.6 or 1.0.7. -b is for branches.
Re: GStreamer 1.0
Well, it does get a bit further using 1.0.7 tag.
But, compiling gst-libav fails due to lack of memory.
This is on the 512MB pi too!
I guess other people must have some sort of virtual memory setup to do this.
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
You sure you want a codec from libav?
Re: GStreamer 1.0
I'm following the HOWTO doc.Defiant wrote:You sure you want a codec from libav?
Regards
Nick
Re: GStreamer 1.0
libav contains the Software codecs which are really slow. In most cases one usually prefers the gst-omx hardware codec.
Re: GStreamer 1.0
No. I compiled gst-libav yesterday on a Pi with 512MB memory with gpu_mem set to 128nickon314 wrote:Well, it does get a bit further using 1.0.7 tag.
Re: GStreamer 1.0
Maybe the HOWTO needs updating.
If libav is pointless on the Pi, and we don't have enough RAM to actually build it - how did it get in there in the first place?
Nick
Nick
Re: GStreamer 1.0
Its not pointless, since it contains decoders that are not part of gst-omx - its just a question if you need these codecs or not.
Re: GStreamer 1.0
I too have GPU_men set to 128.
Do you have any virtual memory setup?
I turned off swap because my memory card is getting full.
Regards
Nick.
Regards
Nick.
Re: GStreamer 1.0
I was just using the 2013-02-09-wheezy-raspbian image updated, upgraded and with rpi-update run on it.nickon314 wrote:I too have GPU_men set to 128.
Do you have any virtual memory setup?.
Here's a vmstat:
pi@raspi1 ~ $ vmstat
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
r b swpd free buff cache si so bi bo in cs us sy id wa
0 0 0 64900 13124 125756 0 0 5 7 50 76 20 2 78 0
Perhaps that's your issue. I've compiled GStreamer 1.0 many times on the Pi and I've never had an issue with lack of memory.nickon314 wrote:I turned off swap because my memory card is getting full.
Is there a particular reason why you want to compile it yourself rather than using Defiant's GStreamer 1.0 Packages?
Re: GStreamer 1.0
I've dropped GPU mem down to 64MB, and now that compiles.
I'm now trying to build gst-plugins-bad, but that fails because Schroedinger/schro.h is missing.
It's #included from gstschro.c .
Any suggested fix for that problem?
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
Here's the libraries I installed before compiling any of the GStreamer stuff. It may be included as one of them. :nickon314 wrote:I'm now trying to build gst-plugins-bad, but that fails because Schroedinger/schro.h is missing.
sudo apt-get install -y build-essential autotools-dev automake autoconf \
libtool autopoint libxml2-dev zlib1g-dev libglib2.0-dev \
pkg-config bison flex python git gtk-doc-tools libasound2-dev \
libgudev-1.0-dev libxt-dev libvorbis-dev libcdparanoia-dev \
libpango1.0-dev libtheora-dev libvisual-0.4-dev iso-codes \
libgtk-3-dev libraw1394-dev libiec61883-dev libavc1394-dev \
libv4l-dev libcairo2-dev libcaca-dev libspeex-dev libpng-dev \
libshout3-dev libjpeg-dev libaa1-dev libflac-dev libdv4-dev \
libtag1-dev libwavpack-dev libpulse-dev libsoup2.4-dev libbz2-dev \
libcdaudio-dev libdc1394-22-dev ladspa-sdk libass-dev \
libcurl4-gnutls-dev libdca-dev libdirac-dev libdvdnav-dev \
libexempi-dev libexif-dev libfaad-dev libgme-dev libgsm1-dev \
libiptcdata0-dev libkate-dev libmimic-dev libmms-dev \
libmodplug-dev libmpcdec-dev libofa0-dev libopus-dev \
librsvg2-dev librtmp-dev libschroedinger-dev libslv2-dev \
libsndfile1-dev libsoundtouch-dev libspandsp-dev libx11-dev \
libxvidcore-dev libzbar-dev libzvbi-dev liba52-0.7.4-dev \
libcdio-dev libdvdread-dev libmad0-dev libmp3lame-dev \
libmpeg2-4-dev libopencore-amrnb-dev libopencore-amrwb-dev \
libsidplay1-dev libtwolame-dev libx264-dev
Re: GStreamer 1.0
Nick,fbutler wrote:I've started a complete up to date Gstreamer 1.0 compile tonight on one of my Pi's. If it is successful I'll post my script for the build here tomorrow.
I had a couple of syntax errors building it overnight due to poor cutting and pasting by me in the build script, however I've corrected these now. The build script that I used can be found here:
http://www.trans-omni.co.uk/pi/GStreame ... _gstreamer
Re: GStreamer 1.0
Did your build work ok?
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
Oops, looks like our forum posts crossed in the mail.
Regards
Nick
Regards
Nick
Re: GStreamer 1.0
Yes, I believe so, but I won't be fully testing it until tonightnickon314 wrote:Did your build work ok?
Regards
Nick
If you do a gst-inspect-1.0 after the build you should see:
Total count: 189 plugins, 1068 features
at the end of the listing
If you do a gst-inspect-1.0 | grep omx you should see the following gst-OMX components:
omx: omxmpeg2videodec: OpenMAX MPEG2 Video Decoder
omx: omxmpeg4videodec: OpenMAX MPEG4 Video Decoder
omx: omxh263dec: OpenMAX H.263 Video Decoder
omx: omxh264dec: OpenMAX H.264 Video Decoder
omx: omxtheoradec: OpenMAX Theora Video Decoder
omx: omxvp8dec: OpenMAX VP8 Video Decoder
omx: omxmjpegdec: OpenMAX MJPEG Video Decoder
omx: omxvc1dec: OpenMAX WMV Video Decoder
omx: omxh264enc: OpenMAX H.264 Video Encoder
################# SET UP GSTREAMER ENVIRONMENT ##########
cd $HOME
echo -e \\n# Gstreamer environment >> .profile
echo export GST_PLUGIN_PATH=/usr/local/lib/gstreamer-1.0/ >> .profile
echo export GST_OMX_CONFIG_DIR=/usr/local/etc/xdg/ >> .profile
echo export LD_LIBRARY_PATH=/usr/local/lib/ >> .profile
. ./.profile
rm ~/.cache/gstreamer-1.0/registry.armv6l.bin
# Install the v4l-utils to be able to use the v4l2-ctl command to configure
# v4l2 input devices, such as webcams, if required
sudo apt-get install v4l-utils
Re: GStreamer 1.0
I had to use this to build gst-plugins-bad :
make CFLAGS+="-I/usr/include/schroedinger -Wno-error"
otherwise it can't find schro.h file.
Re: GStreamer 1.0
I had no issues with compiling gst-plugins-bad without that. Here's an excerpt for my build log for the make:nickon314 wrote:I had to use this to build gst-plugins-bad :
make -C schroedinger
make[3]: Entering directory `/home/pi/myNAS/RaspberryPiPackages/gstreamer-1.0/gst-plugins-bad/ext/schroedinger'
CC libgstschro_la-gstschro.lo
CC libgstschro_la-gstschrodec.lo
CC libgstschro_la-gstschroenc.lo
CC libgstschro_la-gstschroutils.lo
CCLD libgstschro.la
make[3]: Leaving directory `/home/pi/myNAS/RaspberryPiPackages/gstreamer-1.0/gst-plugins-bad/ext/schroedinger'
Making install in schroedinger
make[2]: Entering directory `/home/pi/myNAS/RaspberryPiPackages/gstreamer-1.0/gst-plugins-bad/ext/schroedinger'
make[3]: Nothing to be done for `install-exec-am'.
/bin/mkdir -p '/usr/local/lib/gstreamer-1.0'
/bin/bash ../../libtool --mode=install /usr/bin/install -c libgstschro.la '/usr/local/lib/gstreamer-1.0'
libtool: install: /usr/bin/install -c .libs/libgstschro.so /usr/local/lib/gstreamer-1.0/libgstschro.so
libtool: install: /usr/bin/install -c .libs/libgstschro.lai /usr/local/lib/gstreamer-1.0/libgstschro.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/local/lib/gstreamer-1.0
Libraries have been installed in:
