Have just installed and tried this, and unless you turn off the squeezelite player then shairport won't work. I wonder if it's possible to write some kind of script which will listen for a connection to shairport and automatically turn off squeezelite, then once the connection leaves it turns it back on.
Also I went to edit my default soundcard for shairport in /etc/init.d/shairport which then told me to go to /etc/default/shairport but this was empty?
Re: SqueezePlug Version 7 available
FWIW, I am having the same problem. Although my shairport audio is coming out of HDMI...not sure how to change it..
-Craig
-Craig
Hi Thomas
I've been happily running Squeezeplug 5 for well over a year, and I've had no major issues.
Is it worth me getting a new SD card and trying Version 7?
I don't run any of the client stuff (Squeezelite etc), just LMS and MiniDLNA (because the LMS DLNA server is useless for videos and photos on my Smart TV)
Squeeze Plug 5 has my LMS on Logitech Media Server Version: 7.7.2 - r33893
What benefits will I get on SPlug 7?
I'd mainly be interested in performance improvement (browse times on the Logitech clients and scan times) but maybe this can be done by overclocking? I've not ventured into the realms of overclocking yet
Is it possible to control the volume with button connected on gpio?
or something else?
may be this product (normaly for xbmc)
http://www.audiophonics.fr/audiophonics ... -8435.html
or something else?
quick question.. is spotify working at all?? ive tried v6 and v7 and audio is either in slowmotion or not playing at all.. been playing with it all weekend.. tried installing lame but no luck..
thanks!!
thanks!!
Up until today I've been successfully getting sound using HDMI into a splitter box which extracts the audio and sends it via SPDIF to my HiFi. It works very well but requires an external powered splitter box.
Today I got a Wolfson Audio Card that sits directly on the GPIO of my RPi (it uses the P5 header and at least one of the normal header pins) . It has SPDIF output so hopefully I will no longer need the splitter box. The question I have is how do I configure Squeezeplug to use the Wolfson audio card's SPDIF out ?
First we need the output of "squeezelite -l", then we can see which parameters we will need to start SqueezeLite. Pleas post this output here!bantammenace2012 wrote:Up until today I've been successfully getting sound using HDMI into a splitter box which extracts the audio and sends it via SPDIF to my HiFi. It works very well but requires an external powered splitter box.
Thomas
truehl
http://www.squeezeplug.de
It works, but it will need a paid Spotify account!tomriddle wrote:quick question.. is spotify working at all?? ive tried v6 and v7 and audio is either in slowmotion or not playing at all.. been playing with it all weekend.. tried installing lame but no luck..
thanks!!
Thomas
truehl
Never touch a running system! There is no relevant performance improvement, as far as I know! I've eliminated a lot of bugs, now use the actual community Rasbbpian image and so on! If the old image is running well for you, keep it as it is!bobbydriver wrote:Hi Thomas
Thomas
truehl
Good advice, but I picked up a cheap Class 10 4GB SD card and had a play at the weekend. It seems to work fine. To be honest I had loaded so many additional packages on my Pi since I started with Squeezeplug 5 that I was glad of the chance to tidy up and get a newer Raspbian image.truehl wrote: Never touch a running system! There is no relevant performance improvement, as far as I know! I've eliminated a lot of bugs, now use the actual community Rasbbpian image and so on! If the old image is running well for you, keep it as it is!
Thomas
Performance does indeed not seem to be any different - I've upped the overclock to medium, but it doesn't seem to make a noticeable difference, so I think that the bottleneck to performance on the scan must be the samba share that holds my library
Unfortunately, *all* music is playing in "slow motion" for me with version 7tomriddle wrote:quick question.. is spotify working at all?? ive tried v6 and v7 and audio is either in slowmotion or not playing at all.. been playing with it all weekend.. tried installing lame but no luck..
thanks!!
Updating the buffering *while music was playing* seemed to fix this for me.fuzzybee wrote:Unfortunately, *all* music is playing in "slow motion" for me with version 7tomriddle wrote:quick question.. is spotify working at all?? ive tried v6 and v7 and audio is either in slowmotion or not playing at all.. been playing with it all weekend.. tried installing lame but no luck..
thanks!!
I'm pretty sure that it's not a problem with the Samba share! The last days I did some tests with an Odroid U3 device. It's a very promising 1,7 GHz Quad Core, 2GB RAM device. I'm using an eMMC card, coming with the device. Following the vendor, this card is about 6 times faster than an class 10 SD card. Performance of Squeezebox, especially scanning the library runs about six times quicker as with a Raspberry Pi. They both use the same Samba share, so it won't be Samba!bobbydriver wrote:Performance does indeed not seem to be any different - I've upped the overclock to medium, but it doesn't seem to make a noticeable difference, so I think that the bottleneck to performance on the scan must be the samba share that holds my library
Thomas
truehl
Hello, i buy the kayboard but don't work over squeezeplug or picoreplayerTheD6Bel wrote:Hello,
or something else?
Hello, I am excited to try out the new build but I'm having trouble installing it on an SD card. I have tried a 8GB class 10 Patriot card and a 4GB class 6 Verbatim card with no luck booting. I used USB Image Tool in device mode with the first 2 boxes checked under "options". Is there anything I'm doing wrong? Maybe the install process is different with this new build?
Thank's for any help!
UPDATE: I tried both sd card's in my model b 1st gen (256MB) pi and they booted, but they still won't boot in my 2nd gen (512MB). Seems like a hardware issue but it's beyond me.
This bothered me a lot about version 6 and I hoped it would be fixed in v7 but I guess not. It's either one or the other I guess.Marky89 wrote:Have just installed and tried this, and unless you turn off the squeezelite player then shairport won't work. I wonder if it's possible to write some kind of script which will listen for a connection to shairport and automatically turn off squeezelite, then once the connection leaves it turns it back on.
Sounds strange, but you are the very first reporting boot problems with version 7. So I think it must be an individual problem for you, sorry!gabevr wrote:Hello, I am excited to try out the new build but I'm having trouble installing it on an SD card. I have tried a 8GB class 10 Patriot card and a 4GB class 6 Verbatim card with no luck booting. I used USB Image Tool in device mode with the first 2 boxes checked under "options". Is there anything I'm doing wrong? Maybe the install process is different with this new build?
Thomas
truehl
Thanks for the info - on that basis I guess the Pi is just going as fast as it can. I have circa 70,000 mp3s and it takes about 20 minutes to do a scan for changes. A full rescan takes about 8 hourstruehl wrote: I'm pretty sure that it's not a problem with the Samba share! The last days I did some tests with an Odroid U3 device. It's a very promising 1,7 GHz Quad Core, 2GB RAM device. I'm using an eMMC card, coming with the device. Following the vendor, this card is about 6 times faster than an class 10 SD card. Performance of Squeezebox, especially scanning the library runs about six times quicker as with a Raspberry Pi. They both use the same Samba share, so it won't be Samba!
Thomas
The Odroid U3 sounds awesome but I can't find anywhere that sells them in the UK. Importing one from Korea sounds like a hassle, as you have to deal with UK customs. I'll definitely get one when they become widely available
Hello and thanks for your hard work. 2 simple noob questions:
-I want to use my Ubuntu laptop as the server and 3 squeezeplug raspis as clients for simultaneous playback multi-room audio. I would like the laptop server to also output sound to speakers, to have music in 4 rooms. Is this possible?
-Can I capture the output of my Ubuntu laptop soundcard (playing pianobar/pithos/pandora) and broadcast to the squeezeplugs?
Thanks again!
Pete
Thanks again!
Pete
I got it working, I think the image got corrupted during the download/extraction because a fresh download worked first try.truehl wrote:Sounds strange, but you are the very first reporting boot problems with version 7. So I think it must be an individual problem for you, sorry!gabevr wrote:Hello, I am excited to try out the new build but I'm having trouble installing it on an SD card. I have tried a 8GB class 10 Patriot card and a 4GB class 6 Verbatim card with no luck booting. I used USB Image Tool in device mode with the first 2 boxes checked under "options". Is there anything I'm doing wrong? Maybe the install process is different with this new build?
Thomas
Thanks!
So I tried installing Squeezeslave as a workaround for this issue and seems to have worked. I was able have audio from Squeezeslave and Shairport streaming simultaneously via the Raspi analog out (Haven't tried my DAC yet). I know Squeezelite is the preffered player but Squeezeslave seems fine so far and this is a big enough plus for me to keep using it!gabevr wrote:This bothered me a lot about version 6 and I hoped it would be fixed in v7 but I guess not. It's either one or the other I guess.Marky89 wrote:Have just installed and tried this, and unless you turn off the squeezelite player then shairport won't work. I wonder if it's possible to write some kind of script which will listen for a connection to shairport and automatically turn off squeezelite, then once the connection leaves it turns it back on.
Right now you have to Order directly in Korea. I was very impressed about the time for shipping! It lasts only one week to deliver it to Germany. Customs was no problem, FedEx did the job and send me the bill a few days later. There was no toll, only 19% VAT.bobbydriver wrote:The Odroid U3 sounds awesome but I can't find anywhere that sells them in the UK. Importing one from Korea sounds like a hassle, as you have to deal with UK customs. I'll definitely get one when they become widely available
Thomas
truehl
Does anyone know how to change the audio output of Shairport? I'm using a UCA202 DAC and squeezeslave works great through it but Shairport is still going through the analog out. I've changed the alsa sound card to usb and I've looked through what I think is the config file in /etc/init.d/shairport, but I'm just not sure what settings to change if any.
Any help is much appreciated!
Hi,TheD6Bel wrote: Hello, i buy the keyboard but don't work over squeezeplug or picoreplayer
i trie the keyboard with raspbmc and it work perfectly but i need squeezeplug and not xbmc. Is possible to assign the volume keys on squeezeslave ?
I really need to control the volume with the button to make a preamp, thank's for your help
Hi-
I got the system working beautifully on 3 raspi's and an old laptop running Ubuntu.
I wasn't able to get audio out through my usb soundcards (C-Media C119), but for the time being the regular headphone jack on the pi's is serving the purpose.
I had these soundcards working on Raspian before by this:
Change
By commenting out
Restart, and all sound was routed to these great little sound cards.
The current configuration of that file looks very different.
Can you give me some guidance, please?
This soundcard is one of 3 easily found on Amazon in the states, so I doubt I am the only one that will have this issue.
http://www.amazon.com/Syba-SD-CM-UAUD-A ... +soundcard
Thanks, and AMAZING work!!!
Change
/etc/modprobe.d/alsa-base.conf
By commenting out
options snd-usb-audio index=-2
