Max
OpenELEC 4 Debian
Sun Jun 24, 2012 1:08 am
For people short on SD cards, I created an OpenELEC Debian package for Debian Wheezy.
To install under Debian Wheezy:
wget http://www.berryterminal.com/dl/openelec_0.1_armel.deb
sudo dpkg -i openelec_0.1_armel.deb
sudo cp /boot/arm128_start.elf /boot/start.elf
sudo reboot
To start:
sudo OpenELEC
(Will simply shutdown running Debian services, and launch OpenELEC in a chroot under /opt/OpenELEC)
Advantages over having OpenELEC on a seperate SD card:
  • saves you an extra SD card.
  • easier to download stuff under Debian and play on OpenELEC later.
Disadvantages:
  • Requires the 128 MB RAM split. (less memory available to the main system, more to the GPU)
If you want to use CEC (the ability to control the media player with your normal TV remote), make sure you enabled the following setting: "System" -> "Settings" -> "Services" -> "Webserver" -> "Allow control of XMBC via HTTP"
teomac
Re: OpenELEC 4 Debian
Sun Jun 24, 2012 6:54 am
Thank you, seems interesting. I'm going to try it :)
WebdevNZ
Fri Jun 29, 2012 10:45 am
Download and install seems to work just fine. Streaming files from a UPnP source is working pretty well.
Only things I have noticed is when I run OpenELEC I get the following...
Shutting down services...
[ ok ] Stopping Light Display Manager: lightdm.
[ ok ] Stopping NFS common utilities: idmapd statd.
[ ok ] Stopping rpcbind daemon....
[ ok ] Network Interface Plugging Daemon...stop eth0...done.
[ ok ] Stopping enhanced syslogd: rsyslogd.
[ ok ] Stopping Samba daemons: nmbd smbd.
[ ok ] Stopping periodic command scheduler: cron.
[ ok ] Stopping system message bus: dbus.
Stopping dphys-swapfile swapfile setup ..., done.
[ ok ] Stopping NTP server: ntpd.
[ ok ] Stopping OpenBSD Secure Shell server: sshd.
[ ok ] Stopping the Winbind daemon: winbind.
[ ok ] Stopping the hotplug events dispatcher: udevd.
Starting OpenELEC in chroot...
OpenELEC - Version: devel-20120623213722-r1
mkdir: can't create directory '/dev/shm': No such file or directory
mount: mounting none on /dev/shm failed: No such file or directory
I went on a hunt to look into the /dev/shm and have found that a blank file gets created??
Has this got anything to do with saved preferences or settings? The image that is displayed by OpenELEC is slightly larger than my screen so I resize it but this setting does not seem to be retained.
Thanks for any help or idea you have...
Greenstreet
Fri Jun 29, 2012 10:51 am
I have followed the instructions but when I try to start with typing sudo OpenELEC my monitor goes black and nothing else happens. :?:
Max
Fri Jun 29, 2012 12:48 pm
WebdevNZ wrote:I went on a hunt to look into the /dev/shm and have found that a blank file gets created??
Should be able to do fine without /dev/shm
Noticed the same problem, both with OpenELEC under Wheezy and standalone.
Haven't found a real solution for that.
As a workaround I switched my TV to a different p.size/zoom setting and it did fit then.
glepore70
Fri Jun 29, 2012 3:36 pm
Thanks for the file, I was to install it with no problems. However, I'm getting random hangs when navigating the menus with an attached USB mouse (which works just fine in Wheezy.) Also, is there any way to enable ssh into openELEC? I tried adding the ssh_enable file in config, but no luck. Perhaps the chroot environment has something to do with it?
Lastly, is there any dead easy way to have openELEC see my files which are share by SAMBA from another machine?
Max
Fri Jun 29, 2012 5:24 pm
glepore70 wrote:Thanks for the file, I was to install it with no problems. However, I'm getting random hangs when navigating the menus with an attached USB mouse (which works just fine in Wheezy.) Also, is there any way to enable ssh into openELEC? I tried adding the ssh_enable file in config, but no luck. Perhaps the chroot environment has something to do with it?
Not sure about the mouse, I use my TV remote (CEC) and didn't experience problems.
Might need to load additional drivers (probably: sudo modprobe cifs) before starting OpenELEC.
pc77
Fri Jun 29, 2012 7:52 pm
I have got and armhf error and could not install the deb file. I am using raspbian piesces.
Max
Fri Jun 29, 2012 8:04 pm
pc77 wrote:I have got and armhf error and could not install the deb file. I am using raspbian piesces.
Package has not been tested under Raspbian, and does not advertise it is compatible in the meta data (although it should be).
If you want to try it, you need to add "--force-architecture" to the dpkg line.
ghans
Fri Jun 29, 2012 9:20 pm
Can't this be turned into a XBMC package ?
Would be nice ro have it in the official repos.
ghans
pc77
Fri Jun 29, 2012 9:25 pm
It worked!
Now i can't change sound output to analogic to use the RCA video. The system hangs.
Max
Sat Jun 30, 2012 3:20 pm
glepore70 wrote:Also, is there any way to enable ssh into openELEC? I tried adding the ssh_enable file in config, but no luck. Perhaps the chroot environment has something to do with it?
Does work for me
In Debian: sudo touch /opt/OpenELEC/storage/.config/ssh_enable
login with root/openelec
Max
Sat Jun 30, 2012 4:45 pm
pc77 wrote: Now i can't change sound output to analogic to use the RCA video. The system hangs.
Seems to be a bug.
As a temporary workaround, switch to analog manually:
sudo sed -i 's/<mode>2/<mode>0/' /opt/OpenELEC/storage/.xbmc/userdata/guisettings.xml
Be aware that there are still some other issues with analog audio though.
Seems if CPU usage spikes, audio has a hickup, and also goes out of sync with the video.
Zeek20
Sat Jun 30, 2012 5:49 pm
Edit: I do have squeeze tho, if that makes a diff, then I know where the problem is lol....
Right now I have an issue with OpenElec's playing videos, whenever I try, it opens them I see the network light blink and the tv just goes to a ton of random lines and a horrid sound comes out lol....(no I don't mean tv snow....)
Is it not opening the videoplayer correctly? Or is there a step in the setup that i'm missing?
Max
Sat Jun 30, 2012 6:03 pm
Zeek20 wrote:Edit: I do have squeeze tho
Squeeze might work.
But then you need to at least update the firmware.
(and after update make sure you are still using the 128 mb memory split
"cat /proc/meminfo" should give: MemTotal: 123180 kB
if not do "sudo cp /boot/arm128_start.elf /boot/start.elf" again, and reboot)
Paul_L
Sat Jun 30, 2012 7:22 pm
Installed , started ok but in wheezy I was using a WLAN nano USB adapter that is not working anymore in openelec after restarting services. I don't how to setup the WLAN adapter in openelec. Can somebody help me ?
bsan
Sat Jun 30, 2012 7:23 pm
I did have the same problem.
But the system also hangs when I try to change the seaker configuration from 2.0 - while keeping the audio output as HDMI.
Anyway. Apart from this it has been pretty stable. Thanks Max.
Seems to be a bug.
ghans
Sat Jun 30, 2012 7:57 pm
Just a little bit confused :
Is this really a XMBC package or a OpenELEC package ?
Isn't OpenELEC a "real" , slimmed-down distro ?
ghans
Max
Sat Jun 30, 2012 9:17 pm
ghans wrote:Just a little bit confused :
This is the entire OpenELEC distribution, including all supporting programs and libraries.
Packaged as a .deb to allow easy installation on a SD card that already has Debian on it.
Correct, it is an independent distribution.
But as demonstrated here, one can start other distributions from within Debian.
There are no technical limitations preventing that.
Just a simple script of a couple lines that shuts down Debian's running services to free up resources, and starts OpenELEC's /sbin/init in a chroot ( https://en.wikipedia.org/wiki/Chroot )
That way OpenELEC can use its own optimized hardfp libraries.
If one creates a real Debian XBMC package instead, you are stuck with Debian's system libraries and suffer in performance because they are softfp. (unless you use Raspbian)
Max
Sat Jun 30, 2012 10:16 pm
Paul_L wrote:Installed , started ok but in wheezy I was using a WLAN nano USB adapter that is not working anymore in openelec after restarting services. I don't how to setup the WLAN adapter in openelec. Can somebody help me ?
Wifi settings and the like are hidden under: "Programs" -> "OpenELEC OS Settings" -> "Network"
Don't forget to use the scroll bar on the right to get to all the settings (like the SSID).
Reboot is necessary for changes to effect.
mathewjenkinson
Sat Jun 30, 2012 10:50 pm
Works a treat :)
2 things:
1) I can't get my Microsoft USB Remote to work - it works out of the box for OpenElec and Raspian - so do I need to get drivers for it from somewhere?
2) is there a way I can write a script so that on boot it waits 10 seconds for a keystroke otherwise loads straight into OpenElec?
other than that, well done and many thanks!
Max
Sat Jun 30, 2012 11:21 pm
mathewjenkinson wrote:2 things:
Try enabling SSH on standalone OpenELEC, log in, and do a "lsmod"
Does it show the name of the module your USB remote uses?
There is not an easy one line command to do that with this package.
Although if you know some programming you may be able to write a script for that, and put it in /etc/rc.local so that it is executed on boot.
It does is a feature I do want to add to the next version of my BerryBoot boot selection screen.
I did some initial work to replace the text selection screen in the current version, with a simple GUI that currently looks like this:
With a button to make one OS the default, so that it is booted automatically after a number of seconds unless you press a key or wiggle your mouse.
But the new version is not ready for release yet, and also still needs some work to deal with the different memory splits each operating system prefers, before I can add OpenELEC to the mix.
Paul_L
Sun Jul 01, 2012 5:24 am
Max wrote: Wifi settings and the like are hidden under: "Programs" -> "OpenELEC OS Settings" -> "Network"
Something not working well. Even after reboot there are the settings it is not connecting to the WLAN. Is there a possibility to see some more messages to see what is wrong ? Anyway that damn display overscan settings that I am clearing are not saved so I am obliged to redo every time .
mathewjenkinson
Sun Jul 01, 2012 11:15 am
The reply from lsmod:
ipv6                  213236  28
evdev                   6840  0
i tried to install lirc but doesnt seem to have done anything. So I must be missing something somewhere.
Cool.Majkl
Sun Jul 01, 2012 7:30 pm
How I get this error all the time.
pi@raspberrypi:~/downloads$ sudo dpkg -i openelec_0.1_armel.deb
(Reading database ... 49414 files and directories currently installed.)
Unpacking openelec (from openelec_0.1_armel.deb) ...
dpkg: error processing openelec_0.1_armel.deb (--install):
 failed in write on buffer copy for backend dpkg-deb during `./opt/OpenELEC/usr/share/xbmc/language/Polish/strings.po': No space left on device
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Does anybody know what could be the problem ? I quite new to Linux. Thanks for replies.
Return to “Media centres”
