If I do this, my resolv.conf file is as expected
nameserver 8.8.8.8
nameserver 8.8.4.4
/etc/network/interfaces
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.0.140
netmask 255.255.255.0
gateway 192.168.0.1
dns-nameservers 8.8.8.8 8.8.4.4
Alright, but I haven't connected to any network, so I try this
auto wlan0
allow-hotplug wlan0
address 10.0.0.5
gateway 10.0.0.1
wpa-scan-ssid 1
wpa-ap-scan 1
wpa-key-mgmt WPA-PSK
wpa-proto RSN WPA
wpa-pairwise CCMP TKIP
wpa-group CCMP TKIP
wpa-ssid "blah"
wpa-psk blahblah
That works, but my resolv conf gets some extra crap from dhcpcd which should not be called by ifup :/
dhcpcd adds these 2 lines, in the name of wlan0
nameserver 10.0.0.1
nameserver fe80::1%wlan0
if I run resolvconf -i I get
wlan0 wlan0:ra wlan0.inet
I want static. I don't want those entries in my resolv.conf file. And I don't want dhcpcd getting called.
Any ideas?
PS: I like the /etc/network/interfaces ONLY approach. But if it's buggy with static I could use a WPA supplicant conf file.
Alternatively how can I disable resolvconf?
- DougieLawson
Re: WPA supplicant static IP /etc/network/interfaces problem
With Jessie static IP addresses are done on /etc/dhcpcd.conf NOT in /etc/network/interfaces. Undo your changes.
The man dhcpcd.conf command tells you how to do it.
Wow, thanks for the info. I really disagree with this change. I made a special post about it.
viewtopic.php?f=66&t=140045&p=928358#p928358
