adamomg
Accessing VNC over the Internet
Tue Jun 04, 2013 3:30 pm
As I understand it, you have to tunnel over SSH to get VNC working from outside of your local network.
I have followed the steps from a previous topic (http://www.raspberrypi.org/phpBB3/viewt ... 63&t=24378) but I am unable to get it to work. That and the user that was requesting help didn't seem to be using a default setup.
I have a default setup of tightvnc installed on my Raspberry Pi - Model B following these directions: http://myraspberrypiexperience.blogspot ... p-vnc.html
SSH is working
VNC is working on my Raspberry Pi on my local network using 192.168.1.136:1
I have DD-WRT on my router. I have port forwarded my other Windows systems to be accessed over the internet through VNC so the router isn't the issue.
Can someone point me in the right direction?
Piminiuser
Re: Accessing VNC over the Internet
Wed Jun 05, 2013 6:00 am
Basic setup.
Install VNC server on Raspberry pi
VNC Port forward on your router/modem: Your tutorial uses port "1"? Forward port 1 to your raspberry pi internal IP adres (192.168.1.136)
http://www.dd-wrt.com/wiki/index.php/Port_Forwarding
Application:VLC
Start port: 1
End port: 1
Protocol: Both for the first time, i dont know VNC use TCP or UDP for default.
Ip adress: INTERNAL ip adres of your raspberry pi
Then go to -> http://www.whatsmyip.org/ And copy your ip adres(PUBLIC) ip adres. your should connect now to EXTERNALIPADRES:1
I also made a own VNC tutorial: http://raspberrypihelp.net/tutorials/18 ... vnc-server
ghans
Wed Jun 05, 2013 6:32 am
The number :1 refers to the VNC display , which maps
to port 5901 , :2 maps to 5902 etc.
ghans
