mlbaker
change ssh port
Tue Oct 08, 2013 4:21 pm
Hi all,
I'd like to move ssh to a different port. For some reason I'm having trouble doing this... I ran
sudo vim.tiny /etc/ssh/ssh_config
and changed this line
#   Port 22
to this line
   Port 2122
then I ran the following to restart the ssh service
sudo service ssh restart
finally I tried to connect to my box on the new port and it does not work. The old port still works. When I run netstat it no changes have taken effect.
mlbaker@raspberrypi ~ $ netstat -tnl | grep 22
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
mlbaker@raspberrypi ~ $ netstat -tnl | grep 2122
I've tried restarting and that does not fix it. I've edited the file again and confirmed that my changes are there. I'm running 2013-09-25-wheezy-raspbian.zip.
Other possibly relevant information. I installed and removed fail2ban. Thank you for any suggestions.
Re: change ssh port
Tue Oct 08, 2013 6:36 pm
You need to change /etc/ssh/sshd_config which is the config file for the ssh server, not /etc/ssh_config which is the client config. Then restart ssh.
mlbaker
Re: change ssh port
Wed Oct 09, 2013 1:58 am
Haha! Changing that file worked. Thank you very much.
anita2r
Re: change ssh port
Sun Oct 13, 2013 10:00 pm
Just as an aside:
If you change the port in the /etc/ssh/ssh_config file it allows you to connect to remote machines that use a non-standard port without using the -p parameter every time.
I have several machines that have the port set to 666 in their /etc/ssh/sshd_config files
and my laptop which communicates with all of them has the same port number setup in the /etc/ssh/ssh_config file
Now I can just use ssh machinename instead of ssh -p 666 machinename
Joe Schmoe
Re: change ssh port
Sun Oct 13, 2013 10:08 pm
All of which means that the OP should change it back in ssh_config, pronto!
Or else ssh will stop working on most sites...
anita2r
Re: change ssh port
Mon Oct 14, 2013 1:20 pm
It all depends on your use of ssh.
If you connect to sites using the standard port, more than your own sites using the non-standard port, then of course set it back, but if you only or mainly connect to sites using a non-standard port then changing the port in the local machine's ssh_config is useful.
In the case of the OP, it looks like the change in the ssh_config file was on the remote (ssh host) machine, so unlikely to be a problem.
Regards
confuseling
Re: change ssh port
Mon Oct 14, 2013 1:31 pm
You can specify it per host, if you like.
http://nerderati.com/2011/03/simplify-y ... nfig-file/
http://forums.debian.net
anita2r
Re: change ssh port
Mon Oct 14, 2013 2:40 pm
confuseling - thanks for posting that link - really useful
