jdolecki
Contact: YouTube
displaying temp sensor on LCD
Mon Sep 20, 2021 2:42 am
I'm trying to display 1wire temp sensor data on my LCD.
For temp sensor I'm using the W1Thermsensor libary
For the LCD I'm using the I2C lcd driver
The print (temperature_in_celsius) will display the temp
When i try to send it to the lcd is were the trouble is??
help or suggestions would be grateful.
Thanks John
import I2C_LCD_driver
from time import *
from w1thermsensor import W1ThermSensor
mylcd = I2C_LCD_driver.lcd()
sensor= W1ThermSensor (sensor_id="062017f57999")
temperature_in_celsius = sensor.get_temperature()
mylcd.lcd_display_string(temperature_in_celsius)
B.Goode
Re: displaying temp sensor on LCD
Mon Sep 20, 2021 6:59 am
Thanks John
from time import *
"help or suggestions would be grateful. "
Check the API documentation for the w1thermsensor and I2C_LCD_driver library modules you have installed. (You don't say where you found them.)
It seems likely that the function W1ThermSensor.get_temperature() will return a Number, while the function I2C_LCD_driver.lcd().lcd_display_string() will almost certainly expect to display a String?
Try converting temperature_in_celsius to a string prior to displaying it.
pcmanbob
Tue Sep 21, 2021 8:11 am
Use " str " to convert your number to a string , most if not all LCD drivers required the information to be displayed to be in the for of text.
like this
from time import *
display_temperature = str(temperature_in_celsius)
mylcd.lcd_display_string(display_temperature)
