paulv
Yet Another Rotary Encoder Solution (Python)
Mon Nov 23, 2015 11:17 am
For a new project, I needed some Rotary Encoders, and to also reduce some conventional hardware, I used PICAXE chips. (Yeah, blasphemy on this Forum, I know) It took me a surprisingly long time to find a solution that worked for me in that environment. Eventually I selected an "early detection" solution and wrote a post on the PICAXE forum to explain my endeavors.
With a lot of knowledge and even more confidence, I then wanted to "port" that rather simple solution to the Raspberry Pi, but boy, was I wrong! It didn't work at all. So, for the same reasons that many solutions do not work on the PICAXE, many also do not work well on the Pi.
I have to admit that I'm adamant in using Python, instead of C, and also for using the RPi.GPIO library. That didn't help me, but my assumption is that there are more like me (in a way anyway).
So, working from the same methodology, the "early detection" method, I finally was able to finish a Python program that works pretty reliably.
The code is explained the best I could, so you should have no problems following it, or modifying it for your own application.
#!/usr/bin/python
# FileName:     Rotary_Encoder-1a.py
# Purpose:      This program decodes a rotary encoder switch.
# Note:         All dates are in European format DD-MM-YY[YY]
# Author:       Paul Versteeg
# Created:      23-Nov-2015
#    This program is free software: you can redistribute it and/or modify
#    it under the terms of the GNU General Public License as published by
#    the Free Software Foundation, either version 3 of the License, or
#    (at your option) any later version.
#    This program is distributed in the hope that it will be useful,
#    but WITHOUT ANY WARRANTY; without even the implied warranty of
#    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#    GNU General Public License for more details.
#    You should have received a copy of the GNU General Public License
#    along with this program.  If not, see <http://www.gnu.org/licenses/>
import RPi.GPIO as GPIO
from time import sleep
# Global constants & variables
# Constants
__author__ = 'Paul Versteeg'
counter = 10  # starting point for the running directional counter
# GPIO Ports
Enc_A = 23  # Encoder input A: input GPIO 23 (active high)
Enc_B = 24  # Encoder input B: input GPIO 24 (active high)
def init():
    Initializes a number of settings and prepares the environment
    before we start the main program.
    print "Rotary Encoder Test Program"
    GPIO.setwarnings(True)
    # Use the Raspberry Pi BCM pins
    GPIO.setmode(GPIO.BCM)
    # define the Encoder switch inputs
    GPIO.setup(Enc_A, GPIO.IN) # pull-ups are too weak, they introduce noise
    GPIO.setup(Enc_B, GPIO.IN)
    # setup an event detection thread for the A encoder switch
    GPIO.add_event_detect(Enc_A, GPIO.RISING, callback=rotation_decode, bouncetime=2) # bouncetime in mSec
    return
def rotation_decode(Enc_A):
    This function decodes the direction of a rotary encoder and in- or
    decrements a counter.
    The code works from the "early detection" principle that when turning the
    encoder clockwise, the A-switch gets activated before the B-switch.
    When the encoder is rotated anti-clockwise, the B-switch gets activated
    before the A-switch. The timing is depending on the mechanical design of
    the switch, and the rotational speed of the knob.
    This function gets activated when the A-switch goes high. The code then
    looks at the level of the B-switch. If the B switch is (still) low, then
    the direction must be clockwise. If the B input is (still) high, the
    direction must be anti-clockwise.
    All other conditions (both high, both low or A=0 and B=1) are filtered out.
    To complete the click-cycle, after the direction has been determined, the
    code waits for the full cycle (from indent to indent) to finish.
    global counter
    sleep(0.002) # extra 2 mSec de-bounce time
    # read both of the switches
    Switch_A = GPIO.input(Enc_A)
    Switch_B = GPIO.input(Enc_B)
    if (Switch_A == 1) and (Switch_B == 0) : # A then B ->
        counter += 1
        print "direction -> ", counter
        # at this point, B may still need to go high, wait for it
        while Switch_B == 0:
        # now wait for B to drop to end the click cycle
        while Switch_B == 1:
        return
    elif (Switch_A == 1) and (Switch_B == 1): # B then A <-
        counter -= 1
        print "direction <- ", counter
         # A is already high, wait for A to drop to end the click cycle
        while Switch_A == 1:
        return
    else: # discard all other combinations
        return
def main():
    The main routine.
    try:
        init()
        while True :
            # wait for an encoder click
            sleep(1)
    except KeyboardInterrupt: # Ctrl-C to terminate the program
        GPIO.cleanup()
if __name__ == '__main__':
    main()
Here is the schematic of the encoder with some de-bouncing hardware.
[edit] the caps are 100nF. Better de-bounce timing. I used a "classic" B, standard stock, latest f/w
Enjoy!
hrvoje
Re: Yet Another Rotary Encoder Solution (Python)
Tue Mar 15, 2016 11:02 am
Hi Paulv,
I have seen that you fought with same problem as I did, if you want you can check my solution - maybe it can help you.
Regards,
Hrvoje
viewtopic.php?f=37&t=140250
paulv
Tue Mar 15, 2016 6:29 pm
I did, nice solution!
Thanks for posting.
dannyh914
Tue Aug 23, 2016 2:23 am
Hey Paulv,
Your post was exactly what I was looking for! Thanks for the help! One question, how would you add a button to the code?
paulv
Tue Aug 23, 2016 7:28 pm
Hi Danny,
Glad you like it.
If you want to add a button, I suggest you have a look at the following post, because depending on your application and environment, adding a simple button seems easy enough, but can be frustratingly difficult. viewtopic.php?f=29&t=133740
Success!
neteng
Mon Sep 19, 2016 6:38 am
Hi paulv,
You mention in the codes that the pullups are weak??...What does this mean???...Does it mean that I will get unstable count values if I use the pull up feature???
Thanks,
neteng
paulv
Mon Sep 19, 2016 9:14 am
Well, you need to remember that the RPi GPIO pull-ups are only about 50K Ohms.
They were most likely designed for CMOS applications and the likes, not for hobbyists.
For an exercise, calculate the current that flows from a 3.3V supply.
You need to be aware of this limitation (a very meager pull-up/down) if you use it to create an R/C filter for button or switch bounce noise. You also need to be aware of tha fact that a GPIO pull may not be in the state you want when the RPi powers up. Therefore it is generally safer/better/more reliable/intuitive to use a "real" resistor of something like 1K. This value still protects the input port if you accidentally set it to output with a low.
If you know what you're doing you're OK.
That is what I wanted to point out.
Success!
neteng
Sun Sep 25, 2016 11:32 pm
So what you are saying paulv, I should externally pull up my encoder output with 1k resistors???......
paulv
Mon Sep 26, 2016 4:26 am
If you follow my hardware example and software design for the rotary switch, you need 10K pull-downs. Look at the diagram in the first post of this topic.
I used 10K pull-down resistors in this application, because that is the value needed for the optimum de-bounce in combination with the capacitor value and the series resistor.
The 1K value for a pull (up or down) I referred to earlier was used in general terms.
OK?
DimpiM
Sat Feb 22, 2020 11:01 pm
Hi everybody,
I know, this is a post from 2015 but the problem still exists.
After a long search at google, everyone tell me, this kind of solution is good (https://github.com/martinohanlon/KY040/ ... 0/KY040.py or I should poll the inputs.
Finally I found this post... Thanks paulv, regarding to your solution I made my own.
I have a KY040 like this (https://www.handsontec.com/dataspecs/mo ... ncoder.pdf). Here a 10k pullup resistor is already on switch A & B.
I dont want to write a long text... Check my solution and fell free to use it ;)
import time
class KY040:
    ROTARY_DEBOUNCE = 2
    SWITCH_DEBOUNCE = 200
    BREAK_COUNTER = 199999
    def __init__(self, clockPin, dataPin, switchPin, rotaryCallback, switchCallback):
        #persist values
        self.clockPin = clockPin
        self.dataPin = dataPin
        self.switchPin = switchPin
        self.rotaryCallback = rotaryCallback
        self.switchCallback = switchCallback
        #setup pins
        GPIO.setup(clockPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        GPIO.setup(dataPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        GPIO.setup(switchPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    def start(self):
        GPIO.add_event_detect(self.clockPin, GPIO.FALLING, callback=self._clockCallback, bouncetime=self.ROTARY_DEBOUNCE)
        GPIO.add_event_detect(self.dataPin, GPIO.FALLING, callback=self._dataCallback, bouncetime=self.ROTARY_DEBOUNCE)
        GPIO.add_event_detect(self.switchPin, GPIO.FALLING, callback=self._switchCallback, bouncetime=self.SWITCH_DEBOUNCE)
    def stop(self):
        GPIO.remove_event_detect(self.clockPin)
		GPIO.remove_event_detect(self.dataPin)
        GPIO.remove_event_detect(self.switchPin)
    def _clockCallback(self, pin):
        Switch_A = GPIO.input(self.clockPin)
        Switch_B = GPIO.input(self.dataPin)
        if (Switch_A == 0) and (Switch_B == 1):
            if(not self.waitForRotaryState(0, 0)):
                return
            if(not self.waitForRotaryState(1, 1)):
                return
            self.rotaryCallback(1)
    def _dataCallback(self, pin):
        breakCounter = self.BREAK_COUNTER
        if (Switch_A == 1) and (Switch_B == 0):
                return
                return
            self.rotaryCallback(0)
    def waitForRotaryState(self, switch_A, switch_B):
        while Switch_A == (not switch_A) or Switch_B == (not switch_B):
            breakCounter = breakCounter - 1
            if(breakCounter <= 0):
                return False
        return True
    def _switchCallback(self, pin):
        self.switchCallback()
Thanks a lot
Ted Toad
Mon Oct 19, 2020 2:47 am
Found this code and it is great, thanks. Just one problem that you may have a solution for, in my application there are four encoders that can be turned one at a time. With your code, turning one encoder works exactly as designed, however, the event_detect thread stops at one of the detection points within the thread. Then when you turn another encoder, nothing happens since (I think) the other thread is still active and the new event_detect won't run. This proves out when you turn the first one again and the second is allowed to process once.
So is there any way to terminate that first encoders thread and start a new one?
Sorry if I'm misunderstanding how these event_detect threads work, have not used them before.
paulv
Tue Oct 20, 2020 10:52 am
Ted,
I have never used more than one, so unfortunately, I can't help you.
The RPi.GPIO library is known to have issues, some of them have been around for years and never been addressed.
What I would investigate if I were you, is the use the pigpio library, which is a much better and still maintained library.
http://abyz.me.uk/rpi/pigpio/index.html It has specific support for rotary decoders.
Success!
