. 2 Smart Tracker BBD100-A10
. 2 Smart Temperature & Humidity Sensor BBW200-A1
. 1 Smart LED Color Bulb BBL227-A1
As there is no binding for BeeWi I started with the beewibulb script from Stephanie Maks viewtopic.php?f=37&t=117729 with the update from Gerrit Hannaert and got that running.
Next I wanted to get the information from the BeeWi 'BBW200 - Smart Temperature & Humidity Sensor'
This script reads the actual temperature, humidity, battery status and the device information. The historical data is not handled yet.
Future step would be to create a rule in OpenHab using the knowledge gathered.
Some output of the script:
pi@raspberrypi:~ $ sudo ./beewiclim.py
Correct usage is "[sudo] beewiclim.py <device address> <command> [hci device]"
<device address> in the format XX:XX:XX:XX:XX:XX
Commands: stat - Get status
Commands: val - Get values (temperature, humidity, battery)
Commands: raw - Get values (temperature, humidity, battery)
[hci device] i.e. hci1 in case of multiple devices
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' stat
Device name = BeeWi SmartClim 1
Model number = BeeWi BBW200
Serial number =
Firmware revision = V1.5 R140514
Hardware revision = 1.0
Software revision =
Manufacturer = Voxland
Temperature = 19.5℃
Humidity = 25%
Battery = 97%
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' val
Temperature = 19.5℃
Humidity = 25%
Battery = 97%
pi@raspberrypi:~ $ sudo ./beewiclim.py 5C:31:3E:XX:XX:XX' raw
19.5 25 97
#!/usr/bin/env python2.7
# A python script to read actual vales from the BeeWi 'BBW200 - Smart Temperature & Humidity Sensor'
# BeeWi website: http://www.bee-wi.com/en.cfm
# Missing: Read the historical temperature & humidity data (0x0039)
# Tested on elelentary OS elementary OS 0.3.2 Freya >> BLE hardware: Broadcom Corp. BCM2045B (BDC-2.1) USB dongle
# Tested on Raspberry 3
# Don't kill me for the source, it's the first time I did something in Python.
# Script based on the beewibulb.py script by Stephanie Maks >> Controlling a BeeWi SmartLite
# https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=117729
# Used the modicications of Gerrit Hannaert
# Some fiddling with the bluetooth packet capture on Android, Wireshark, hcitool, hciconfig, GATTTool, apktool and testing, testing, testing.....
# Many thanks to Stephanie Maks & Gerrit Hannaert
# Stephanie Maks figured out with help from -- and thanks to -- the following sources:
# http://stackoverflow.com/questions/24853597/ble-gatttool-cannot-connect-even-though-device-is-discoverable-with-hcitool-lesc
# http://mike.saunby.net/2013/04/raspberry-pi-and-ti-cc2541-sensortag.html
# https://github.com/sandeepmistry/node-yeelight-blue
# https://www.nowsecure.com/blog/2014/02/07/bluetooth-packet-capture-on-android-4-4/
# note: this needs to be called with 'sudo' or by root in order to work with some of the hci commands
import os
import sys
from subprocess import call, check_output
import time
def cycleHCI(s_hci) :
# maybe a useless time waster but it makes sure our hci is starting fresh and clean
# nope in fact we need to call this before each time we do hci or gatt stuff or it doesn't work
call(['hciconfig', 's_hci', 'down'])
time.sleep(0.1)
call(['hciconfig', 's_hci', 'up'])
time.sleep(0.1)
def getResultStringForDeviceMacHandle(s_hci, s_mac, s_handle) :
# Read the string from handle
raw_input = check_output(['gatttool', '-i', s_hci, '-b', s_mac, '--char-read', '--handle='+s_handle]);
result_string = ''
if ':' in raw_input:
raw_list=raw_input.split(':')
raw_data=raw_list[1]
raw_data=raw_data.strip()
octet_list=raw_data.split(' ')
for octet in octet_list :
j = int(octet, 16)
if j > 31 and j < 127 : result_string += str(unichr(j))
return result_string
def getActualValues(s_hci, s_mac) :
# read the value characteristic (read handle is 0x003f)
# handle returns 10 byte hex block containing temperature, humidity and batery level
# the temperature consists of 3 bytes
# Posivive value: byte 1 & 2 present the tenfold of the temperature
# Negative value: byte 2 - byte 3 present the tenfold of the temperature
raw_input = check_output(['gatttool', '-i', s_hci, '-b', s_mac, '--char-read', '--handle=0x003f']);
raw_list = raw_input.split(':')
raw_data = raw_list[1]
raw_data = raw_data.strip()
octet_list = raw_data.split(' ')
t0 = int(octet_list[0], 16)
t1 = int(octet_list[1], 16)
t2 = int(octet_list[2], 16)
if t2 == 255:
temperature = (t1-t2)/10.0
else:
temperature = ((t0*255)+t1)/10.0
humidity = int(octet_list[4], 16)
battery = int(octet_list[9], 16)
return (temperature, humidity, battery)
def getDeviceInfo(s_hci, s_mac) :
# BeeWi Smart Climate handles
# 0x0003 : SmartClim name : 'Smart Clim'
# 0x001b : model number : 'BeeWi BBW200\00'
# 0x001d : serial number : '\00'
# 0x001f : firmware revision : 'V1.5 R140514\00'
# 0x0021 : hardware revision : '1.0\00'
# 0x0023 : software revision : '\00'
# 0x0025 : manufacturer : 'Voxland\00'
Name = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0003')
ModelNumber = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001b')
SerialNumber = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001d')
FirmwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x001f')
HardwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0021')
SoftwareRevision = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0023')
Manufacturer = getResultStringForDeviceMacHandle(s_hci, s_mac, '0x0025')
return (Name, ModelNumber, SerialNumber, FirmwareRevision, HardwareRevision, SoftwareRevision, Manufacturer)
def printHelp() :
print 'Correct usage is "[sudo] beewiclim.py <device address> <command> [argument]"'
print ' <device address> in the format XX:XX:XX:XX:XX:XX'
print ' Commands: stat - Get status'
print ' Commands: val - Get values (temperature, humidity, battery)'
print ' Commands: raw - Get values (temperature, humidity, battery)'
print ' [hci device] i.e. hci1 in case of multiple devices'
print ''
if __name__=='__main__' :
if os.geteuid() != 0 :
print 'WARNING: This script may not work correctly without sudo / root. Sorry.'
if len(sys.argv) < 3 :
printHelp()
else :
hci_device = 'hci0' # default
device_address = sys.argv[1]
command = sys.argv[2]
command = command.lower()
error = ''
if len(sys.argv) == 4 : hci_device = sys.argv[3]
hci_device = hci_device.lower()
# address shortcuts
if device_address == 'sc1' : device_address = '5C:31:3E:XX:XX:XX'
if device_address == 'sc2' : device_address = 'D0:5F:B8:XX:XX:XX'
if len(device_address) != 17 :
print 'ERROR: device address must be in the format NN:NN:NN:NN:NN:NN'
exit()
if 'stat' in command :
name, model, serial, frevision, hrevision, srevision, manufacturer = getDeviceInfo(hci_device, device_address)
temperature, humidity, battery = getActualValues(hci_device, device_address)
print '-------------------------------------'
print 'Device name = ' + name
print 'Model number = ' + model
print 'Serial number = ' + serial
print 'Firmware revision = ' + frevision
print 'Hardware revision = ' + hrevision
print 'Software revision = ' + srevision
print 'Manufaturer = ' + manufacturer
print 'Temperature = ' + str(temperature) + u'\u2103'.encode("utf8") # encode("utf8") needed on raspberry
print 'Humidity = ' + str(humidity) + '%'
print 'Battery = ' + str(battery) + '%'
if 'val' in command :
if 'raw' in command :
print str(temperature),str(humidity),str(battery)
if error != '' :
if error == 'off' : error = 'ERROR: SmartClim ' + device_address
print error
exit()
Update for negative temperatures and positive values over 25.5 degrees Celcius
Busy on pulling the historical data (temperature & humidity), having some troebles translating the data into values.
And sorry for the language mistakes, English is not my native language
Cheers!
