Based on the brilliant work on the **** project, I decided to use the fractional divider to control remote power switches operating at 433.92 MHz. A long story short; it worked! As of now it is limited to controlling Nexa-remotes (which is commonly available at least here in Scandinavia).
Source code, compiled binary and instructions: http://www.skagmo.com/page.php?p=projects/22_pihat
Re: PiHAT - Rasberry Pi Home Automation Transmitter
so the pi could turn itself off?
Nice! Other stuff worth reading too! I really like your groundstation.
While you can, I don't really see why you would do that.pygmy_giant wrote:so the pi could turn itself off?
The wireless power switches can be used for anything: A lamp, an oven etc.
Thanks!cyrano wrote:Nice! Other stuff worth reading too! I really like your groundstation.
- Location: Italy, not my fault, I wasn't able to deceide where to born
Nice hack Skagmo!
Sadly I don't have any Nexa-remote but I'm trying to play with some similar items.
At this point I'm guessing is there any way to READ 433 MHz signal in a similar way?
Thank you!leonardo wrote:Nice hack Skagmo!
RF-reception is not that easy to achieve, and a (bad) ASK-receiver would require 4-5 components at least.
Yes, I find the answer trying to read the code. If I'm not wrong, you create something similar a oscillator at 433MHz without having the oscillator! That's possible to "send" signals, but to receive we must have all the circuit!
I thought maybe it could be useful if you had to leave the Pi running for a long indeterminate ammount of time and wanted it to power down afterwards.by skagmo » 24 Dec 2012 10:49While you can, I don't really see why you would do that.pygmy_giant wrote:so the pi could turn itself off?
I had this situation a few months ago when I was calculating permutations - I new it was going to take a long time (over 24 hours) but I did not know how long, and I wanted to get on with my life without leaving appliances switched on unnecessarily.
Impressive work by the way.
Yup, much easier to build an rf transmitter paired with a RF-enabled socket than script "shutdown -h now "pygmy_giant wrote: I thought maybe it could be useful if you had to leave the Pi running for a long indeterminate ammount of time and wanted it to power down afterwards..
This looks very interesting. I might look into it with some RF sockets I have. No idea yet what frequency they run on, or what signal they require, but they do have a similar "long press" for pairing system to pair with the remote.skagmo wrote:Based on the brilliant work on the **** project, I decided to use the fractional divider to control remote power switches operating at 433.92 MHz. A long story short; it worked! As of now it is limited to controlling Nexa-remotes (which is commonly available at least here in Scandinavia).
I've successfully utilised rfxtrx433 to communicate with such devices. It provides a usb-serial interface, which is relatively simple to code with perl and supports a bunch of various protocols.
I've tried it with my "Status" Remote Sockets. They too run on 433.92MHz but it doesn't seem to work.skagmo wrote:Based on the brilliant work on the project, I decided to use the fractional divider to control remote power switches operating at 433.92 MHz. A long story short; it worked! As of now it is limited to controlling Nexa-remotes (which is commonly available at least here in Scandinavia).
I've got a socket which is "1" on my remote and I've tried...
sudo ./pihat --id=1 --channel=0 --state=0
sudo ./pihat --id=1 --channel=1 --state=0
sudo ./pihat --id=1 --channel=2 --state=0
sudo ./pihat --id=1 --channel=3 --state=0
sudo ./pihat --id=1 --channel=4 --state=0
sudo ./pihat --id=1 --channel=5 --state=0
sudo ./pihat --id=1 --channel=6 --state=0
sudo ./pihat --id=1 --channel=7 --state=0
sudo ./pihat --id=1 --channel=8 --state=0
sudo ./pihat --id=1 --channel=9 --state=0
sudo ./pihat --id=1 --channel=10 --state=0
sudo ./pihat --id=1 --channel=11 --state=0
sudo ./pihat --id=1 --channel=12 --state=0
sudo ./pihat --id=1 --channel=13 --state=0
sudo ./pihat --id=1 --channel=14 --state=0
sudo ./pihat --id=1 --channel=15 --state=0
This thread might be helpful....
http://www.picaxeforum.co.uk/showthread ... 850d92f87e
More so this post.....
Decoding the RCT-08 remote using a standard 433MHz receiver module and 20X2
Typical output ...
0001 <0110 0000 0111 1011> <1000> 0 Remote=$607B All Off
0001 <0110 0000 0111 1011> <1111> 0 Remote=$607B 1 On
0001 <0110 0000 0111 1011> <0111> 0 Remote=$607B 1 Off
0001 <0011 1110 1111 0000> <1000> 0 Remote=$3EF0 All Off
@ant_thomas
Can you download 20X2-Morissons.txt and 20X2-Morrisons-Tx.txt? I don't have permissions to download them.
It does seem to be easy to implement the status remote protocol according to the link you posted, unless there are preamle and postamble like nexa remote.
I will try to write something in a few days time.
I did some quick code and you can download the modified version (for status remote) here
https://github.com/s7mx1/pihat/raw/master/pihat
Usage is here
I have not tested it personally so it may or may not work and I am not responsible for any damage it may cause.
Usage is here
Thanks for these, I'll give them a go later.s7mx1 wrote:I did some quick code and you can download the modified version (for status remote) here
Usage is here
The Status remotes are a fairly common cheap remote socket in the UK so if the program does work with them you might have some very happy users on here!
I wanted to provide those .txt files from the other forum but I'm still waiting for my account to be approved so I can access the attachments. Once it is I'll get them to you.
I just downloaded the binary and it won't run: -bash: ./pihat: cannot execute binary file according to "file" it appears to be an x86 not ARM executable.s7mx1 wrote:I did some quick code and you can download the modified version (for status remote) here
Usage is here
root@raspberrypi:~# file pihat
pihat: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0xf6401296fea2f19fcf49bd0830125d15ce6804c1, stripped
Am I doing something wrong here??
Richard S.
It didn't work for me either. So didredhawk wrote:I just downloaded the binary and it won't run: -bash: ./pihat: cannot execute binary file according to "file" it appears to be an x86 not ARM executable.
Richard S.
git clone https://github.com/s7mx1/pihat.git
cd pihat
make
then ./pihat --id=0 --channel=7 --state=0
but it didn't turn anything on or off. I'm going to try a couple of other things first!
...edit - tried to pair and that hasn't worked either
Got the files....
https://dl.dropbox.com/u/14641356/rpi/2 ... issons.txt
https://dl.dropbox.com/u/14641356/rpi/2 ... ons-Tx.txt
Edit - I think this line...
Symbol ON_5 = %1110
Should be
Symbol ON_4 = %1110
#Picaxe 20X2
#No_Table
#No_Data
#Terminal 38400
Symbol DATA_PIN = pinB.0 ' HINT1 - Received from 433MHz module
Symbol dataStream.lsw = w0 ' b1:b0
Symbol dataStream.msw = w1 ' b3:b2
Symbol dataLast.lsw = w2 ' b5:b4
Symbol dataLast.msw = w3 ' b7:b6
Symbol dataAvailable = b8
Symbol hexBits = b9
SetFreq M32
HIntSetup %00100010
Do
Gosub InterruptEnable
Do
dataAvailable = 1
Pause 12 ' 3ms @ 32MHz
Loop Until dataAvailable = 1
dataStream.msw = 0
dataStream.lsw = 0
Do
Do
dataAvailable = 1
Loop until dataStream.lsw > 1
SetIntFlags OFF
If bit24=0 And bit23=0 And bit22=0 And bit21=1 And bit0=0 Then
If dataStream.msw = dataLast.msw And dataStream.lsw = dataLast.lsw Then
SerTxd( #bit24, #bit23, #bit22, #bit21, " <" )
SerTxd( #bit20, #bit19, #bit18, #bit17, " " )
SerTxd( #bit16, #bit15, #bit14, #bit13, " " )
SerTxd( #bit12, #bit11, #bit10, #bit9, " " )
SerTxd( #bit8, #bit7, #bit6, #bit5, "> <" )
SerTxd( #bit4, #bit3, #bit2, #bit1, "> " )
SerTxd( #bit0 )
dataStream.lsw = dataStream.lsw >> 1
bit15 = bit16
SerTxd( 9,"Remote=$" )
hexBits = dataStream.msw >> 1 : Gosub ShowHex
hexBits = dataStream.lsw >> 12 : Gosub ShowHex
hexBits = dataStream.lsw >> 8 : Gosub ShowHex
hexBits = dataStream.lsw >> 4 : Gosub ShowHex
SerTxd( " " )
hexBits = dataStream.lsw & $F
Select Case hexBits
Case %1000 : SerTxd( "All Off" )
Case %0111 : SerTxd( "1 Off" )
Case %1111 : SerTxd( "1 On" )
Case %0011 : SerTxd( "2 Off" )
Case %1011 : SerTxd( "2 On" )
Case %0101 : SerTxd( "3 Off" )
Case %1101 : SerTxd( "3 On" )
Case %0110 : SerTxd( "4 Off" )
Case %1110 : SerTxd( "4 On" )
Else : SerTxd( "?" )
End Select
SerTxd( CR, LF )
End If
End If
dataLast.msw = dataStream.msw
dataLast.lsw = dataStream.lsw
Loop
ShowHex:
hexBits = hexBits & $0F + "0"
If hexBits > "9" Then : hexBits = hexBits + 7 : End If
SerTxd( hexBits )
Return
Interrupt:
PauseUs 90 ' ~300us @ 32MHz
dataStream.msw = dataStream.msw << 1 | bit15
dataStream.lsw = dataStream.lsw << 1 | DATA_PIN
dataAvailable = 0
InterruptEnable:
hInt1Flag = 0
SetIntFlags %00000010, %00000010
Return
#Picaxe 20X2
#No_Table
#No_Data
Symbol TX = C.0
Symbol ALL_OFF = %1000
Symbol OFF_1 = %0111
Symbol ON_1 = %1111
Symbol OFF_2 = %0011
Symbol ON_2 = %1011
Symbol OFF_3 = %0101
Symbol ON_3 = %1101
Symbol OFF_4 = %0110
Symbol ON_5 = %1110
Symbol outputBits.lsw = w0 ' b1:b0
Symbol outputBits.msw = w1 ' b3:b2
Symbol dataStream.lsw = w2 ' b5:b4
Symbol dataStream.msw = w3 ; b7:b6
Symbol shiftData = w4 ' b9:b8
Symbol remoteId = w5 ' b11:b10
Symbol keyPress = b12
Symbol shiftBits = b13
Symbol alignLeftShift = b14
Symbol packetCount = b15
Symbol bitCount = b16
PowerOnReset:
SetFreq M32
Low TX
Goto MainLoop
SendOutputBits:
For bitCount = 0 To 24
If bit24 = 0 Then
High TX
PauseUs 70
Low TX
PauseUs 80
outputBits.msw = outputBits.msw << 1 | bit15
outputBits.lsw = outputBits.lsw << 1
Else
High TX
PauseUs 215
Low TX
End If
Next
Return
MainLoop:
Do
Pause 8000
remoteId = $3EF0
keyPress = ON_1
Gosub SendCommand
Pause 8000
remoteId = $3EF0
keyPress = ON_2
Gosub SendCommand
Pause 8000
remoteId = $3EF0
keyPress = OFF_1
Gosub SendCommand
Pause 8000
remoteId = $3EF0
keyPress = OFF_2
Gosub SendCommand
Loop
SendCommand:
shiftData = %0001
shiftBits = 4
Gosub Shift
shiftData = remoteId
shiftBits = 16
Gosub Shift
shiftData = keyPress
shiftBits = 4
Gosub Shift
shiftData = %0
shiftBits = 1
Gosub Shift
For packetCount = 1 To 10
outputBits.lsw = dataStream.lsw
outputBits.msw = dataStream.msw
Gosub SendOutputBits
Pause 30
Next
Return
Shift:
alignLeftShift = 16 - shiftBits
shiftData = shiftData << alignLeftShift
Do
If dataStream.lsw >= $8000 Then
dataStream.msw = dataStream.msw | 1
End If
If shiftData >= $8000 Then
dataStream.lsw = dataStream.lsw | 1
End If
shiftData = shiftData << 1
shiftBits = shiftBits - 1
Loop While shiftBits > 0
Return
Symbol ON_5 = %1110
Should be
Symbol ON_4 = %1110
There's a fault in the code somewhere it's not accepting the --brand parameter.
A work around: edit main.c goto line 119 and change BRAND_NEXA to BRAND_STATUS
then make and it should work.
Richard S.
Richard S.
Thanks.redhawk wrote:There's a fault in the code somewhere it's not accepting the --brand parameter.
Richard S.
Doesn't seem to work. It's not pairing. Hopefully someone else can try too, might just be me!
I can confirm it does work with Status remote switches (ones sold by Asda in 3 packs).
Do you have an antenna wire attached to "GPIO 4" pin?? without this your TX range is approximately 10cm.
http://elinux.org/RPi_Low-level_periphe ... .28GPIO.29
For the best range at 443.92MHz use an antenna wire of approximately 6 1/2 inches.
Richard S.
Richard S.
I did have a cable plugged in, but unplugged and replugged and it's working now.redhawk wrote:I can confirm it does work with Status remote switches (ones sold by Asda in 3 packs).
Richard S.
Thanks, it's appreciated!
One more question.
Is it possible to find out the id of my actual remote without trying 0-65535?
I was thinking the same thing myself so I'll let you know if I have cracked my remote ID.
The transmitter uses ook encoding (on off keying) so basically you'll have a 443.92MHz carrier for a set duration and then a set duration of no TX carrier.
These pulses can be detected by placing an FM radio next to the remote all you have to do is record the audio and interpret the pulses back to data.
By pressing buttons on the remote and comparing the pulses generated by the Pi application it should be possible to determine the remote control ID.
Richard S.
Richard S.
