GranducatodiToscana
Raspberry 400 and Innomaker DAC
Wed Sep 22, 2021 8:23 pm
I've bought on Amazon a Pi400 GPIO Header expansion for my Raspberry 400:
and i've connect the Innomaker DAC to it:
but i don't obtain any sound out of it. Maybe i connected the hat in the wrong way ?
any suggestions?
Thanks!
ps.I have noticed that the Texas Instruments chip gets very hot when plugged in, very very hot.
Raspberry Pi 400 addicted
HawaiianPi
Re: Raspberry 400 and Innomaker DAC
Wed Sep 22, 2021 9:38 pm
From your pictures you have not connected the DAC properly. It looks skewed to the left and not connected to all pins (could just be the angle and my aging eyes).
LTolledo
Thu Sep 23, 2021 12:17 am
yeah, looks like pin 1 of the DAC landed on pin 3 of the GPIO expansion board...
if after connecting the DAC the right way the TI chip remains unusually hot.... then its time to buy another one...
Some people be like:
GranducatodiToscana
Thu Sep 23, 2021 6:32 am
i think i mounted it correctly on the pin 1 ??????
Cloudcentric
Thu Sep 23, 2021 6:57 am
any suggestions?
Thanks!
Stupid question, but did you plug in the expansion board into the RPi correct orientation ??
GranducatodiToscana
Thu Sep 23, 2021 7:34 am
I've mounted it in the right way (i hope) as seen in the first image
I'm scared that Texas Instruments chip is so hot when i plug in the hat. What's wrong?
LTolledo
Thu Sep 23, 2021 7:58 am
looking at Cloudcentric's image and your image.... you inserted the GPIO extension board the wrong way...
is your RPi still OK?
does it still boot?
if still OK better use a 40-pin ribbon cable (instead of the GPIO extension board)
and try again....
Cloudcentric
Thu Sep 23, 2021 8:11 am
I actually meant into the RPi 400, but if you are convinced that is not the case, please ignore my post :?
https://thepihut.com/products/gpio-ribb ... -pi-2-pi-3
GranducatodiToscana
Thu Sep 23, 2021 8:52 am
I've mounted it in the correct way as seen on product explanation.
Cloudcentric
Thu Sep 23, 2021 10:14 am
I was going by the Raspberry Pi Pin Assignments not what the Amazon Seller shows.
https://www.amazon.com/PI400-GPIO-ADAPT ... B08SKT6FB3
https://www.raspberrypi.org/documentati ... pin-header
Therefore the RPi 400 Pin 1 is 3v3 and Pin 2 is 5V
ame
Thu Sep 23, 2021 10:19 am
In the picture you can see Pin 1 and Pin 40 marked on the Pi 400 plastic case. This does not match the marking on the PCB that you are plugging in.
Therefore it would appear that you have plugged the board in upside down.
GranducatodiToscana
Thu Sep 23, 2021 8:38 pm
does it still boot?
and try again....
Yes my Rpi400 is healty and booting, i've tried to connect directly to gpio connector but the hat has give me no signal of life... However i've ordered a ribbon cable. Thank you
GranducatodiToscana
Thu Sep 23, 2021 8:39 pm
you think i can throw the hat into trash ? i've tried to connect directly to Rpi400 gpio but returned nothing.
GranducatodiToscana
Thu Sep 23, 2021 8:42 pm
I'm not "convinced" but i'm "hoping": i've tried to directly connect the hat to Rpi400 but i've got not signal of life. I 'll try tomorrow with a ribbon cable.... The Rpi400 booting with no problems, but i'm worried about the DAC
trejan
Thu Sep 23, 2021 8:45 pm
It isn't backwards. There are a mass of traces which flip it around. Look closely at the PCB shot on the Amazon page.
ame
Thu Sep 23, 2021 8:49 pm
Crikey. How about that!
GranducatodiToscana
Thu Sep 23, 2021 8:51 pm
i've runned gpiotest on my Rpi400 and the result is this
pi@raspberrypi:~/Desktop/gpio $ sudo pigpiod
pi@raspberrypi:~/Desktop/gpio $ ./gpiotest
This program checks the Pi's (user) gpios.
The program reads and writes all the gpios.  Make sure NOTHING
is connected to the gpios during this test.
The program uses the pigpio daemon which must be running.
To start the daemon use the command sudo pigpiod.
Press the ENTER key to continue or ctrl-C to abort...
Testing...
Skipped non-user gpios: 0 1 28 29 30 31
Tested user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Failed user gpios: None
ame
Thu Sep 23, 2021 8:54 pm
If you are plugging in the hat only, did you plug it in correctly? Pin 1 on the hat is clearly marked, and should align with the Pin 1 marking on the Pi 400.
My original observation was incorrect, and the intermediate board was probably ok. Sorry.
But, if one of the chips is getting hot and you can't get the software working then something is wrong somewhere.
Inno-maker
Fri Sep 24, 2021 3:56 am
Dear,Thank you for choosing innomaker. Could you please share the link of this GPIO Header expansion for me ? The picture is too small to check. I will send the correct plug way to you.
In addition, I attached the DAC pins map for you.
BTW, you said the Texas Instruments chip is very hot, I am afraid that the chip may be destroyed. Please contact to my e-mail calvin@inno-makr.com. I am pleasure to make a replacement for you. Hope you have fun with our DAC module and Raspberry Pi.
DAC PINMAP.png (249.25 KiB) Viewed 533 times
LTolledo
Fri Sep 24, 2021 10:41 am
Wow.... good to know Inno-maker is "in the house" :D
makes it all re-assuring! :D
eby
Fri Sep 24, 2021 6:14 pm
Is it with Ribbon GPIO connector or both ?.
