Found some official info about the chip, maybe it would help some one to help us
TC358743
Features
HDMI-RX Interface
• HDMI 1.4
– Video Formats Support (Up to 1080P)
• RGB, YUV444: 24-bpp@60 fps
• YUV422 24-bpp @60 fps
– Audio Supports
• Internal Audio PLL to track N/CTS value transmitted by
the ACR packet
– 3D support
– Support for HDCP (High-bandwidth Digital Content
Protection)
– Support for DDC (Display Data Channel)
– Support for EDID (Extended Display Identification Data)
• Release A, Revision 1 (Feb 9, 2000)
• First 128 byte (EDID 1.3 structure)
• First E-EDID Extension: 128 bytes of CEA Extension version 3 (specified in CEA-861-D)
• Embedded 1K-byte SRAM (EDID_SRAM) – Maximum HDMI clock speed: 165 MHz
• Does not support Audio Return Path and HDMI Ethernet Channels CSI-2 TX Interface
• MIPI CSI-2 compliant (Version 1.01 Revision 0.04 – 2 April 2009) – Supports up to 4 data lanes
• Supports up to 1 Gbps per data lane – Video, Audio and InfoFrame data can be transmitted I2C Slave Interface
• Support for normal mode (100 KHz), fast mode (400KHz), and ultra fast mode (2 MHz)
• Configure all H2C internal registers Audio Output Interface Either I2 S or TDM Audio interface available (pins are multiplexed) 2S Audio Interface
• Single stereo channel
• Support Master Clock mode only
• Support 16, 18, 20 or 24-bit data (based on HDMI input stream)
• Support for left-justify or right-justify with MSB first TDM (Time Division Multiplexed) Audio Interface
• Single data link
• Up to 2,4,6 or 8 channels (based on HDMI input stream)
• Support 16, 18, 20 or 24-bit PCM audio data word (based on HDMI input stream) InfraRed (IR)
• Support NEC InfraRed protocol Power Supply Inputs
• Core and MIPI D-PHY: 1.2V
• I/O: 1.8V – 3.3V
• HDMI: 3.3V
• APLL: 3.3V/2.5V Package
• TC358743XBG: 64-pin, 6.0 x 6.0 mm, 0.65 mm ball pitch, 1.2 mm height
