raspnik
vlc automatic start at boot up
Tue Sep 11, 2012 12:05 pm
hi,
sorry for the bad english
I need to start automatically VLC player at startup of the raspberry
and must perform a playlist whit VLC
please someone can 'help
thank you very much
stevepdp
Re: vlc automatic start at boot up
Tue Sep 11, 2012 1:47 pm
There are a couple of things to learn here:
1. .desktop files
2. m3u playlists (or another playlist format supported by vlc)
Here's an example which I just put together and tested.
First, make a directory in /home/pi/.config/ called autostart
mkdir /home/pi/.config/autostart
Next, we need to create a .desktop file with the vlc exec instructions, including the location of the playlist.
nano /home/pi/.config/autostart/autovlc.desktop
[Desktop Entry]
Type=Application
Exec=vlc /home/pi/playlist.m3u
Then, we need to populate the playlist file with file locations. Here's the following for example, you'll obviously need to create the correct paths for your music collection.
nano /home/pi/playlist.m3u
/home/pi/music/faith-no-more/the-real-thing/01-from-out-of-nowhere.ogg
/home/pi/music/faith-no-more/the-real-thing/02-epic.ogg
/home/pi/music/faith-no-more/the-real-thing/03-falling-to-pieces.ogg
Restart the desktop and it should run :-)
Hope this helps!
raspnik
Tue Sep 11, 2012 10:37 pm
thanks for the help, I try now and let you know if it works.
raspnik
Wed Sep 12, 2012 10:35 am
hello stevepdp
thank you very much vlc works wonderfully
nik
sgegreen
Tue Sep 18, 2012 1:13 pm
There's a museum application for a Raspbery Pi here that also needs vlc to start at boot.
However it's to play a DVD stored on the SD card and it's too slow without video acceleration.
Does anyone have an accelerated version of vlc, preferably including DVD menu navigation?
ghans
Tue Sep 18, 2012 2:52 pm
There is no such thing available. XBMC has disabled dvdnav entirely,
and omxplayer only works with .vob files. We don't even know how to work
with CSS'ed disks.
ghans
ghans
Tue Sep 18, 2012 5:52 pm
Okay , i take that back :
http://www.raspberrypi.org/phpBB3/viewt ... 35&t=17598
But that's still a work in progress .
ghans
Bob404
Mon Apr 15, 2013 9:28 am
Hi guys!
I've a little question about this way to auto-load VLC: in my Raspberry-pi this procedure don't work, it's probably because my system use autologin function provided with mingetty??? There is a way to make VLC able to autoload on startup an URL (audio streaming) with mingetty?!?
My goal is to automatically load my radio on startup, in order to have my raspberry-pi connected only to an amplifier to check if my radio is running, without needing keyboard, mouse and monitor. Manually everything work properly, but I want to automate the process.
I'm asking too much to my little raspberry? :)
Bob404
Mon Apr 22, 2013 11:16 am
Hi everyone! I've an update! actually, in my case, the auto-load-n-play script seems to work only in desktop enviroment, maybe this procedure was created to do so, but how can I achieve the same goal in the "command line enviroment", without typing "startx"?
Thank you!
Twana94
Tue Mar 18, 2014 2:38 pm
Could this work if I want the raspberry pi to send a stream on the network. In my case I want to use the raspberry as a surveillance camera and watch the stream on a computer elsewhere.
dodger97
Sun Sep 17, 2017 8:14 pm
finally , i tried this a few time in the past ,[novice at best with copying code and editing file ],and to-day it worked :D :o
Biorobot75
Sat Mar 02, 2019 3:00 pm
Hi to all…
I want to automaticly start VLC at startup of my raspberry PI 3b+ but nothing I found on this forum seems to work for me.
I have installed the raspbian sofware with NOOBS ver 2.8.2 and the software works fine. Installed a Subtronics X5000 sound card and this one also works fine. Installed a 7 inch lcd screen and it also works fine. It is verry frustrating that nothing seems to work to get VLC to autostart at startup of my raspberry.
can someone help me with my problem ?
where to put script files to autostart vlc?
greetz Biorobot75
gkaiseril
Sat Mar 02, 2019 4:35 pm
Did you follow the post from stevepdp?
These post are assuming that one is logged in as the 'pi' user. If you are not logged in as 'pi' you will need to change the 'pi' directory to your logged in user id.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
Biorobot75
Fri Apr 12, 2019 5:15 pm
Sorry for my late reply to the above post...
hi gkaiseril,
yes i'm logged in as "pi" user and I followed stevepdp's post aswell as other posts.
maybe I should look for a script-file on my Raspberry PI that is already working and ad a startup command for VLC ?
Minaras
Thu Aug 08, 2019 6:31 am
Is there any way to change the seconds that vlc will start up?
Paddor
Thu Dec 19, 2019 7:04 am
Hello Users, I am also looking for a way to delay the start of the M3U / VLC a bit because my Raspberry is faster than my IP camera.
thank you for your help
