djazz
Re: omxplayer play controls / input
Thu Jan 03, 2013 7:24 pm
Try out omxradio, a web interface for playing webradio, youtube clips and local files on the pi, all controlled from a web interface on mobile/laptop. Written in nodejs and uses some HTML5 features to sync play queue and Now Playing across clients.
More info: https://github.com/daniel-j/omxradio
Demo: https://www.youtube.com/watch?v=HrgPvr6pDV0
Juggler
Fri Jan 11, 2013 10:15 pm
I've managed to create PHP WEB GUI for omxplayer. But I need some help to continue. No matter PHP, Python or javascript.
http://www.raspberrypi.org/phpBB3/viewt ... 7&p=212485
Is it possible to display some text without X using overlay or something similar to add info on the screen?
Is it possible get position or timecode from omxplayer, maybe we can mod it to support some output and draw some text?
gabello
Sat Jan 12, 2013 6:12 pm
Omxradio is a great app, thanks for that. It would be interesting to add a volume up/down on it.
fabiovaz
Sun Mar 03, 2013 5:45 am
Hi all,
Is it possible to play a video using a part of the screen using omxplayer?
Let's say I have a 1920x1080 screen and I want to play a video from the left top corner using on 800x600 window or maybe a centered window.
BR
Fabio.
KenT
Sun Mar 03, 2013 11:14 am
There is a new option in the code on github, not sure it has made its way into the apt_get upgrade repository yet.
--win \"x1 y1 x2 y2\" Set position of video window\n");
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
Gomoto
Tue Mar 12, 2013 9:49 pm
there is a new option to play video with omxplayer in a moveable and resizable window on your desktop:
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=36830
Have fun!
fabiovaz
Tue Mar 12, 2013 10:00 pm
Hi all,
I'm very glad to know that this new feature is already implemented. But I'm not a qualified user so I can get the sources from Github and compile them. Does anyone have a compiled version including this feature ? Or maybe, point me somewhere I can find it already compiled.
Any help would be very, very appreciated.
BR,
Fabio.
KenT
Wed Mar 13, 2013 7:29 am
loydesteve
Tue Dec 10, 2013 4:11 am
Kinda tricky procedure for me, but I was able to fix the pi from its several issue...
Regards,
Loyd
custom iphone cases
dynamitemedia
Sun Jan 26, 2014 11:51 pm
Jim Ford wrote:I'm trying to write a simple bash script for controlling omxplayer from a command line. I'm a rubbish programmer, particularly with bash. This is what I've got so far:
#!/bin/bash
if [ ! -e /tmp/omxplayer.pipe ]
then
        mkfifo /tmp/omxplayer.pipe
fi
( /usr/bin/omxplayer -n -o hdmi $1 < /tmp/omxplayer.pipe & )
echo -n . /tmp/omxplayer.pipe
clear
while true
do
echo p for play/pause
echo q for quit
echo b for back 30
echo B for back 600
echo f for forward 30
echo F for forward 600
echo z for info
echo 1 for slower
echo 2 for faster
echo j for previous audio track
echo k for next audio track
echo + for volume up
echo - for volume down
echo i for previous chapter
echo o for next chapter
echo n for previous subtitle track
echo m for next subtitle track
echo s for toggle subtitles
read inp
clear
case $inp in
        p|z|1|2|j|k|+|-|i|o|n|m|s)
                echo -n $inp > /tmp/omxplayer.pipe
        q)      echo "Quiting"
                echo -n q > /tmp/omxplayer.pipe
                rm /tmp/omxplayer.pipe
                break
        b)      echo -n $'\x1b\x5b\x44' > /tmp/omxplayer.pipe
        B)      echo -n $'\x1b\x5b\x41' > /tmp/omxplayer.pipe
        f)      echo -n $'\x1b\x5b\x43' > /tmp/omxplayer.pipe
        F)      echo -n $'\x1b\x5b\x42' > /tmp/omxplayer.pipe
        *)      echo "Please select from above only"
esac
done
But it doesn't really work as expected.
I'd welcome suggestions , please!
Jim
Did you ever get this working? i am interested in a bash script as well
blockh34d
Fri Feb 28, 2014 6:58 am
http://www.raspberrypi.org/forum/viewto ... 91&t=70459
Here's what I hacked together. It's real basic but it works. Just select one or more media files from nautilus and right click to play. A terminal window opens and shows whats happening, allows for input etc.
I may add flatfile playlists and shufle. Working on a just sslightly nicer python wrapper now. Still text mode, but a little nicer.
lgp_michael
Wed Aug 27, 2014 4:15 pm
I've been looking into this on and off for a while now. I have a media player I wrote myself, and I use omxplayer for the player.
It always bugged me that I needed to either have a keyboard plugged in, or I couldn't control the pi, even with the pipe idea above.
I decided to solve this today and came up with a solution using xbindkeys
It's easy as anything once I worked it out, and now I just have my mouse by my TV not a whole keyboard
I start omxplayer with a script
#!/bin/sh -
\rm /tmp/command_pipe
mkfifo /tmp/command_pipe
xbindkeys
omxplayer -o hdmi $* < /tmp/command_pipe &
PID=$!
echo . > /tmp/command_pipe
wait $PID
killall -9 xbindkeys
This starts up the fifo, and xbindkeys
Inside the ~/.xbindkeysrc file I have
"echo -n p > /tmp/command_pipe"
  b:1
"echo -n q > /tmp/command_pipe"
  b:3
"echo -n ^[[A > /tmp/command_pipe"
  b:4
"echo -n ^[[B > /tmp/command_pipe"
  b:5
"echo -n ^[[D > /tmp/command_pipe"
  b:6
"echo -n ^[[C > /tmp/command_pipe"
  b:7
This allows me to pause, stop, and skip forwards and backwards 10 seconds/10 minutes. Obviously you can simulate any command you like this way.
As a note: The ^[ shown above is a representation of the escape key, so ^[[C represents the three keys ESC then [ then C which simulates the right arrow key
How you enter them is up to you in whatever text editor you use.
Hope this helps!
