brigo
Simple Pi Rack
Sun Feb 24, 2013 7:47 pm
Here is my solution for racking Raspberry Pis, using a block of plyboard
and the audio and video jacks as mounts. This allows simple plugging in and out.
I used a Netgear 8 port switch, and a Plugable USB 3.0 7-Port Hub for power
(which works as long as you don't intent to add further USB devices).
Hope it might be useful to others!
Jb2cool
Re: Simple Pi Rack
Mon Feb 25, 2013 5:11 pm
NIce and neat. Any chance of a pic without the Pi's plugged in.
Cloudcentric
Re: Simple Pi Rack
Mon Feb 25, 2013 5:16 pm
Cool Beans !!!!! :o
dan3008
Re: Simple Pi Rack
Mon Feb 25, 2013 6:43 pm
wow, Set them up to do distebuted computing, and youve got yourself the most amazing pi computer ever :D
nice :D
dan3008 wrote:Pays your money, takes your choice
toxibunny
Re: Simple Pi Rack
Tue Feb 26, 2013 12:19 am
tidy.
SirLagz
Re: Simple Pi Rack
Tue Feb 26, 2013 7:13 am
Looks great :D
Love it.
tonyhughes
Re: Simple Pi Rack
Tue Feb 26, 2013 7:24 am
It appeals to my sense of tidiness and completeness. Well done.
brigo
Re: Simple Pi Rack
Tue Feb 26, 2013 10:06 am
Pictures of the board without the Pis, particularly for Jb2cool.
Various elevations:
brigo
Re: Simple Pi Rack
Tue Feb 26, 2013 10:23 am
More elevations:
The back is not so neat - but, no one will see that:
Tools used, and a little PVA glue, the drill bits are 9mm and 11mm for audio and video, respectively.
A vertical bench drill, would have helped keep the holes true, but I could only use what was at my
disposal.
The biggest problem overall, was obtaining 7 UTP and USB cables all the same length, I ordered
20cm, but didn't always get it.
Jb2cool
Re: Simple Pi Rack
Tue Feb 26, 2013 12:30 pm
Thanks, that is such a nice idea.
TonyD
Re: Simple Pi Rack
Tue Feb 26, 2013 1:13 pm
nice simple idea, I like it :-)
Tony
Nannerman
Re: Simple Pi Rack
Wed Feb 27, 2013 3:31 am
Niceley done. So clean compared to some of the other multi-pi holders.
Probably a dumb question, but what is the advantage of having so many Raspberry Pi's? I've seen lots of pictures of people that have hooked up one (or more) pi to another, but I haven't been able to find a reason to it.
Jb2cool
Re: Simple Pi Rack
Wed Feb 27, 2013 7:33 am
Could be anything from clustered computing to hosting a different service (website, FTP, etc.) on each one. Even something like a classroom environment where each student SSHes to a different Pi.
tonyhughes
Re: Simple Pi Rack
Wed Feb 27, 2013 7:40 am
Nannerman wrote:Niceley done. So clean compared to some of the other multi-pi holders.
I have three Pi's all neatly stacked (in identical, but different coloured cases).
One is an HTTP/IMAP/SMTP/FTP/SSH/stuff server, one is an IRC server, and one is my 'development' unit where I test Baked Raspberry Pi Mod and other things (that one gets re-imaged every few days while I'm testing modules and installing/uninstalling packages and things.
I legitimately still want:
One dedicated to being an IP PBX (Asterisk), one being an XBMC media center, and maybe another one or two for various things.
The low power use of these things is incredible, as is the small size, the fact they are totally silent, and because they are so cheap, it is very viable to have one per task (or set of tasks).
Previously I ran a Sempron 3000+ laptop as my 'server' doing everything, and it had fan noise, and used more power than 10x Raspberry Pi's, and if I borked the system, it took down EVERYTHING. (It wasn't able to run virtualisation to suit my needs).
Love the Pi.
Nannerman
Re: Simple Pi Rack
Thu Feb 28, 2013 1:12 am
Okay, that makes sense. I was overthinking it.
Thanks for explaining it.
brigo
Re: Simple Pi Rack
Thu Feb 28, 2013 9:58 pm
Personally, the Pis are allowing me to experiment with integrating and configurating
a stack of Open Source Application Lifecycle Management (ALM) tools, one instance per
server, in much the same way as done in large industrial scale installations, using
much the same operating systems and toolsets, but at a minute fraction of the costs
in terms of hardware, power, space and other overheads. And, I'm completely at liberty
to pursue the avenues of my choice, without any of the influences I might normally need
to consider.
The Pi is indeed a great learning tool!
I don't have much space, so one of the first challenges was how to neatly group them, after
a number of failed attempts I struct on this one, which neatly fits on half a shelf of my Billy
bookcase, and thought it might just save others some agony.
eedwards86
Re: Simple Pi Rack
Fri Mar 08, 2013 8:42 pm
This is perfect! Been looking for a solution to power 3 raspberry pi's (using http://www.amazon.com/gp/product/B00BGUE4W8).
brigo
Re: Simple Pi Rack
Sat May 04, 2013 8:52 am
The Simple Pi Rack has been redesigned, the network switch and USB powered hub are now underneath, and the Pis are mounted on the HDMI connector. It all now fits neatly on a desk beside other kit, and into a shoe-box (along with PSUs and cables), for easy transporation, without any need for dismantling. See the Simple Pi Rack Mk II at:
http://www.raspberrypi.org/phpBB3/viewt ... 40&t=41669
kuaf
Re: Simple Pi Rack
Sat May 04, 2013 12:49 pm
You mentioned that you used audio and video jack as mount. But I still did not understand how you did fastness to Pi. Could you show more details? Thanks in advance.
brigo
Re: Simple Pi Rack
Mon May 13, 2013 8:03 pm
Apologies for taking so long to reply. I think you probably mean fasten, so perhaps the following picture will help:
Just slot them in to fasten!
However, I now find it simpler and sturdier to use the HDMI connector. It helps reduce the height, makes it easier to get access to the SD card and USB sockets without cables getting in the way, and the edge of the card now rests snugly on the wooden plate:
Using the HDMI socket
mistermocha
Re: Simple Pi Rack
Tue Jul 16, 2013 6:26 am
Isn't it a bad idea to let solder points support the weight of the entire device? Granted, they're not moving around, and there's not much weight there, it just doesn't seem like a good idea to me.
This post went up last year, have there been any problems since?
brigo
Re: Simple Pi Rack
Mon Jul 22, 2013 7:06 am
The solder points seem remarkably robust, and with the expected insertion and removal of
cables, must have been designed to take a fair amount of strain. In this arrangement, and
under normal usage, we can expect only the occassional removal of the ethernet, usb, power or
SD card, and as long as you hold the Pi steady while doing that, I would expect very little
strain on the solder points.
Most of the time the rack of Pis will sit neatly doing what they are asked, and there have
been no problems.
arm2
Re: Simple Pi Rack
Wed Oct 09, 2013 9:35 am
Another powering option is using a PSU with a standard 2.1mm DC connector.
We do adaptor cables and splitter:
http://www.cjemicros.co.uk/products/VAR-2_1MUSB
http://www.cjemicros.co.uk/products/VAR-2_1-4X2_1ADAPT
Chris
brigo
Re: Simple Pi Rack
Tue May 03, 2016 6:59 am
Just to let readers of this forum topic know that the Simple Pi Rack has now been substantially redesigned and incorporates a PSU and relay switch as suggested by BMS Doug (discussed in the topic Simple Pi Rack Mk II), an enclosing case and a number of others features. A new forum topic has been added at: Simple Pi Rack 3.
CryptoKing
Re: Simple Pi Rack
Wed Mar 06, 2019 6:11 pm
I was always interested in doing something like this. I would have to start small and then eventually move into a heated sea-can. But, I am curious about this set up you have here. I am wondering how much you can earn in a 24 hour period with that set up you have in this thread alone. I hope you don't mind me asking, I just want to se if it will be worth it for me. Thanks.
Nelson
CryptoKing
Return to “Other projects”
