nickon314
Emulate a USB keyboard.
Tue Aug 07, 2012 8:08 pm
Is it possible to get a Raspberry Pi to emulate a USB keyboard?
I would like to plug in the raspberry pi in to my PC - and the PC recognise it as a new keyboard.
Then it can be used to send predefined automated keystrokes to the PC.
Is that possible?
Regards
Nick
mahjongg
Re: Emulate a USB keyboard.
Tue Aug 07, 2012 9:58 pm
No, on the RAspberry PI model B the USB hardware is actually connected to a built in Hub, this fixes the USB format as master, there is no way a model B can be a "slave device". Thats said, the SoC of the Raspberry PI is actually capable as being used for both a master and a slave USB device, so theoretically when using a model-A it could be possible to program it to behave as a slave device. Obviously its against the USB specification for a slave device to have a type-A connector, but with some soldering you could connect a type-B or even an USB-on-the-go connector.
Currently it is NOT possible.
redhawk
Tue Aug 07, 2012 10:11 pm
If you need to control your PC from the PI there is always the VNC server / client option.
As for keyboard combinations what exactly did you have in mind??
Richard S.
mahjongg
Tue Aug 07, 2012 10:23 pm
`It may be possible to emulate a PS/2 keyboard (using bit banging on the GPIO pins), then using a "Blue box" PS/2 to USB adapter to connect this "PS/2 keyboard" to a PC.
bredman
Tue Aug 07, 2012 10:42 pm
It is also possible to use the RPi sound port to drive infrared LEDs. This allows the RPi to pretend that it is an infrared wireless keyboard. Some people have reported success using the RPi to control a media server using this method. Try searching this forum for "infrared".
arbuz
Tue Aug 07, 2012 11:36 pm
redhawk wrote:If you need to control your PC from the PI there is always the VNC server / client option.
VNC is only usable when x server is loaded, I would recommend using SSH (you can use it to operate on x11 as well).
nickon314
Wed Aug 08, 2012 9:24 pm
bredman wrote:It is also possible to use the RPi sound port to drive infrared LEDs. This allows the RPi to pretend that it is an infrared wireless keyboard. Some people have reported success using the RPi to control a media server using this method. Try searching this forum for "infrared".
Yes, I have already played with the PWM pins to create an IR transmitter.
But, that was to directly control my Set Top Box.
It worked - but it's not very reliable as the timing of on/off isn't very accurate with Linux.
I also have an Arduino to do this sort of thing and I am sticking with that at the moment as it works everytime.
Regards
Nick
guidol
Thu Aug 09, 2012 6:55 am
nickon314 wrote:Is it possible to get a Raspberry Pi to emulate a USB keyboard?
You can only use a Ardunino Lenoardo as single device or conencted to you RPi to emulate
a USB-Keyboard (and Mouse):
http://arduino.cc/en/Reference/MouseKeyboard
YodaTheCoder
Thu Aug 09, 2012 8:07 am
nickon314 wrote:IThen it can be used to send predefined automated keystrokes to the PC.
If this is just going to be run on a timed basis I'd recommend AutoHotkey and Scheduled Tasks. If you are aiming for remote control then go with the already suggested SSH or VNC.
DexOS
Thu Aug 09, 2012 8:11 pm
Regards
Nick
The problem is linux gets in the way of the timing, to be fair to the PI, go bare metal and it will do anything the arduino can do, plus more.
owen
Wed Jul 31, 2013 11:03 pm
http://www.linuxuser.co.uk/tutorials/em ... spberry-pi
Looks like you can emulate a keyboard over bluetooth, this is a guide for doing it to connect to an android device. But I like the idea of keyboard emulation for PCs so I can do KVM over IP. I wonder if a bluetooth USB device could be pre-paired with this and offer immidiate USB keyboard and mouse input. Then we're just left with dealing with video, and that should be doable on a pi.
For most of the other suggestions here, ask yourself, can they offer KVM access to a BIOS? The one real alternative mentioned was arduino, and while it can handle keyboard/mouse unfortunately it doesn't look like it can handle the video.
GebekovAS
Sun Aug 10, 2014 4:54 pm
Here's an interesting link on the topic https://www.youtube.com/watch?v=Ua_5Uekg4tQ
Fr4gg0r
Mon Oct 13, 2014 4:18 pm
Anyone trying to get this working for the model A?
There are now patches available for certain android devices, https://github.com/pelya/android-keyboard-gadget .
Darlanio
Sat Nov 15, 2014 11:54 am
I would also like to emulate a PS/2 keyboard with my Raspberry pi, preferrably thru a library using bitbanging on the GPIO port and C-program or bash-script that controls what to be sent.
I need both the schematics for the wiring (PS/2 connector - GPIO) aswell as the software for the bitbanging, preferrably open source and downloadable, for a Raspberry PI Model B+.
I would also apprechiate any information on how to emulate a mouse using PS/2 aswell (moving mouse up/down/left/right and mousebuttons).
I am NOT interested in any specific software on the computer to have this keyboard connected to.
Someone wrote that a Raspberry Pi Model A have the hardware to emulate a USB-keyboard but that it was not possible at present. Is it only the software missing, or something else? Information regarding Emulation of a hardware USB-keyboard is welcome. And, no, still not intersted in installing any software on the computer which this "keyboard" will be connected to.
Please reply with all and any information.
pocketvj
Fri Mar 13, 2015 10:32 pm
I'm also interested in a feature like that.
There are some light controllers which you can be controlled with a plugged in PS2 keyboard.
If there would be the availability to simulate such a keyboard with the raspberrypi, I could automate the light show.
Anyone found a solution?
elvsp1n
Sun Jan 31, 2016 6:25 pm
Hi, Guys,
You can buy a cheap usb keyboard and find the wires that each key connect then buy something like an i2c matrix switch that press each key depending on the message sent, in that way with 2 pins of the gpio you should be able to send the same keys.
Cheers,
E
penguinjeff
Thu Feb 04, 2016 10:40 pm
It seems a bit expensive but this looks interesting http://www.hagstromelectronics.com/prod ... km232.html
This should be easier to do. My idea is to use the raspberry pi with a bluetooth keyboard to control a PC before an OS is loaded. Also as a quick way to connect a bluetooth keyboard to a pc without having to pair as the pairing would be done in my device.
tin_yaboku
Fri Feb 05, 2016 12:23 pm
This might be of interest, though this deals exclusively with the Pi Zero as far as I am aware.
https://learn.adafruit.com/turning-your ... t/overview
It's certainly an interesting idea but as of now, it doesn't look like anyone has attempted emulating a keyboard specifically - certainly if I was going to do so, I'd spring for something along the lines of a Teensy.
taupring
Fri Aug 24, 2018 1:56 am
Not sure if anyone is still interested in this, but I found a possible solution. Unfortunately, it's not based on Rasp. Pi, but instead on Arduino ProMicro, and does require a tiny bit of hardware skills (mostly connecting a few short wires or some basic soldering for a more permanent solution). It looks like the latest version of the code even supports "software" pressing of function keys and other non-printable characters.
I can't really use some of the other solutions, as my project involves pressing an F12 key during bootup to enter into pxe-boot. I'm trying to create a fully automated build rack, where brand new 1u servers are slid into shelves on the build rack, connected to power, network, and the "software" keyboard controller, then powered up and every 5 seconds or so the software keyboard controller will send the F12 key until the server pxe-boot's, and then puppet will take it from there.
Here's a link to using the ProMicro for this type of project: https://www.sparkfun.com/tutorials/337
Return to “Other projects”
