Remberry
Re: Modifying a 3.5" car display for USB power.
Thu Nov 23, 2017 10:25 am
BMS Doug wrote:
Mon Sep 04, 2017 1:34 pm
Scionsamurai wrote:
Sat Sep 02, 2017 12:46 am
Thank you for the reply BMS Doug!
I'm not sure if i'm in need of a new(decent) multimeter. I wasn't getting any reading from 1,3,4,5,6, or 8. I was getting in between 3.7 and 4.8 on 2 and 7.
This was when you were feeding it from a 5V supply?
Please connect a 12V supply to the board for testing purposes and tell us the voltage output on pin 3.
Hello everybody,
I have the same board but I am waiting for a new multimeter so I can't do the test.
However, I have better pictures, and we can read on the back VCC33 (lower right). So, is it possible to weld DC_IN wire on it and connect the board on a raspberry's 3.3V pin ? Or it is the wrong way ... I prefer have your assessment before burning something :roll:
There is an extra connectic to weld in the box so I suppose that they allow a modification in the design of the board (the two rounds in the middle?).
Sorry for my english.
Thank you.
Top - Copie.jpg (182.53 KiB) Viewed 1779 times
back - Copie.jpg (87.65 KiB) Viewed 1779 times
George.p
Thu Jan 25, 2018 11:07 pm
Hi
Anyone knows how to get this board to work on 5V? I found some posts but not sure if it works. Thank you guys
AdrianoMoura
Sat Mar 03, 2018 9:16 am
Hello everybody,
Thank you.
I've bought an display and it had the same board, had you figure out how to solve this? I'm trying to find more information but I won't found any tutorial with this kind of board
snazzify
Sun Aug 19, 2018 6:56 am
I followed a guide at Wiring Guide for the 3.5″ GearBest Screen with 5V Mod for my screen.
Return to “Other projects”
