killor
Re: Beta Boards mechanical data
Wed Apr 18, 2012 5:33 pm
Now a seller on ebay has given me this information:
..."Dimension x (ethernet / usb mini usb side to side) 84.81mm
Dimension and (sound / video to hdmi side) 55.92mm
Board is 1.5mm deep
Overall height (from top to bottom of usb connector adapter of sd cardis around 22mm)
ethernet port overhangs by + - 1.5mm
overhangs by port usb2 + - 7.5mm
overhangs by 6.7mm analogue video".....
Wait someone with more confidence  :-((
We have a discount for purchases made in BTC :o
Discount Codes :BitcoinPizzaDay :!:
Gert van Loo
Sat Apr 21, 2012 9:08 pm
Just curious: with all the PIs out there has anybody now checked/verified my measurements?
HansH
Sun Apr 22, 2012 9:44 am
I get from different people different measurements...
85.0 x 56.17  but also  84.9 x 55.9
Not heard yet anybody about the component positions and sizes
killor
Mon Apr 23, 2012 10:27 am
I have a forum member that has an RPI and asked to verify your measurements and I must say are quite accurate,
Bone you've done a good job!
arm2
Mon Apr 23, 2012 2:03 pm
Can someone with a production board please confirm how far the largest component on the underside protrudes?
It is probably the SD card holder but the lugs that hold the USB sockets in place don't look small. I've seen everything from 1.9mm to over 5mm for various brands/models of SD holders.
I would think a vernier gauge would be needed!
HansH
Mon Apr 23, 2012 2:49 pm
My case from thingiverse got printed and I am told it fits perfectly after adapting the pcb width.  The pcb width is reported from 55.9 – 56.19
So far I know nobody changed the component positions, so everything is confirm Gert measurements.
I use 3.5 mm as sd cardholder height...
raspi
Tue Apr 24, 2012 11:13 am
I just designed my Raspberry Pi case and I am going to get a set of 5 made initially. If all proves well I shall produce more if there is a demand for them. There WILL be a 20% donation made to the Raspberry Pi Foundation on any profit.
Please look and comment at: raspi.co.uk
Thank you.
LMWmichael
Wed May 02, 2012 2:06 pm
Hi All
New member, just used the dims here to create a solidworks model of the Pi
if anyone is interested i'll upload it to 3D content central for people to try out
waiting for my Pi to arrive, which should be the end of the month to tidy up dimensions and connector/part positions
feedback greatly appreciated
LMWmichael
Wed May 02, 2012 2:12 pm
sorry about the previous pic, its a bit big try this instead
Lolo34140
Mon May 07, 2012 1:25 am
I'm currently working on the CAO Pi board production dimensions. I near finished to draw and to place all the connectors and parts present on the Pi board.
I will share the dimension as soon as finish on my website : http://freakyshape.com/
cases for the Raspberry Pi available here : http://www.shapeways.com/shops/FreakyShape
Lolo34140
Fri May 18, 2012 12:16 pm
You can download my Raspberry Pi board dimensions here (.STL):
http://freakyshape.com/raspberry-pi-boa ... ical-data/
I hope it will help all those who need this musearements.
eightbit
Fri Sep 14, 2012 12:35 pm
Hi Gert,
can you please renew the drawing with measurements from current production boards, including the mounting holes of the modB rev2 board?
Thanks in advance,
eightbit
Fri Sep 14, 2012 1:38 pm
eightbit wrote:Hi Gert,
Thanks in advance,
eightbit
I'm pretty sure Gert won't have time to do that, but if someone out there with a rev2 would like to oblige...
Gert van Loo
Tue Jan 15, 2013 8:11 am
Done,
very late reply, I know, but it is done now.
jtisdo
Mon Apr 22, 2013 7:32 pm
Gert van Loo wrote:Done,
Gert,
Is that what's in the top section of this post?
I am wondering if you could add the following to it.
Location of the P1, P5 and P6 -- just the Pin 1 location from 0,0
Gert van Loo
Sat Apr 27, 2013 1:22 pm
No I can't do that.
It sounds strange but the reason is simple:
I have provided all measurements using a simple digital caliper.
If I indicate the pin-1 that information is likely to be used in PCB design.
(I think that is also the reason why you asked).
A digital caliper is not accurate enough to provide that data.
I will have to ask the foundation (especially Pete Lomas) for the
Gerber database. From there I can give figures exact enough for PCB design.
I am, not sure they are willing to give that data out.
TonyD
Mon Apr 29, 2013 12:55 pm
Gert, many thanks for updating the drawing.
Any chance someone could post it as a file attachment as scribd is asking for $9 to download it :-(
Tony
Gert van Loo
Mon Apr 29, 2013 5:07 pm
That should be incorrect. I posted it as free.
I will have to look into that.
Gert van Loo
Mon Apr 29, 2013 6:45 pm
TonyD wrote:Gert, many thanks for updating the drawing.
Can anybody confirm this?
It is free to me but then it is also in my account so I can't reliably check this.
rurwin
Mon Apr 29, 2013 9:21 pm
I can confirm it
I clicked the download button on the page...
I skipped the login...
And then I got a payment required page...
Gert van Loo
Mon Apr 29, 2013 10:01 pm
Now that REALLY pisses me off!
I do all the work and somebody else is cashing in on it!
I will take action but sometime tomorrow after I am calmed down and had a good nights sleep.
liz
Tue Apr 30, 2013 12:40 pm
Gert is currently jetlagged and cross, but he'll be sending me a PDF later on today, and I'll get it hosted here instead.
TonyD
Wed May 01, 2013 1:31 pm
Thanks Gert & Liz
Tony
Return to “Other projects”
