Caemron
Photo keyring as screen
Sun May 27, 2012 3:22 pm
I'm trying to set up an old 1.5" photo keyring as the display for my raspberry pi. A long time ago I received a "Tao Digital Photo Keyring 1.5" Display - in 8 colors Version 2.0_9_29_09_RF" as can be seen here.
I have taken it apart to leave me with this PCB and the LCD screen:
[Image redacted]
I am following this tutorial as suggested by another forum member but I have got to the point where I need to type "./hackfw.sh /dev/sdX" but I can't figure out what number X is.
Cameron.
Caemron
Re: Photo keyring as screen
Sun May 27, 2012 6:52 pm
I tried plugging the device into my windows PC and it seems that although it is displayed, the only way to transfer photos is through "DPFMate" and it is shown as a CD. Is there a way to get around this?
Caemron
Sun May 27, 2012 7:02 pm
This is the chip that stores the data. I'm thinking perhaps if I can wipe this I will be able to do what I like to it?
http://www.amictechnology.com/pdf/A25L016.pdf
patrikg
Sun May 27, 2012 7:22 pm
I have searched a lot of this, but what i can find is this.
http://www.appotech.com/main/doc.php
http://picframe.spritesserver.nl/wiki/i ... AsPicframe
http://picframe.spritesserver.nl/wiki/i ... Tech_AX206
http://picframe.spritesserver.nl/wiki/i ... ch_chipset
http://hansdegoede.livejournal.com/8797.html
First like many this devices there a cd emulation then you put it in a usb port.
You need to swith that.. and then program it.
Happy coding
/Patrik
Caemron
Sun May 27, 2012 7:53 pm
I've already seen all those links, the problem is turning off the emulation.
patrikg
Sun May 27, 2012 9:10 pm
patrikg wrote:I have searched a lot of this, but what i can find is this.
Happy coding
/Patrik
http://www.appotech.com/dp/platform/digital-photo-frame
Caemron
Sun May 27, 2012 9:40 pm
I don't understand what you are suggesting?
MarshallBanana
Sun May 27, 2012 10:52 pm
Caemron wrote:... I have got to the point where I need to type "./hackfw.sh /dev/sdX" but I can't figure out what number X is.
power up pi, when booted an logged in go to the console
now plug in the usb device
type in "dmesg" and look at the latest entries, the output of the command should end with several lines about registering new usb device and so on... if the pictureframe registered as device, the /dev/sdX name should be mentioned...
cougarten
Mon May 28, 2012 8:33 pm
just to throw this in here: http://tech.section5.ch/news/?p=150
cougarten
Mon Jun 11, 2012 11:07 pm
tadaa
http://img7.imagebanana.com/img/jyu9m3k ... 220422.jpg
10 eur from ebay, aproximately 4fps with ax206term (the text only terminal you see here).
http://projects.doozan.com/usb_lcd/st2205term.html
lcd4linux was a lot faster changing single lines only.
jbeale
Tue Jun 12, 2012 12:02 am
Impressive! Great project, thanks for posting this.
meltwater
Tue Jun 12, 2012 3:28 pm
I have the same issue.
The question is, is the statement:
"the latest generation of frames appear as a CDRW device (/dev/sr0) to Linux and cant be hacked"
Still true???
The link given gives you access to a windows based firmware read/write program, but we still have the issue of working out what firmware will work.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
Crook
Tue Jun 12, 2012 4:54 pm
Can you do a more detailed write up at some point?
meltwater
Tue Jun 12, 2012 6:51 pm
Crook wrote:Can you do a more detailed write up at some point?
"IF" I get it to work, yes.
First step is to make a backup image of the device (I managed this previously - but will try to do it again).
______________
meltwater
Wed Jun 13, 2012 8:03 am
Ok after a night of trying this and attempting to get the various things to build, I can conclude two things...
1) I don't know what I am doing!
2) I'll probably be better off looking for another screen and trying again. The one I have "may" work, but it clearly isn't going to easily.
This is the details of mine:
http://www.dealextreme.com/p/1-5-lcd-re ... rage-27893
Result from dmesg:
scsi 0:0:0:0: CD-ROM            buildwin  Photo Frame     1.01 PQ: 0 ANSI: 2
sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
cdrom: Uniform CD-ROM driver Revision: 3.20
sr 0:0:0:0: Attached scsi CD-ROM sr0
usb 1-1.2.1: reset full speed USB device number 6 using dwc_otg
usb 1-1.2.1: USB disconnect, device number 6
usb 1-1.2.1: new full speed USB device number 7 using dwc_otg
usb 1-1.2.1: New USB device found, idVendor=1908, idProduct=3318
usb 1-1.2.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
usb 1-1.2.1: Product: BL206v1.0.0
usb 1-1.2.1: Manufacturer: BUILDWIN
usb 1-1.2.1: SerialNumber: 000001
generic-usb 0003:1908:3318.0002: timeout initializing reports
generic-usb 0003:1908:3318.0002: hiddev0: USB HID v2.01 Device [BUILDWIN BL206v1.0.0] on usb-bcm2708_usb-1.2.1/input0
______________
meltwater
Wed Jun 13, 2012 7:14 pm
Thanks to some help from doozan.com I now have a hacked picture frame.
http://forum.doozan.com/read.php?2,2435 ... 9#msg-8330
Hopefully that will also help you out. Happy to give more details if needed.
Now comes the small task of trying to work out how to use lcd4linux... :shock:
______________
ax206geek
Sat Jun 16, 2012 3:07 pm
cougarten wrote:tadaa
I did the port of st2205term to ax206term over at forum.doozan.com . Now that my R-Pi has arrived, I can try this as well.
ashbash
Sun Jun 24, 2012 2:55 pm
Pls can someone link to known working devices and where they got them from?
ashbash
Mon Jun 25, 2012 11:08 am
Anyone know where we can get compatible DPF from? Looking at various links I found coby, sintronix, etc etc but cannot find them in the UK/eBay etc... :?
ax206geek
Mon Jun 25, 2012 1:10 pm
The latest list for ax206 frames is in the source of dpf-ax
dealextreme ship to UK. There are a few ebay sources too. But beware, YMMV as the same item shipped at different times may end up to be different models.
ashbash
Mon Jun 25, 2012 6:42 pm
ax206geek wrote:The latest list for ax206 frames is in the source of dpf-ax
Thanks... looking at that list, found this eBay seller, got some DPF's ... what do u reckon? :|
ashbash
Tue Jun 26, 2012 8:28 am
Put the link in first ash, come on! :oops: .. anyway here it is; http://www.ebay.co.uk/itm/White-Mini-1- ... 415f0980e0
ax206geek
Wed Jun 27, 2012 1:02 pm
ax206geek wrote: I did the port of st2205term to ax206term over at forum.doozan.com . Now that my R-Pi has arrived, I can try this as well.
I grabbed libdpf.so, st2205term, us.kmap and fonts.txt from my dockstar usb drive and copied those files over to the rpi. It worked as expected.
ax206geek
Wed Jun 27, 2012 1:06 pm
No experience with that particular variant but superelchi over at doozan/VDR portal has been super helpful in porting over new frames. I tried my hand with an AVLabs AVL969S recently but that was a relatively uncomplicated port. You really have to try your luck as the merchant may ship a different model even if it worked initially for others who purchased the item earlier on.
meltwater
Wed Jun 27, 2012 1:24 pm
Hi Guys.
The one I posted above from dealextreme seems to work. Are you able to display images using ax206term at all or is it purely terminal stuff?
Are there some guides about which show you how to use LCD3linux etc with these screens after you have them setup/programmed etc?
______________
Return to “Other projects”
