I use a (<10$) 5000lm light that has no powerline frequency issues:
viewtopic.php?f=66&t=209041&p=1309474#p1309474
First some facts, new videos taken will get separate postings in this thread.
v2 camera hardware framerate limit
I found a hardware limit in v2 camera, you cannot get more than 1007fps, but you can get 1007fps:
viewtopic.php?f=43&t=109137&p=1309989&s ... 3#p1307795
v2 camera 1000fps resolution(s)
The resolution where this works is 640x75.
With setting odd vertical line increment from 1 to 3 you can get 640x150_s frames at 1000fps.
But dcraw program needed to process raw Bayer frames has some problems for v2 camera (not for similar in v1 camera).
v2 camera capturing 75 lines this way covers 150 line area, and after dcraw duplicating each line gives 640x150_s:
Comparison with S9 super slow motion
800$ S9 can do HD 960fps super slow motion, but only for 0.2s:
http://www.samsung.com/global/galaxy/galaxy-s9/specs/
I did 7s 1000fps video with raspiraw into /dev/shm (required), leading to 100% use but still 3664K free.
And v2 camera does cost 25$, not 800.
first 1000fps v2 camera video taken
From this posting, screw driver quickly moving left/right above Lego pieces:
if you want to try now ...
... I did not commit/push the new features to github, will do that as single commit/push for pull request on 6by9's branch.
But you can start right now, diff you can apply as patch and 640x75 and 640x150_s tools are attached here:
viewtopic.php?f=43&t=109137&p=1309989&s ... 3#p1309546
