simplesi
Re: Foundation Camera Board information
Wed May 08, 2013 9:19 am
Here's a non high-res example of a time lapse shot through a window
I've seen some black cats in a coal cellar videos before but yours was the most boring one I've seen recently ;)
But very nice once the sun rises :)
Simon
PS for others - skip first 54 secs :)
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
Wed May 08, 2013 9:39 am
Simon
Apart from those people getting undressed over the road...
Actually, that may have been my imagination.
Perder
Wed May 08, 2013 12:21 pm
Would love to see high rez, less compressed timelapse. if someone with the camera could put that together..?
recantha2
Wed May 08, 2013 2:51 pm
jamesh wrote:
recantha2 wrote:Time lapse is definitely an application for this camera. The shots it produces are of high quality.
http://www.recantha.co.uk/blog/?p=3201
Apologies for the jaunty camera angle - the board was being held with some of those 'helping hands' things!
Nice timelapse! Might set up something like that at home for a laugh! What was the time gap between shots?
60 seconds - I didn't want to run out of storage space overnight :-)
Michael Horne - @recantha on Twitter
Raspberry Pi Pod blog - http://www.recantha.co.uk/blog
Cambridge Raspberry Jam - https://camjam.me
Pi Wars - https://piwars.org
recantha2
Wed May 08, 2013 2:55 pm
Perder wrote:Would love to see high rez, less compressed timelapse. if someone with the camera could put that together..?
I think I can manage that - will try and knock something up tonight.
Perder
Wed May 08, 2013 6:33 pm
awesome!
it doesn't have to be long, but different lighting conditions would be cool to see.
bullen
Thu May 09, 2013 2:10 am
Looking forward to this, specially the lowres highspeed video!
One thing though, can you make the band narrower and slim so it can squeeze out from pibow case above the ethernet plug?
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
jbeale
Thu May 09, 2013 5:17 am
I am almost sure those ribbon cables are stock items; not designed specifically for the R-Pi camera, so they are a fixed width. The best solution is probably to use a case with a slot, or add a slot yourself with a dremel tool, etc.
recantha2
Thu May 09, 2013 6:51 am
Best case I've seen for the camera (and the one I use) is the SB Components one.
Review here: http://www.recantha.co.uk/blog/?p=1264
It's a sturdy, clip together non-rattle case with good slots for the GPIO and, most importantly, the camera cable.
And they're really cheap - you can get them for under £5.
Watha
Thu May 09, 2013 2:29 pm
I know that the camera lens is fixed focus and therefore not autofocus but is it manually adjustable? Images of the lens suggest that there are lugs on the lens barrel. Most of the CCTV modules I have have some means of rotating the lens to adjust the focus. I want to use it inside a nestbox so I need it to focus at about 10cm.
M33P
Thu May 09, 2013 5:54 pm
The lens assembly is held within a threaded carrier and the thread is epoxied. It took me a modest amount of work to scrape away the epoxy and, well, end up with this:
If you unscrew the lens from the default position you can get a minimum ~6cm focal length. The FOV isn't spectacular though - about 30 degrees.
Bad news for the astrophotography crowd though - I think the IR filter is a bit more permanently attached. Once the modules are in general release I'll experiment with trying to remove it.
gkreidl
Thu May 09, 2013 7:51 pm
Things would be much simpler for many projects, if the lens thread
would not be fixed so hard (epoxied). One small spot should be enough to keep it fixated.
Minimal Kiosk Browser (kweb)
SpringHalo
Thu May 09, 2013 8:07 pm
M33P wrote:The lens assembly is held within a threaded carrier and the thread is epoxied. It took me a modest amount of work to scrape away the epoxy and, well, end up with this:
What do you think about using a wide-angle lens attachment like what they have for iPhone cameras?
http://photojojo.com/store/awesomeness/ ... ne-lenses/
gordon77
Thu May 09, 2013 8:40 pm
That looks good :) and not that difficult
Watha
Thu May 09, 2013 10:09 pm
Thanks M33P.
For a nestbox I'll need it IR filter free to allow for non-invasive lighting. I wonder if one of my existing CCTV module lenses would fit the screwthread. Hmm..
I agree with gkreidl that only the minimum amount of adhesive should be used so that we're free to adapt it for our needs. Isn't that the Raspberry Pi way?
jbeale
Thu May 09, 2013 10:40 pm
Excellent work M33P, I think a lot of people wanted to see that photo! I believe this is a standard mobile phone camera module; does the Foundation have the ability to specify a custom process for it ("less glue")? If so, I agree that would be nice.
In case anyone is going to try removing the IR filter, here are some ideas (assuming it is bonded with a UV-cure adhesive, which is often used for optical assemblies): http://www.dymax.com/pdf/literature/lit ... ves_tb.pdf
http://www.raspberrypi.org/phpBB3/viewt ... 00#p318685
"Having spoken to the Omnivision people, getting it apart may be almost impossible."
No doubt some may take that as a challenge :-)
recantha2
Fri May 10, 2013 5:54 am
M33P wrote: Bad news for the astrophotography crowd though - I think the IR filter is a bit more permanently attached. Once the modules are in general release I'll experiment with trying to remove it.
So it _does_ come apart. Great news for those who want to use it for macro. Let us know how you get on with the IR filter - it'd be nice to ramp up the low-light.
jbeale
Fri May 10, 2013 6:27 am
One other caution: even if you manage to get the IR filter removed with no damage whatsoever, be aware that you will lose resolution when compared with the original, because IR wavelengths are longer (=more diffraction) and they also diffuse farther through the silicon sensor, than visible light does. This is especially true with sensors having supertiny 1.4 micron pixels, like this one.
Fri May 10, 2013 7:58 am
Nice job getting that apart M33P! Just a warning that according to Omnivision the IR filter will be almost/completely impossible to remove.
The Foundation has no influence over the manufacture of the device, so asking for less glue won't be possible (and if it was would probably double the price of the device). These things come off a production line producing millions - any change to that line is BIG money. Since the demand for less glue would be less than 1000 items over the lifetime of the device, it's not worth the effort.
poing
Fri May 10, 2013 3:04 pm
Great work M33P!!!
sirkris
Fri May 10, 2013 4:13 pm
M33P, once the epoxy is removed, does the lens rotate freely enough to imagine adding the ability to focus using a GPIO controlled motor?
If the lens assembly is removable, can we replace it with another assembly (without an IR filter)? If so, does anyone know if Omnivision standardize this part across multiple models?
jbeale
Fri May 10, 2013 5:02 pm
I believe the IR filter is not part of the lens. It is apparently bonded to the image sensor itself. I suspect that this module or something similar to it, is also available with an autofocus lens assembly, so somewhere out there- maybe even on ebay- is a compact solution for a software-adjustable focus.
For example, there is a A1x wiki page (you may know the Allwinner A10 and A13 ARM SoC chips used in tablets) at http://linux-sunxi.org/CSI which lists the OmniVision OV5647 as a supported camera device, and they show it as an autofocus module. I think the autofocus version uses a different connector so it is not plug-compatible, unfortunately.
M33P
Fri May 10, 2013 5:55 pm
sirkris wrote:M33P, once the epoxy is removed, does the lens rotate freely enough to imagine adding the ability to focus using a GPIO controlled motor?
Yes
jamesh wrote:Just a warning that according to Omnivision the IR filter will be almost/completely impossible to remove.
O Rly?
[insert owl here]
I will be able to get it apart but not without a significant chance of cracking the sensor itself. Or debonding the connections between the flexible ribbon and the chip. Thus I'm going to wait until they are available generally.
If anyone's insane enough to try, then I would suggest removing the lens and sanding the mounting tube down to the IR filter. I think it should then "pop" out as I think the mount is welded (ultrasonic? thermal?) to the back plate and has a lip upon which the filter rests.
I think the basic construction is this:
1000 hours in mspaint.png (22.05 KiB) Viewed 20083 times
pygmy_giant
Fri May 10, 2013 7:14 pm
As breaking out the Pi's 2nd camera connector on future board revisions has been ruled out by the Foundation, I wonder whether it would be theoretically possible (with some jiggery pokery) to connect multiple cameras to the single connector on a Pi and switch it between them? This could allow for stereoscopic images or a cctv network....
Is there a set up routine that the camera and Pi have to go through and would the hardware spasm if the Pi was switched between cameras?
How many lines are in the ribbon cable? If switching is possible, could it be limited to a few lines with the others connected permenantly?
gsh
Fri May 10, 2013 7:27 pm
No it wouldn't work, those serial lines are seriously high speed so having something in parallel would be a problem, plus the CSI spec doesn't allow for it.
3D isn't likely to be possible for quite some time... I wouldn't say forever though...
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Chief Product Officer
Return to “Camera board”
