barry914
Re: Motion - MMAL camera
Mon Sep 26, 2016 8:10 pm
You can use motion without motion detection. You set a couple of switches in /etc/motion/motion.conf:
output_pictures off
and
ffmpeg_output_movies off
I'm doing exactly what you want to do with a webcam and the standard version of motion.
GraspAberry
Tue Sep 27, 2016 2:48 pm
I have those options off already. But the motion detection engine still runs, the software still evaluates every image for motion, it just doesn't write anything to disk. When I relaunch with those settings, the pixel counter in the mjpeg stream still shows the number of changed pixels and the config interface under Detection > Status still shows "ACTIVE".
I checked and saw that with Detection set to PAUSE in the web config interface, motion's CPU load drops about 10 percentage points. Since I have some other tasks running and the Zero isn't that powerful to begin with, it'd be nice to be able to launch it this way, instead of manually turning Detection off in the config interface every time.
And yea, still curious about the server and log questions if anyone knows. Thanks!
barry914
Tue Sep 27, 2016 3:04 pm
See what happens when you take advice from a newbie? So, not only did I not help you resolve your problem, I found out from you there's a way to turn off motion detection completely. I thank you for that. The only problem for me is I don't see that particular switch in my config file. I'm using the unmodified motion without support for the Pi cam, so I'm wondering if that's only in the version you are using.
andies
Sun Oct 23, 2016 4:43 pm
I was able to install motion on wheezy as well as jessy but had problems with my USB. Therefore, I had to start from scratch - and now it does not work anymore. Unfortunately, my error messages are not very helpful:
[0] [NTC] [ALL] [Oct 23 17:57:27] motion_startup: Using log type (ALL) log level (WRN)
[1] [ALR] [VID] [Oct 23 17:57:27] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Oct 23 17:57:27] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Oct 23 17:58:03] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Oct 23 17:59:03] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Oct 23 17:59:03] MMAL Camera cleanup
[1] [ALR] [VID] [Oct 23 17:59:04] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Oct 23 17:59:04] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Oct 23 17:59:40] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Oct 23 18:00:40] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Oct 23 18:00:40] MMAL Camera cleanup
[1] [ALR] [VID] [Oct 23 18:00:42] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Oct 23 18:00:42] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Oct 23 18:01:18] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Oct 23 18:02:18] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Oct 23 18:02:18] MMAL Camera cleanup
[1] [ALR] [VID] [Oct 23 18:02:19] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Oct 23 18:02:19] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Oct 23 18:02:55] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Oct 23 18:03:55] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Oct 23 18:03:55] MMAL Camera cleanup
[1] [ALR] [VID] [Oct 23 18:03:56] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Oct 23 18:03:56] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Oct 23 18:04:32] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Oct 23 18:05:32] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Oct 23 18:05:32] MMAL Camera cleanup
Does anyone has an idea what is going on here? I did the usual upgrade && update, there is enough space for the pictures to be stored, camera is activated etc.
raspberry B, Noir camera, Mac Book Air, iPhone, Bezzera
andies
Sun Oct 23, 2016 5:32 pm
OK, sorry: It seemed to be a forgotten "reboot". Shame on me...
barry914
Sun Oct 23, 2016 9:00 pm
How sure are you that you don't have power problems? I'd suggest trying a powered hub for the cam, or at least a 2 amp power supply for the Pi.
andies
Mon Oct 24, 2016 6:19 am
I am using a 2.5A because I had so many problems with the power supply.
jypang
Wed Oct 26, 2016 12:34 pm
Hi all, I am using camera module v2 and RPi 3
I have install the motion MMAL provided by @lowflyer and have configured the localhost stream to off...
but when i view in my browser (chrome) through ipaddr:8081, browser returns "This site can't be reached"
Anyone could solve my problem? Thanks!!
AndCustard
Sat Oct 29, 2016 5:22 am
@lowflyer - I've been following the installation of motion outlined here; viewtopic.php?p=864996#p864996 but I keep running into a problem similar to one posted here already.
./motion: error while loading shared libraries: libpq.so.5: cannot open shared object file: No such file or directory
When I try to apt-get the above using sudo apt-get install -y libpq5 libpq-dev I get this bunch of errors:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-dev armhf 1.0.1t-1+deb8u3
404 Not Found [IP: 5.153.225.207 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-doc all 1.0.1t-1+deb8u3
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 5.153.225.207 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u3_all.deb 404 Not Found [IP: 5.153.225.207 80]
I'm running a fresh, updated install of Raspbian Jessie on a Pi B+ and a Noir v2 camera.
Any help would be much appreciated - I've been going in circles for a couple of days now.
underwhelmd
Sat Oct 29, 2016 11:34 pm
I'd like to run two cameras on one Pi 3. One is a noir v2 and the other is USB webcam. The Pi 3 is currently running lowflyer's Motion MMAL with just the noir v2 and it's fine.
So when I go to make the threadX.conf files, I'm stuck at naming the videodevice for the noir v2 cam. The USB cam shows up in /dev as video0 .... so what is the path/name to the noir v2?
Thanks in advance for any help.
andies
Thu Nov 03, 2016 9:57 pm
I have a problem with motion on jessy on a Raspi3. First I tried uv4l together with motion but got a load-average of about 6 (because I was using the full resolution of the camera). Then, I installed twice the new raspi-image together with a complete new system (including update, upgrade and rpi-update) and only motion-mmalcam, nothing more. But I am not able to start the software. I always get an error message like
[0] [NTC] [ALL] [Nov 03 22:50:00] motion_startup: Using log type (ALL) log level (WRN)
[1] [ALR] [VID] [Nov 03 22:50:01] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Nov 03 22:50:01] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Nov 03 22:50:36] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Nov 03 22:51:36] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Nov 03 22:51:36] MMAL Camera cleanup
[1] [ALR] [VID] [Nov 03 22:51:37] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 512 x 384 at 7 fps
[1] [ALR] [VID] [Nov 03 22:51:37] mmalcam_start: MMAL Camera using still capture
[0] [ERR] [ALL] [Nov 03 22:52:12] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Nov 03 22:53:12] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
[0] [ALR] [VID] [Nov 03 22:53:12] MMAL Camera cleanup
Any ideas what I can do?
andies
Thu Nov 03, 2016 9:59 pm
Sorry, my conf-file. And I have installed that before, so cabel is ok, camera is ok, /media/usb is available etc. And
Does work.
# Daemon
# Start in daemon (background) mode and release terminal (default: off)
daemon on
# File to store the process ID, also called pid file. (default: not defined)
process_id_file /home/pi/motion/motion.pid
# Basic Setup Mode
# Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
# Use a file to save logs messages, if not defined stderr and syslog is used. (default: not defined)
logfile /home/pi/motion/motion.log
# Level of log messages [1..9] (EMR, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL). (default: 6 / NTC)
log_level 5
# Filter to log messages by type (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). (default: ALL)
log_type all
# Capture device options
# Videodevice to be used for capturing  (default /dev/video0)
# for FreeBSD default is /dev/bktr0
#videodevice /dev/video0
# v4l2_palette allows to choose preferable palette to be use by motion
# to capture from those supported by your videodevice. (default: 17)
# E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
# V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
# Setting v4l2_palette to 2 forces motion to use V4L2_PIX_FMT_SBGGR8
# instead.
# Values :
# V4L2_PIX_FMT_SN9C10X : 0  'S910'
# V4L2_PIX_FMT_SBGGR16 : 1  'BYR2'
# V4L2_PIX_FMT_SBGGR8  : 2  'BA81'
# V4L2_PIX_FMT_SPCA561 : 3  'S561'
# V4L2_PIX_FMT_SGBRG8  : 4  'GBRG'
# V4L2_PIX_FMT_SGRBG8  : 5  'GRBG'
# V4L2_PIX_FMT_PAC207  : 6  'P207'
# V4L2_PIX_FMT_PJPG    : 7  'PJPG'
# V4L2_PIX_FMT_MJPEG   : 8  'MJPEG'
# V4L2_PIX_FMT_JPEG    : 9  'JPEG'
# V4L2_PIX_FMT_RGB24   : 10 'RGB3'
# V4L2_PIX_FMT_SPCA501 : 11 'S501'
# V4L2_PIX_FMT_SPCA505 : 12 'S505'
# V4L2_PIX_FMT_SPCA508 : 13 'S508'
# V4L2_PIX_FMT_UYVY    : 14 'UYVY'
# V4L2_PIX_FMT_YUYV    : 15 'YUYV'
# V4L2_PIX_FMT_YUV422P : 16 '422P'
# V4L2_PIX_FMT_YUV420  : 17 'YU12'
v4l2_palette 17
# Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
# This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
# The video input to be used (default: -1)
# Should normally be set to 0 or 1 for video/TV cards, and -1 for USB cameras
input -1
# The video norm to use (only for video capture and TV tuner cards)
# Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
# The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
# Rotate image this number of degrees. The rotation affects all saved images as
# well as movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
# Image width (pixels). Valid range: Camera dependent, default: 352
width 512
# Image height (pixels). Valid range: Camera dependent, default: 288
height 384
# Maximum number of frames to be captured per second.
# Valid range: 2-100. Default: 100 (almost no limit).
framerate 7
# Minimum time in seconds between capturing picture frames from the camera.
# Default: 0 = disabled - the capture rate is given by the camera framerate.
# This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
# URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// mjpg:// or file:///)
# Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
;netcam_url http://127.0.0.1/cgi-bin/raspicam.sh
# Username and password for network camera (only if required). Default: not defined
# Syntax is user:password
; netcam_userpass value
# The setting for keep-alive of network socket, should improve performance on compatible net cameras.
# off:   The historical implementation using HTTP/1.0, closing the socket after each http request.
# force: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
# on:    Use HTTP/1.1 requests that support keep alive as default.
# Default: off
netcam_keepalive off
# URL to use for a netcam proxy server, if required, e.g. "http://myproxy".
# If a port number other than 80 is needed, use "http://myproxy:1234".
# Default: not defined
; netcam_proxy value
# Set less strict jpeg checks for network cameras with a poor/buggy firmware.
# Default: off
netcam_tolerant_check off
# Let motion regulate the brightness of a video device (default: off).
# The auto_brightness feature uses the brightness option as its target value.
# If brightness is zero auto_brightness will adjust to average brightness value 128.
# Only recommended for cameras without auto brightness
auto_brightness off
# Set the initial brightness of a video device.
# If auto_brightness is enabled, this value defines the average brightness level
# which Motion will try and adjust to.
# Valid range 0-255, default 0 = disabled
brightness 0
# Set the contrast of a video device.
contrast 0
# Set the saturation of a video device.
saturation 0
# Set the hue of a video device (NTSC feature).
hue 0
# File "camera" support - read raw YUV data from a file
#filecam_path /home/pi/test-cap/motion-mmal.capture
# OpenMax/MMAL camera support for Raspberry Pi
mmalcam_name vc.ril.camera
mmalcam_control_params --vflip --hflip
#-ex night -mm average -ev 8 -ifx denoise
#mmalcam_raw_capture_file /home/pi/motion-mmal.capture
# Switch this setting to "on" to use the still image mode of the Pi's camera
# instead of video. This gives a wider field of view, but requires
# a much slower frame-rate to achieve exposure stability
# (e.g. 0.25 fps or slower). You can use the minimum_frame_time
# parameter above to achieve this
mmalcam_use_still on
# Set this to non-zero value to enable a secondary buffer used for outputting results
# This value is used to multiply the original width & height settings to decide the
# secondary buffer size, so you can use it to capture a high-res image as well as a
# normal (low) resolution one for the primary.
# Use the options output_secondary_pictures, ffmpeg_output_secondary_movies, stream_secondary
# to use this high-res secondary image as the source for picture, movie and web stream output,
# while the actual motion detection is performed on the lower-resolution primary image (and
# thus use less CPU power).
mmalcam_secondary_buffer_upscale 5
# Pre-encode the secondary buffer to this jpeg quality
# Default: 0 (off), range 1-100
mmalcam_secondary_buffer_jpeg	80
# Round Robin (multiple inputs on same video device name)
# Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
# Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
# Try to filter out noise generated by roundrobin (default: off)
switchfilter off
# Motion Detection Settings:
# Threshold for number of changed pixels in an image that
# triggers motion detection (default: 1500)
threshold 500
# Automatically tune the threshold down if possible (default: off)
threshold_tune on
# Noise threshold for the motion detection (default: 32)
noise_level 32
# Automatically tune the noise threshold (default: on)
noise_tune on
# Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
# Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
# (l)abeling must only be used once and the 'l' must be the last letter.
# Comment out to disable
despeckle_filter EedDl
# Detect motion in predefined areas (1 - 9). Areas are numbered like that:  1 2 3
# A script (on_area_detected) is started immediately when motion is         4 5 6
# detected in one of the given areas, but only once during an event.        7 8 9
# One or more areas can be specified with this option. Take care: This option
# does NOT restrict detection to these areas! (Default: not defined)
; area_detect value
# PGM file to use as a sensitivity mask.
# Full path name to. (Default: not defined)
#mask_file /home/pi/motion/EinfahrtMaske.pgm
# Dynamically create a mask file during operation (default: 0)
# Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
# Ignore sudden massive light intensity changes given as a percentage of the picture
# area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
# Picture frames must contain motion at least the specified number of frames
# in a row before they are detected as true motion. At the default of 1, all
# motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
# Specifies the number of pre-captured (buffered) pictures from before motion
# was detected that will be output at motion detection.
# Recommended range: 0 to 5 (default: 0)
# Do not use large values! Large values will cause Motion to skip video frames and
# cause unsmooth movies. To smooth movies use larger values of post_capture instead.
pre_capture 0
# Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
# Event Gap is the seconds of no motion detection that triggers the end of an event.
# An event is defined as a series of motion images taken within a short timeframe.
# Recommended value is 60 seconds (Default). The value -1 is allowed and disables
# events causing all Motion to be written to one single movie file and no pre_capture.
# If set to 0, motion is running in gapless mode. Movies don't have gaps anymore. An
# event ends right after no more motion is detected and post_capture is over.
event_gap 60
# Maximum length in seconds of a movie
# When value is exceeded a new movie file is created. (Default: 0 = infinite)
max_movie_time 0
# Always save images even if there was no motion (default: off)
emulate_motion off
# Image File Output
# Output 'normal' pictures when motion is detected (default: on)
# Valid values: on, off, first, best, center
# When set to 'first', only the first picture of an event is saved.
# Picture with most motion of an event is saved when set to 'best'.
# Picture with motion nearest center of picture is saved when set to 'center'.
# Can be used as preview shot for the corresponding movie.
output_pictures on
# Output pictures with only the pixels moving object (ghost images) (default: off)
output_debug_pictures off
# Output pictures from secondary capture (see mmalcam_secondary_buffer_upscale above)
# Use this to perform motion detection on a low-res image and record a high-res output
output_secondary_pictures on
# The quality (in percent) to be used by the jpeg compression (default: 75)
quality 100
# Type of output images
# Valid values: jpeg, ppm (default: jpeg)
picture_type jpeg
# FFMPEG related options
# Film (movies) file output, and deinterlacing of the video input
# The options movie_filename and timelapse_filename are also used
# by the ffmpeg feature
# Use ffmpeg to encode movies in realtime (default: off)
# Use ffmpeg to make movies with only the pixels moving
# object (ghost images) (default: off)
ffmpeg_output_debug_movies off
# Use ffmpeg to make movies using any enabled secondary buffer (default: off)
ffmpeg_output_secondary_movies off
# Use ffmpeg to encode a timelapse movie
# Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
# The file rollover mode of the timelapse video
# Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
ffmpeg_timelapse_mode daily
# Bitrate to be used by the ffmpeg encoder (default: 400000)
# This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
# Enables and defines variable bitrate for the ffmpeg encoder.
# ffmpeg_bps is ignored if variable bitrate is enabled.
# Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
# or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 0
# Codec to used by ffmpeg for the video compression.
# Timelapse mpegs are always made in mpeg1 format independent from this option.
# Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
# mpeg1 - gives you files with extension .mpg
# mpeg4 or msmpeg4 - gives you files with extension .avi
# msmpeg4 is recommended for use with Windows Media Player because
# it requires no installation of codec on the Windows client.
# swf - gives you a flash film with extension .swf
# flv - gives you a flash video with extension .flv
# ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
# mov - QuickTime ( testing )
# ogg - Ogg/Theora ( testing )
ffmpeg_video_codec mpeg4
# Use ffmpeg to deinterlace video. Necessary if you use an analog camera
# and see horizontal combing on moving objects in video or pictures.
# (default: off)
ffmpeg_deinterlace off
# SDL Window
# Number of motion thread to show in SDL Window (default: 0 = disabled)
#sdl_threadnr 0
# External pipe to video encoder
# Replacement for FFMPEG builtin encoder for ffmpeg_output_movies only.
# Bool to enable or disable extpipe (default: off)
use_extpipe off
extpipe_secondary off
# External program (full path and opts) to pipe raw video to
# Generally, use '-' for STDIN...
;extpipe mencoder -demuxer rawvideo -rawvideo w=320:h=240:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -vf denoise3d=16:12:48:4,pp=lb -of   avi -o %f.avi - -fps %fps
;extpipe mencoder -demuxer rawvideo -rawvideo w=1024:h=576 -ovc raw -of avi -o %f.avi - -fps 15 -noskip
# Snapshots (Traditional Periodic Webcam File Output)
# Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
# Text Display
# %Y = year, %m = month, %d = date,
# %H = hour, %M = minute, %S = second, %T = HH:MM:SS,
# %v = event, %q = frame number, %t = thread (camera) number,
# %D = changed pixels, %N = noise level, \n = new line,
# %i and %J = width and height of motion area,
# %K and %L = X and Y coordinates of motion center
# %C = value defined by text_event - do not use with text_event!
# You can put quotation marks around the text to allow
# leading spaces
# Locate and draw a box around the moving object.
# Valid values: on, off, preview (default: off)
# Set to 'preview' will only draw a box in preview_shot pictures.
locate_motion_mode off
# Set the look and style of the locate box if enabled.
# Valid values: box, redbox, cross, redcross (default: box)
# Set to 'box' will draw the traditional box.
# Set to 'redbox' will draw a red box.
# Set to 'cross' will draw a little cross to mark center.
# Set to 'redcross' will draw a little red cross to mark center.
locate_motion_style box
# Draws the timestamp using same options as C function strftime(3)
# Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
# Text is placed in lower right corner
text_right %T
# Draw a user defined text on the images using same options as C function strftime(3)
# Default: Not defined = no text
# Text is placed in lower left corner
text_left %d-%m-%Y__(%D)
# Draw the number of changed pixed on the images (default: off)
# Will normally be set to off except when you setup and adjust the motion settings
# Text is placed in upper right corner
text_changes off
# This option defines the value of the special event conversion specifier %C
# You can use any conversion specifier in this option except %C. Date and time
# values are from the timestamp of the first image in the current event.
# Default: %Y%m%d%H%M%S
# The idea is that %C can be used filenames and text_left/right for creating
# a unique identifier for each event.
text_event %Y%m%d%H%M%S
# Draw characters at twice normal size on images. (default: off)
text_double on
# Text to include in a JPEG EXIF comment
# May be any text, including conversion specifiers.
# The EXIF timestamp is included independent of this text.
;exif_text %i%J/%K%L
# Target Directories and filenames For Images And Films
# For the options snapshot_, picture_, movie_ and timelapse_filename
# you can use conversion specifiers
# Quotation marks round string are allowed.
# Target base directory for pictures and films
# Recommended to use absolute path. (Default: current working directory)
target_dir /media/usb/movement
# File path for snapshots (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-snapshot
# Default value is equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
# File extension .jpg or .ppm is automatically added so do not include this.
# Note: A symbolic link called lastsnap.jpg created in the target_dir will always
# point to the latest snapshot, unless snapshot_filename is exactly 'lastsnap'
snapshot_filename %Y%m%d%H%M%S-snapshot
# File path for motion triggered images (jpeg or ppm) relative to target_dir
# Default: %v-%Y%m%d%H%M%S-%q
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
# Set to 'preview' together with best-preview feature enables special naming
# convention for preview shots. See motion guide for details
picture_filename %Y%m%d-%H%M%SEinfahrt
# File path for motion triggered ffmpeg films (movies) relative to target_dir
# For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
# File extension .mpg or .avi is automatically added so do not include this
# This option was previously called ffmpeg_filename
movie_filename %Y%m%d-%H%M%SHaustuer
# File path for timelapse movies relative to target_dir
# Default: %Y%m%d-timelapse
# Default value is near equivalent to legacy oldlayout option
# For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
# File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
# Global Network Options
# Enable or disable IPV6 for http control and stream (default: off )
ipv6_enabled off
# Live Stream Server
# The mini-http server listens to this port for requests (default: 0 = disabled)
stream_port 8085
# Quality of the jpeg (in percent) images produced (default: 50)
stream_quality 90
# Output frames at 1 fps when no motion is detected and increase to the
# rate given by stream_maxrate when motion is detected (default: off)
stream_motion off
# Use secondary buffer as stream image source (default: off)
stream_secondary off
# Maximum framerate for stream streams (default: 1)
stream_maxrate 1
# Restrict stream connections to localhost only (default: on)
stream_localhost off
# Limits the number of images per connection (default: 0 = unlimited)
# Number can be defined by multiplying actual stream rate by desired number of seconds
# Actual stream rate is the smallest of the numbers framerate and stream_maxrate
stream_limit 0
# Set the authentication method (default: 0)
# 0 = disabled
# 1 = Basic authentication
# 2 = MD5 digest (the safer authentication)
stream_auth_method 1
# Authentication for the stream. Syntax username:password
# Default: not defined (Disabled)
stream_authentication admin:xxxxxxx
# HTTP Based Control
# TCP/IP port for the http server to listen on (default: 0 = disabled)
webcontrol_port 8086
# Restrict control connections to localhost only (default: on)
webcontrol_localhost on
# Output for http server, select off to choose raw text plain (default: on)
webcontrol_html_output on
# Authentication for the http based control. Syntax username:password
; webcontrol_authentication username:password
# Tracking (Pan/Tilt)
# Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo, 6=servo)
# The generic type enables the definition of motion center and motion size to
# be used with the conversion specifiers for options like on_motion_detected
track_type 0
# Enable auto tracking (default: off)
track_auto off
# Serial port of motor (default: none)
;track_port /dev/ttyS0
# Motor number for x-axis (default: 0)
;track_motorx 0
# Set motorx reverse (default: 0)
;track_motorx_reverse 0
# Motor number for y-axis (default: 0)
;track_motory 1
# Set motory reverse (default: 0)
;track_motory_reverse 0
# Maximum value on x-axis (default: 0)
;track_maxx 200
# Minimum value on x-axis (default: 0)
;track_minx 50
# Maximum value on y-axis (default: 0)
;track_maxy 200
# Minimum value on y-axis (default: 0)
;track_miny 50
# Center value on x-axis (default: 0)
;track_homex 128
# Center value on y-axis (default: 0)
;track_homey 128
# ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
# Angle in degrees the camera moves per step on the X-axis
# with auto-track (default: 10)
# Currently only used with pwc type cameras
track_step_angle_x 10
# Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
# Delay to wait for after tracking movement as number
# of picture frames (default: 10)
track_move_wait 10
# Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
# Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
# External Commands, Warnings and Logging:
# You can use conversion specifiers for the on_xxxx commands
# %f = filename with full path
# %n = number indicating filetype
# Both %f and %n are only defined for on_picture_save,
# on_movie_start and on_movie_end
# Do not sound beeps when detecting motion (default: on)
# Note: Motion never beeps when running in daemon mode.
quiet on
# Command to be executed when an event starts. (default: none)
# An event starts at first motion detected after a period of no motion defined by event_gap
; on_event_start value
# Command to be executed when an event ends after a period of no motion
# (default: none). The period of no motion is defined by option event_gap.
; on_event_end value
# Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
# To give the filename as an argument to a command append it with %f
; on_picture_save value
# Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
# Command to be executed when motion in a predefined area is detected
# Check option 'area_detect'.   (default: none)
; on_area_detected value
# Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
# Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
# Command to be executed when a camera can't be opened or if it is lost
# NOTE: There is situations when motion don't detect a lost camera!
# It depends on the driver, some drivers dosn't detect a lost camera at all
# Some hangs the motion thread. Some even hangs the PC! (default: none)
; on_camera_lost value
# Common Options for database features.
# Options require database options to be active also.
# Log to the database when creating motion triggered picture file  (default: on)
; sql_log_picture on
# Log to the database when creating a snapshot image file (default: on)
; sql_log_snapshot on
# Log to the database when creating motion triggered movie file (default: off)
; sql_log_movie off
# Log to the database when creating timelapse movies file (default: off)
; sql_log_timelapse off
# SQL query string that is sent to the database
# Use same conversion specifiers has for text features
# Additional special conversion specifiers are
# %n = the number representing the file_type
# Default value:
# Create tables :
# Mysql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp(14), event_time_stamp timestamp(14));
# Postgresql
# CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time_stamp timestamp without time zone, event_time_stamp timestamp without time zone);
# insert into security(camera, filename, frame, file_type, time_stamp, text_event) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
; sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values('%t', '%f', '%q', '%n', '%Y-%m-%d %T', '%C')
# Database Options
# database type : mysql, postgresql, sqlite3 (default : not defined)
; database_type value
# database to log to (default: not defined)
; database_dbname value
# The host on which the database is located (default: localhost)
; database_host value
# User account name for database (default: not defined)
; database_user value
# User password for database (default: not defined)
; database_password value
# Port on which the database is located
#  mysql 3306 , postgresql 5432 (default: not defined)
; database_port value
# Database Options For SQLite3
# SQLite3 database (file path) (default: not defined)
; sqlite3_db value
# Video Loopback Device (vloopback project)
# Output images to a video4linux loopback device
# The value '-' means next available (default: not defined)
; video_pipe value
# Output motion images to a video4linux loopback device
; motion_video_pipe value
# Thread config files - One for each camera.
# Except if only one camera - You only need this config file.
# If you have more than one camera you MUST define one thread
# config file for each camera in addition to this config file.
# Remember: If you have more than one camera you must have one
# thread file for each camera. E.g. 2 cameras requires 3 files:
# This motion.conf file AND thread1.conf and thread2.conf.
# Only put the options that are unique to each camera in the
# thread config files.
; thread /usr/local/etc/thread1.conf
; thread /usr/local/etc/thread2.conf
; thread /usr/local/etc/thread3.conf
; thread /usr/local/etc/thread4.conf
kilgore72
Tue Nov 29, 2016 9:25 am
First of all i like to thank dozencrow for his awesome work!
My question or problem is that i want to upload motion triggered videos to dropbox, but it didnt worked out for me.
I tried it with the dropbox-Uploader and with a python script. I got connect via the dropbox-uploader so i could upload a test file, but it wouldnt upload motion triggered videos. i got so confused because i tried it really hard the last days...
For the Dropbox-Uploader i used this site : https://learn.adafruit.com/cloud-cam-co ... opbox-sync
For Python-script i used this site: https://mogshade.wordpress.com/2012/12/ ... nd-dropbox
Hope somebody can help me
Greetings Thomas
OS: Jessie,
Rasp A , Rasp B 512MB, 2X Rasp B+ 1GB,
Ordroid with Kodi
Rasp NOIR Cam
barry914
Tue Nov 29, 2016 3:25 pm
Not sure this is related, but I wrote a python script to send and email when motion starts recording a video. It worked fine until I added logging and then it simply stopped sending emails. Commented the logging out and it started working again. Haven't tried chasing this one down yet but maybe one day I will.
kilgore72
Sat Dec 03, 2016 3:23 pm
kilgore72 wrote:First of all i like to thank dozencrow for his awesome work!
Greetings Thomas
Ok, i found the problem, it was "just" a wrong parameter set in the motion-mmalcam.conf .
OS: Jessie,
Ordroid with Kodi
Rasp NOIR Cam
Jarwolf
Thu Dec 22, 2016 12:13 pm
[1] [WRN] [ALL] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] vid_v4lx_start: Using videodevice /dev/video0 and input -1
[1] [ALR] [VID] vid_v4lx_start: Failed to open video device /dev/video0:
I also went to sudo raspi-config and enabled the camera, and it still gives me this error even when trying to take a picture.
root@raspberrypi:/home/pi# sudo rapistill -o testimage.jpg
sudo: rapistill: command not found
root@raspberrypi:/home/pi# sudo raspistill -o testimage.jpg
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not enabled in this build. Try running "sudo raspi-config" and ensure that "camera" has been enabled
Help please :'( I am using a board camera meant for raspberry pi 2/3 I have rpi 3 model B.
root@raspberrypi:/home/pi# sudo raspi-config
It's just odd that this doesn't work anymore. Last night I had Ubuntu and it worked, though the OS was acting slow and choppy, so I formatted SD and switched over to Rasbian-Jesse.img.
[[UPDATE]]
Alrighty, so I got my camera module to work by inserting bcm2835-v4l2 into /etc/modules , and the camera at least gets activated, as in the red led light shows up, however, will not take the picture, here is the output...
pi@Anonymous:~ $ raspistill -o testingimage
mmal: No data received from sensor. Check all connections, including the Sunny one on the camera board
^Cmmal: Aborting program
andies
Mon Dec 26, 2016 5:51 pm
I am getting error messages after a complete new install:
[1] [ERR] [VID] [Dec 26 18:44:19] mmal_output_process_buffer: Output mmalcam - buffer size 499968 does not match destination 488064
[1] [ERR] [VID] [Dec 26 18:44:20] mmal_output_process_buffer: Output mmalcam - buffer size 499968 does not match destination 488064
[1] [ERR] [VID] [Dec 26 18:44:21] mmal_output_process_buffer: Output mmalcam - buffer size 499968 does not match destination 488064
[1] [ERR] [VID] [Dec 26 18:44:22] mmal_output_process_buffer: Output mmalcam - buffer size 499968 does not match destination 488064
[1] [ERR] [VID] [Dec 26 18:44:23] mmal_output_process_buffer: Output mmalcam - buffer size 499968 does not match destination 488064
Any idea what happens here? Here is my motion-mmalcam.conf
# Daemon
daemon on
# Basic Setup Mode
setup_mode off
log_level 4
log_type all
# instead.
# Values :
v4l2_palette 17
input -1
norm 0
frequency 0
rotate 0
width 648
#width 1024
height 486
#height 576
framerate 2
# Default: off
# Default: off
auto_brightness off
brightness 0
contrast 0
saturation 0
hue 0
mmalcam_control_params --exposure night
#mmalcam_control_params -ss 900000 -ISO 1600 --exposure night
#mmalcam_raw_capture_file /run/shm/motion-mmal.capture
mmalcam_use_still off
mmalcam_secondary_buffer_upscale 4
# Note that overlaid text or motion location markers will NOT be drawn into a pre-encoded buffer
# as encoding is done on the MMAL side before the image is passed to motion.
mmalcam_secondary_buffer_jpeg	75
roundrobin_frames 1
roundrobin_skip 1
switchfilter off
threshold 1000
threshold_tune off
noise_level 32
noise_tune on
; area_detect value
; mask_file value
smart_mask_speed 0
lightswitch 25
minimum_motion_frames 5
pre_capture 0
post_capture 1
event_gap 10
max_movie_time 1
emulate_motion off
# Image File Output
output_pictures best
# Output both primary and secondary pictures - only if output_secondary_pictures is on. (default: off)
output_both_pictures on
quality 90
picture_type jpeg
ffmpeg_timelapse 0
ffmpeg_bps 500000
ffmpeg_variable_bitrate 10
#ffmpeg_video_codec msmpeg4
# SDL Window
#sdl_threadnr 0
use_extpipe off
extpipe_secondary on
extpipe mencoder -demuxer rawvideo -rawvideo w=1280:h=960:i420 -ovc x264 -x264encopts bframes=4:frameref=1:subq=1:scenecut=-1:nob_adapt:threads=1:keyint=1000:8x8dct:vbv_bufsize=4000:crf=24:partitions=i8x8,i4x4:vbv_maxrate=800:no-chroma-me -of   avi -o %f.avi - -fps %fps
snapshot_interval 0
# Text Display
# leading spaces
locate_motion_style redbox
text_right Haustuer
text_left %Y-%m-%d %T/%D)
text_changes off
text_double off
exif_text "Test exif"
target_dir /media/usb/movement/
snapshot_filename Haustuer%Y%m%d%H%M
#snapshot_filename lastsnap
#picture_filename %v-%Y%m%d%H%M%S-%q
picture_filename Haustuer%Y%m%d%H%M%S
#picture_filename preview
#movie_filename %v-%Y%m%d%H%M%S
movie_filename %Y%m%d%H%M%S
ipv6_enabled off
stream_port 8081
stream_quality 70
stream_motion off
stream_maxrate 4
stream_limit 0
# 0 = disabled
stream_authentication yyyyyyy:xxxxxxxxx
webcontrol_port 8080
track_type 0
track_auto off
;track_motorx 0
;track_motory 1
;track_maxx 200
;track_minx 50
;track_maxy 200
;track_miny 50
;track_homex 128
;track_homey 128
track_iomojo_id 0
track_move_wait 10
track_speed 255
track_stepsize 40
quiet on
#on_event_end /home/pi/bin/motion_event_end.sh %v
#on_picture_save /home/pi/bin/motion_resize.py %f %n
#on_movie_end /home/pi/bin/motion_resize.py %f
; sql_log_movie off
# Default value:
# Create tables :
# Mysql
# Postgresql
# Database Options
; sqlite3_db value
; video_pipe value
alk1
Sun Feb 19, 2017 12:10 pm
@lowflyer, first thank you very much. It works flawlessly.
I just want it to configure with cron to start every morning at 7 am and end at 15 pm.
What are the commands to do it? how to make it happen?
Thanks again
lowflyer wrote:@maya I have put a copy of my version of motion here
https://www.dropbox.com/s/6ruqgv1h65zuf ... 114.tar.gz
It should work if you do this:
sudo apt-get install -y libjpeg-dev libavformat56 libavformat-dev libavcodec56 libavcodec-dev libavutil54 libavutil-dev libc6-dev zlib1g-dev libmysqlclient18 libmysqlclient-dev libpq5 libpq-dev
wget https://www.dropbox.com/s/6ruqgv1h65zufr6/motion-mmal-lowflyerUK-20151114.tar.gz
tar -zxvf motion-mmal-lowflyerUK-20151114.tar.gz
./motion -c motion-mmalcam-both.conf
Hope it works also for you. I just tested it using a fresh SDcard with jessie lite on an old Pi - and it is the same binary that I tested a few weeks ago on a Pi 2 with the full version of jessie.
I look forward to hearing how you get on with it.
If you can you should learn about how to download and compile code from github. This works for me:
sudo apt-get install git
sudo apt-get install cmake
git clone https://github.com/raspberrypi/userland
git clone https://github.com/lowflyerUK/motion.git
cd motion/
git checkout mmal-test
USERLANDPATH=/home/pi/userland cmake .
make
After a while you should have a newly created binary "motion" in the directory also called "motion". You can run it with:
/home/pi/motion/motion -c /home/pi/motion/configs/motion-mmalcam-both.conf
You may well have to adjust the config file for your needs.
Good luck!
*******Edited on 23 December 2015 to correct the compilation instructions. Thanks to Kreachers for noticing that it didn't work*******
barry914
Sun Feb 19, 2017 4:30 pm
I'm running stock motion with a pi camera without any problems. The only change I needed to make to the system is to load the bcm2835-v4l2 driver at startup. Is there any reason to use the motion-mmal version?
mrknowitall95
Thu May 25, 2017 9:40 pm
barry914 wrote:I'm running stock motion with a pi camera without any problems. The only change I needed to make to the system is to load the bcm2835-v4l2 driver at startup. Is there any reason to use the motion-mmal version?
I did this as well, but I am upable to get the streaming server working. Does it work for you?
barry914
Fri May 26, 2017 5:30 am
Yes it does. Make sure you have this set correctly:
supertoy
Wed Jan 24, 2018 1:36 am
I ran these commands:
wget https://www.dropbox.com/s/6ruqgv1h65zuf ... 114.tar.gz
cd motion/
make
After that I ran this: /home/pi/motion/motion -c /home/pi/motion/configs/motion-mmalcam-both.conf
Error: /home/pi/motion/motion: No such file or directory
I also edited it to point to my own directory (/home/supertoy/) and I se the same error.
I verified that the motion directory is not there in either pi or supertoy.
What should be my next step?
claude5555
Thu Mar 14, 2019 10:17 am
I checked many places to find a solution. I also add a grey screen. Then I decided to uninstall Infrared module and it worked. Then I reinstalled infrared module onto the camera module, but I installed infrared modules over camera module or not under as it was. Now it works perfectly. I think that putting infrared modules under decrease the voltage and this is the reason why it didn't work. I hope that this could help some of you
Thanks for all your support
Return to “Camera board”
