waveform80
Re: Pure Python camera interface
Sun Jun 19, 2016 10:28 pm
Well, it's been a while! Picamera 1.11 is *finally* here, bringing a host of stuff that you can read about in the full changelog but the highlights are:
  • full compatibility with the V2 module (max resolution supported, etc.)
  • direct capture to buffer protocol objects (like numpy arrays)
  • live manipulation of the framerate
  • manual request of key-frames for H264 recording
Part of the reason this release has taken so long is that the guts of picamera have undergone a considerable change with this release. A new layer (mmalobj) is introduced which aims to simplify usage of MMAL for Python users (partly this makes my life easier, but hopefully it might make it easier for others to hack on picamera in the future). In addition, the default pipeline changes considerably for several use-cases.
This won't affect anybody doing basic stuff (capturing JPEGs, recording H264 video) but if you're doing anything like unencoded captures (YUV, RGB, etc.) or grabbing motion estimation data you will probably need to make sure you're running cutting edge firmware (sudo rpi-update) at least until certain firmware changes hit Raspbian stable...
Part of the reason this release has taken a long time is that behind the scenes I've been bugging the extremely long suffering 6by9 day and night with piles of requests for info about, or bug fixes to, the firmware. In the past, picamera has done certain truly horrid things to make things work smoothly on the surface. For example, if you requested an RGB capture from the still port, this wouldn't directly work: the still port would refuse to commit the RGB format. So instead picamera stuck the port in YUV format, attached a resizer with the same resolution as the camera (so it wasn't resizing), set *its* output to RGBA (not RGB ... because RGB didn't work on the resizer), performed the capture, then stripped off the redundant alpha bytes in Python. Ouch. Obviously this was horrid and slow. Well, no more! The still port in cutting edge firmwares will now commit an RGB format properly, and picamera will take advantage of that.
There's similar stories for unencoded captures on the video port. The upshot is that if you're doing stuff like unencoded captures or motion vector capture, you'll want cutting edge firmware (at least until it hits Raspbian stable, so if you're reading this a couple of months from now don't worry about it).
As always, PyPI packages are already up but Raspbian packages will take a few more days to hit the repos, so have some patience if you want to stick with the apt-get installation. I'm off to help out at picademy for the next couple of days, so I won't be able to answer questions until Wednesday. In the meantime, enjoy!
Dave.
Author of / contributor to a few pi related things (picamera, Sense HAT emulator, gpiozero, piwheels, etc.), and currently a software engineer at Canonical responsible for Ubuntu on the Raspberry Pi.
jjsanderson
Mon Jun 20, 2016 2:35 pm
Woohoo! Congratulations on getting this out of the door, Dave. I'm looking forward to playing around with it and bringing my image processing code up-to-date for an installation piece I built for Maker Faire UK. It's been in mothballs for a couple of months, but is about to have another outing up here in Newcastle. It looks like you've already addressed a couple of the issues I was working around - great!
6by9
Mon Jun 20, 2016 2:58 pm
Yes it looks like the Raspbian version of the firmware is from 23rd May 2016, so not quite recent enough to pick up all the extra magic that is required by 1.11.
It looks like Jun 2, 2016 (rpi-update 4468c4c) is the earliest version that includes the changes for video_splitter that are critical for PiCamera 1.11. I'll ask Pi Towers what their plans are for getting firmware bumped.
(When the firmware is bumped it will also include the fix for correcting BGR888 and RGB888 support from the camera. PiCamera 1.11 includes the support for that so it should be invisible to the user. It is likely to cause grief for older versions of PiCamera).
jbeale
Mon Jun 20, 2016 3:31 pm
Great stuff, as always! Thanks for making this great tool even better... looks like it's time to try playing around with some things.
Question: does the picamera.image_denoise attribute affect both still and video? I gather at the MMAL layer they are separate things, given I have seen mention of MMAL_PARAMETER_VIDEO_DENOISE viewtopic.php?f=43&t=145815&start=350#p996767
pindiza
Mon Jun 20, 2016 3:46 pm
Thanks for the hard work ... Cracking job! ... this interface makes the Pi really versatile for Computer Vision projects (and easy to use too!)
6by9
Mon Jun 20, 2016 3:52 pm
jbeale wrote:Great stuff, as always! Thanks for making this great tool even better... looks like it's time to try playing around with some things.
Er, http://picamera.readthedocs.io/en/relea ... eo_denoise
Or if you wanted to check the source, it's all there, and a quick search on the appropriate MMAL_PARAMETER_xxxx values would have given you your answer.
jbeale
Mon Jun 20, 2016 4:39 pm
Thanks again 6by9 ! Indeed it was a silly question- I had searched the docs, but stopped on the first hit which was "image" rather than "video".
waveform80
Sun Jul 03, 2016 11:13 pm
Well, here's 1.12. A bit quicker than I'd expected but there was a rather important issue (297) that needed a quick release to fix. As you can probably guess there's nothing else really notable in this release (other than some other bug fixes and some rather esoteric functionality in the Color class which I managed to find a little time to finish).
TL;DR: if you're doing unencoded capture in Python 3, you'll want to upgrade to 1.12. If not, don't worry about it unless you're upgrading stuff anyway!
Dave.
cww
Mon Aug 01, 2016 2:27 pm
we'll give it a try. I don't get a lot of time to work with this, but, we'll see.
waveform80
Sat Feb 25, 2017 8:43 pm
Picamera 1.13 is now released! As usual, it'll be a few days until it hits the Raspbian repos but it's on PyPI now, and the docs should be updated in a mo.
The major news this time around is a serious re-working of the lower level mmalobj API. I'm guessing most people haven't touched this so a quick intro is in order: mmalobj is the layer between picamera and MMAL. MMAL is the C API that raspistill, raspivid, and picamera are ultimately built on, and mmalobj is a relatively thin layer that sits on top of this and tries to make it a little simpler to use (by taking away some of the decisions you generally have to make when using MMAL like when to release buffers, when to allocate buffer pools, how to allocate them, how big they should be, etc). The main picamera API (PiCamera, PiEncoder, etc.) sits on top of mmalobj.
The most important enhancement mmalobj gets in 1.13 is "pure python components". These are components that, to the mmalobj user, look and feel like "proper" MMAL components (like the camera, video encoder, etc.) but which have a Python implementation (under the covers, they're nothing like MMAL components and incur a pretty heavy performance penalty due to all the memory copying required, but it's the best I can do for now). Anyway, if you're using this lower level API this means you can build your own components and shove them in the MMAL pipeline, e.g. to draw something on top of video frames before they reach the encoder / renderer. Some simple demos are included in the docs (read the mmalobj chapter for a full tour).
There's also lots of bugs fixed in the main API: PiCameraCircularIO.copy_to had a nasty one that meant the "seconds" filter sometimes didn't work correctly, PiCamera.capture_continuous had a bug causing duplicate frames, and 10 second captures should no longer timeout on the V2 module (the default CAPTURE_TIMEOUT has been bumped to 60 seconds to accommodate this). When an updated firmware lands there should also be support for partially transparent overlays.
A lot of work has also gone into the docs in this version: the PDF and E-pub downloads from RTD should now be significantly more useful (in hard-copy or e-readers), the Advanced Recipes chapter has undergone significant revisions (new recipes, and much better versions of existing recipes), and the Camera Hardware chapter almost doubles in size with a detailed description of the low level operation of the camera module. I'd strongly encourage anyone who's read these chapters before to take a look at the new ones.
Anyway, as always: enjoy and do feel free to let me know of any bugs, requests, wishes, etc.!
Dave.
jmmec
Sun Feb 26, 2017 4:49 pm
waveform80 wrote:Picamera 1.13 is now released! ... and the Camera Hardware chapter almost doubles in size with a detailed description of the low level operation of the camera module. I'd strongly encourage anyone who's read these chapters before to take a look at the new ones.
Thank you so much! Really appreciate Picamera, especially all the effort you've put into it.
Son1c
Re: simple motion-detector using picamera
Thu Aug 30, 2018 9:47 pm
del
easybob95
Sat Sep 01, 2018 1:04 pm
i am new with raspberry and picamera. I decided to make my own capture software using Python language and it works quite well.
My purpose : to make a sky survey using raspberry pi 3 b+ and picamera V2.
You can see my program (V1) here :
https://www.facebook.com/10001024080826 ... 980401722/
Everything works just fine for short exposure time.
My 2 major problems are :
- the ISO system : it is not suitable for my purpose. I need to be able to set analog gain as i want and i need the gain setup to be stable (no change)
- long exposure time (more than 3s) is really strange. I need about 20s to get a 4 or 6 second exposure picture. It is very unstable and it's a very big problem for me.
My wishes :
- a function to set camera gain (disable ISO system)
- a better management of long exposures (several seconds).
Do you think you can bring positive answers to my demands ?
Best regards.
Alain
dan s
Tue Apr 21, 2020 6:24 am
Is picamera a dead/abandoned project?
It's been 3 years since the last release, 2 years since the last commit, and the repo has a lot of open issues.
From what I've seen, this is still the most straightforward and flexible way of streaming video, so it would be kind of sad if the project has faded away!
HermannSW
Tue Apr 21, 2020 7:40 am
I think the only person that could answer this is waveform80:
https://github.com/waveform80/picamera
A possible way to find out is to fork, fix a simple open issue and do a pull request.
Because I am interested in high framerates, I typically prefer raspivid, raspiraw, C code.
But picamera is a great piece of software, and even more of documentation.
I always point to it when discussing FoV of the two Raspberry camera models (the v1/v2 images are great):
https://picamera.readthedocs.io/en/rele ... nsor-modes
Sometimes I just use great picamera code from others, like
"gordon77's cool OpenCV live video reticle overlay python scipt"
viewtopic.php?f=43&t=239466&p=1567444#p1567444
Or build on top of other people's picamera code stuff that I would have no idea how to build in C, like
"2 camera preview windows on two displays at same time":
viewtopic.php?f=43&t=232991&p=1582997#p1582997
I have not (knowingly) run into the open issues you mentioned, but picamera having a future is definitely desireable!
6by9
Tue Apr 21, 2020 8:29 am
waveform80 is/was a contractor, therefore time spent on voluntary projects was time away from earning money. He's also involved in several other projects with the Foundation.
I'm in discussion with him as to whether Pi Towers take over Picamera, so it's not totally dead.
Tue Apr 21, 2020 8:39 am
If you can see a way to fix the open issues, write the code and do a pull request. Don't assume it has to be the original author that fixes everything.
dan s
Tue Apr 21, 2020 4:39 pm
My main interest is the all in one simplicity/flexibility that using python provides. For example the documentation provides a nice little all in one example of streaming to a browser. https://picamera.readthedocs.io/en/late ... -streaming
I opened this bug last week, because it's limiting a project I'm currently working on. I'm looking into it, but haven't found anything definitive yet. I'm not convinced it's even a python issue, It might be a C/MMAL, or driver level issue.
https://github.com/waveform80/picamera/issues/619
It's pretty similar to these bugs that also seems to have issue related to stop_recording or spliter ports.
https://github.com/waveform80/picamera/issues/47
https://github.com/waveform80/picamera/issues/466
https://github.com/waveform80/picamera/issues/597
Edit:
might also be something similar to this.
https://github.com/waveform80/picamera/issues/315
HermannSW
Tue Apr 21, 2020 6:10 pm
I am impressed, just had to install python-pip3 on my Pi2B and then do "sudo pip3 install picamera". After that "python3 stream.py" just worked. I used servo demo I tested with that camera yesterday, did control the camera on other end of the room with cursor keys easily, with live view in browser:
https://www.youtube.com/watch?v=Z6vxg0l6UAo
dan s
Tue Apr 21, 2020 7:24 pm
Yep, you are basically trading higher network bandwidth for low latency and the need for less computational power from the Pi.
This is the project i was working on when I came across what I assume is a bug. it takes advantage of the spliter ports to offer 4 potential streams with different bit-rates/resolutions. it starts and stops individual streams as needed, to keep load on the Pi to a minimum.
stream.py
from http.server import HTTPServer, BaseHTTPRequestHandler
from socketserver import ThreadingMixIn
from threading import Condition
from string import Template
import picamera
import os
import io
class videoStreamOutput(object):
    def __init__(self):
        self.frame = None
        self.buffer = io.BytesIO()
        self.condition = Condition()
    def write(self, buf):
        if buf.startswith(b'\xff\xd8'):
            self.buffer.truncate()
            with self.condition:
                self.frame = self.buffer.getvalue()
                self.condition.notify_all()
            self.buffer.seek(0)
        return self.buffer.write(buf)
class videoStream(object):
    def __init__(self, camera, description, **options):
        self.connections = 0
        self.output = videoStreamOutput()
        self.cam = camera
        self.description = description
        self.args = {'format': 'mjpeg', 'resize': None, 'splitter_port': 0, 'bitrate': 25000000}
        self.args.update(options)
        self.args['format'] = 'mjpeg'
    def startRecording(self):
        if self.connections == 0:
            self.cam.start_recording(self.output, **self.args)
            self.cam.wait_recording(timeout=3, splitter_port=self.args['splitter_port'])
        self.connections += 1
    def stopRecording(self):
        if self.connections == 1:
            self.cam.wait_recording(timeout=0, splitter_port=self.args['splitter_port'])
            self.cam.stop_recording(splitter_port=self.args['splitter_port'])
        self.connections -= 1
class StreamingHandler(BaseHTTPRequestHandler):
    def log_message(self, format, *args):
        return
    def renderHtml(self, path):
        content = ''
        if path == '':
            tmpl = Template('<a href="/$key/">$description</a>')
            for key, stream in self.server.streams.items():
                content += tmpl.substitute({'key' : key, 'description' : stream.description})
            file = open('index.html','r')
            tmpl = Template(file.read())
            file.close()
            content = tmpl.substitute({'content' : content})
        else:
            file = open('stream.html','r')
            file.close()
            content = tmpl.substitute({'key' : path, 'description' : server.streams[path].description})
        content = content.encode('utf-8')
        self.send_response(200)
        self.send_header('Content-Type', 'text/html')
        self.send_header('Content-Length', len(content))
        self.end_headers()
        self.wfile.write(content)
    def streamVideo(self, key):
        self.send_header('Age', 0)
        self.send_header('Cache-Control', 'no-cache, private')
        self.send_header('Pragma', 'no-cache')
        self.send_header('Content-Type', 'multipart/x-mixed-replace; boundary=FRAME')
        self.end_headers()
        self.server.streams[key].startRecording()
        try:
            while True:
                with self.server.streams[key].output.condition:
                    self.server.streams[key].output.condition.wait()
                    frame = self.server.streams[key].output.frame
                self.wfile.write(b'--FRAME\r\n')
                self.send_header('Content-Type', 'image/jpeg')
                self.send_header('Content-Length', len(frame))
                self.end_headers()
                self.wfile.write(frame)
                self.wfile.write(b'\r\n')
        except Exception:
            pass
        self.server.streams[key].stopRecording()
    def do_GET(self):
        path = self.path.strip('/')
        if path == '' or path in self.server.streams.keys():
            self.renderHtml(path)
        elif path.endswith('.mjpg') and path[:-5]  in self.server.streams.keys():
            self.streamVideo(path[:-5])
        else:
            self.send_error(404)
            self.end_headers()
class StreamingServer(ThreadingMixIn, HTTPServer):
    allow_reuse_address = True
    daemon_threads = True
    def __init__(self, address, Handler, streams):
        HTTPServer.__init__(self,address, Handler)
        self.streams = streams
abspath = os.path.abspath(__file__)
dname = os.path.dirname(abspath)
os.chdir(dname)
with picamera.PiCamera(sensor_mode=4, resolution=(1640,1232), framerate=40) as camera:
    camera.rotation = 90
    try:
        streams = {}
        streams['full-resolution'] = videoStream(
            camera,
            'Full Resolution',
        streams['high-resolution'] = videoStream(
            camera,
            'High Resolution',
            splitter_port=1,
            resize=(1230,924),
            bitrate=18000000
        streams['medium-resolution'] = videoStream(
            camera,
            'Medium Resolution',
            splitter_port=2,
            resize=(820,616),
            bitrate=10000000
        streams['low-resolution'] = videoStream(
            camera,
            'Low Resolution',
            splitter_port=3,
            resize=(410,308),
            bitrate=4000000
        server = StreamingServer(('', 8000), StreamingHandler, streams)
        server.serve_forever()
    except KeyboardInterrupt:
        pass
    finally:
        for key in streams:
        camera.close()
        server.server_close()
index.html
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<link rel="icon" href="data:;base64,iVBORw0KGgo=">
<title>RailCore Camera</title>
<style>
body{
background-color:#000;
a{
font-size: 1.5rem;
line-height: 2.5rem;
text-decoration: none;
display: block;
a:link, a:visited{
color:#FFF;
a:hover, a:active{
color:#F00;
</style>
</head>
<body>
$content
<body>
</body>
</html>
stream.html
<!doctype html>
<html lang="en">
<head>
<title>RailCore Camera - $description</title>
<style>
body{
margin:0;
padding:0;
#SourceStage{
position:fixed;
top:0;
left:0;
width:100%;
height:100%;
#SourceStage:before {
content: '';
box-sizing: border-box;
position: absolute;
top: 50%;
left: 50%;
width: 2rem;
height: 2rem;
margin-top: -1rem;
margin-left: -1rem;
#Source{
max-height: 100%;
max-width: 100%;
margin: auto;
position: absolute;
top: 0; left: 0; bottom: 0; right: 0;
</style>
</head>
<body>
	<div id="SourceStage">
		<img id="Source" src="/$key.mjpg" />
	</div>
<body>
</body>
</html>
dan s
Tue Apr 28, 2020 7:59 pm
does anyone know of any good tutorials or documentation on how to use the python mmal api directly? The section in the official documentation isn't really good enough imo.
Return to “Camera board”
