harmsobuk
i2cdetect command not found
Sun Feb 22, 2015 11:02 am
hi there,
i have been trying to figure out i2c for a while now, but i keep running into problems
i wanted to connect a mcp23017 to my raspberry pi, and i followed multiple online tutorials. but at one point, i had to type in sudo i2cdetect, but then i get the "sudo: i2cdetect: command not found" error message.
i tried to fix this problem, but i couldn't find a answer to my question.
my setup:
i have a raspberry pi b+ (model 1)
the MCP23017 is the bus i used
i have installed the latest version of raspbian (01-30-15)
Harm
DirkS
Re: i2cdetect command not found
Sun Feb 22, 2015 11:04 am
Install i2c-tools
sudo apt-get update
sudo apt-get install i2c-tools
Houtkamp
Mon Jul 06, 2015 4:14 pm
Hey, anybody got this working? Mine says:
~ $ sudo i2cdetect -y 1
Error: Unsupported option "-1"!
Usage: i2cdetect [-y] [-a] [-q|-r] I2CBUS [FIRST LAST]
i2cdetect -F I2CBUS
i2cdetect -l
I2CBUS is an integer or an I2C bus name
If provided, FIRST and LAST limit the probing range.
joan
Mon Jul 06, 2015 4:57 pm
Houtkamp wrote:Hey, anybody got this working? Mine says:
i2cdetect -F I2CBUS
i2cdetect -l
The syntax is
i2cdetect - y 1
or
i2cdetect 1
I don't know why your system appears to be confused by the -y, you get a similar message if you have a space between the - and the y.
