Hi Forum,
Does anyone know what is the max baud rate for Raspberry Pi 2 - Model B ?
I've done some research without any luck.
Im woundring if RPI2 could handle ~6 Mbps on either UART or SPI?
Thank you for your inputs.
Re: What is the max baud rate for UART/SPI on RPi2 model B
The UART clock is divided from the core clock frequency and uses 16x oversampling, so the "max" baud rate is 250MHz/16 = 15.6Mbaud/s.
At such a high frequency, you will get throughput issues as the FIFOs in the UART are not very deep - 16 / 8 entries. As each entry is only 8 bytes of data, you have to service a lot of interrupts to push that much data through. 6Mbps is reasonable, but expect a core to be quite busy when running at this level of data rate.
Rockets are loud.
https://astro-pi.org
Thank you jdb for you quick and good answer.
Not a very deep FIFO indeed, do you know any UART shields that could supply the RPi2 with a better UART?
SPI should be fine at 6Mbps, it can probably do twice that without too many problems.
One significant difference between SPI and UART - neither UART has DMA wired up, so you have to use either polled or interrupt-driven I/O.
Rockets are loud.
