has anyone managed to read temperature with the tmp102 I2C sensor?
If yes, could I get a tutorial on how to do it?
I have Chris Boot's custom kernel with I2C support and it has the tmp102.ko module included.
Re: tmp102
Ok I got it to work with this script:
But it sometimes (not always) fails with a read error. How to fix this?
example outputs:
#!/bin/bash
hexraw=$(sudo i2cget -y 0 0x49 0x00 w)
while [ "$hexraw" == "" ]; do
done
msb=$(echo ${hexraw:4:2})
lsb=$(echo ${hexraw:2:1})
dec=$(printf "%d\n" "0x$msb$lsb")
echo "scale=4; $dec*0.0625" | bc
example outputs:
$ ./tmp102.sh
26.6250
$ ./tmp102.sh
26.6250
$ ./tmp102.sh
Error: Read failed
Error: Read failed
Error: Read failed
26.6250
$ ./tmp102.sh
Error: Read failed
Error: Read failed
Error: Read failed
26.6250
$ ./tmp102.sh
Error: Read failed
26.6250
$ ./tmp102.sh
Error: Read failed
Error: Read failed
Error: Read failed
Error: Read failed
Error: Read failed
Error: Read failed
26.6250
$ ./tmp102.sh
Error: Read failed
Error: Read failed
26.6250
$ ./tmp102.sh
26.6250
Re: tmp102
Alright, I fixed it by connecting ADD0 to GND (previously unconnected).
Re: tmp102
I am a programmer but have only basic knowledge of electronics, Now I have my RPi and would like to get things started with hardware.
For getting things started I am looking for a cheap solution to have RPi read temperature and make it updated on my website, now the problem is I have no clue how to get started with temperature sensing.
Could you pls. tell how you made things working with this sensor ?
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
Re: tmp102
I have created a detailed tutorial on using the TMP102 with the Raspberry Pi here:
http://donalmorrissey.blogspot.co.uk/20 ... orial.html
Any comments on how to improve it would be great.
Cheers,
Donal
Cheers,
Donal
Re: tmp102
donster2k wrote:I have created a detailed tutorial on using the TMP102 with the Raspberry Pi here:
Cheers,
Donal
Awesome, thanks for sharing
Re: tmp102
In the datasheet (page 10) the serial bus address is specified. And there they have four different addresses. Anyone have experience with this? Most information I see about the tmp102 mentions that two devices can live on the same bus and not four.
Thanks for the tutorial.
Steven
Steven
Re: tmp102
Hi Folks
I've attempted the TMP102 tutorial in MagPi issue 5, and with some reference to the excellent RaspberyPiIVBeginners video, I am encountering problems at the "i2cget -y 0 0x48 0x00 w" stage (testing the module prior to running the script). The command returns with "Error: Read failed". I've queried the bus with "i2cdetect -y 0" and no device appears on the map.
Now, fearing for my soldering skills I immediately tried the module with my Arduino: it works wonderfully. Returning back to the RPi it fails again. I've checked with a multimeter and there is power going to the TMP102; I've since installed an LED off the PWR and GND to verify the supply is fine on the breadboard.
Can anyone offer advice on this?
Stu
Stu
Re: tmp102
it all depends on if you have a rev 2 broad , which you need to change i2cdetect -y 0 for i2cdetect -y 1
http://www.peter224722.blogspot.co.uk/
Re: tmp102
Have you tried bus 1 as well?
i2cdetect -y 1
Between revision 1 and 2 (512MB) RPi's the buses were switched in the hardware. So it could very well be that the tmp102 now lives on bus number 1?
Steven.
i2cdetect -y 1
Steven.
Re: tmp102
Steven, Peter
You were both completely correct! It now works. I hadn't appreciated the significance of the Rev 1 and 2 boards. Thank you very much and a Merry Christmas: this RPi is a refreshing challenging
Re: tmp102
I`ve been using the a tmp102 for so long I`ve forgot that it support 4 address.
I`m using python2 & 3 with both quick2wire and smbus libraries to monitor it.
Re: tmp102
The address changes according to which pin you connect with the ADD pin on the sensor.Steven Boelens wrote:In the datasheet (page 10) the serial bus address is specified. And there they have four different addresses. Anyone have experience with this? Most information I see about the tmp102 mentions that two devices can live on the same bus and not four.
Steven
Re: tmp102
Yes, you can add 4 sensors. TheMagPi-description use address 0x48 (hex for 0100 1000 bin).
The tmp102-data-sheet-table 12, Address Pin and Slave Adresses explained for all four addresses which pin must be connected.
E.g.:
0100 1000 -> 48 -> GND 0100 1001 -> 49 -> V+ See attached images for address 48, 49 and connection to the Raspberry Pi.
E.g.:
Re: tmp102
I want to read out the TMP102 with Python
This is my code:
If i change line 4 with:
I get the temp in hex format. How do i convert this hex format in Python?
This is my code:
import smbus
bus = smbus.SMBus(0)
address = 0x48
temp1 = bus.read_byte_data(address,0x00)
print temp1
temp1 = hex(bus.read_word_data(address,0x00))
Re: tmp102
for smbus :
def get_temp():
tmp = bus.read_word_data(HEAT_BASE_ADDRESS , 0 )
Lo = (tmp & 0xff00) >> 8 ; Hi = (tmp & 0x00ff)
temp = ((( Hi * 256 ) + Lo) >> 4 ) * 0.0625
return temp
for Quick2wire
class tmp102:
def __init__( self , CHIP_BASE_ADDRESS ):
self.CHIP_BASE_ADDRESS = CHIP_BASE_ADDRESS
def __str__(self):
return str(self.read())
# ( High byte * 256 ) + Low byte , then / 16 and the result * 0.0625
def read(self):
with I2CMaster(1) as master:
Hi_byte , Low_byte = master.transaction( quick.reading(self.CHIP_BASE_ADDRESS , 2))[0]
heat = (((( Hi_byte << 8 ) + Low_byte) >> 4) * 0.0625 )
return heat
I`m waiting until a minus temp to check my code.
Re: tmp102
I spent a couple of hour last night making my code work with minus temperatures.
After looking at every bit of code I can find , written in c++ , and python for any and every platform I`ve found no code deal with minus temperatures.
I think I`ve got to grips with i2c and can read and understand pdf chip document, But can say that the tmp102 pdf is the most confusing document I`v every seen in my life.
I`ve worked out how to deal with minus temperatures, Wow and my code works
Re: tmp102
for temperatures ≥(>?)127, subtract 256.
Re: tmp102
I problem is easier than I thought , it says for negative values add 1 , which if Hi_byte was in a byte form would just make it overflow and return back to zero.
For the Hi_byte is really in a integer I just masked anything out of the byte range,
Not sure if I need to mask out the last bit yet , because it`s not got below zero yet.
Re: tmp102
you can test with some ice/frozen food from the fridge
Re: tmp102
Easy said than done , dragging all the stuff downstairs to test it out.
It would be easier to move the freezer upstairs !!!!!
Re: tmp102
Presumably the freezer has some sort of opening on the front, from which you can extract frozen items (e.g. peas); these can then be transported upstairs, and here's the important bit, without taking the freezer itself.Peter247 wrote:Easy said than done , dragging all the stuff downstairs to test it out.
Re: tmp102
We had a big freeze last night ,so had a chance to check my code , and found I was totally wrong how to deal with minus temperatures , this is due to my translation of the your pdf document.
Re: tmp102
jamesh wrote:Presumably the freezer has some sort of opening on the front, from which you can extract frozen items (e.g. peas); these can then be transported upstairs, and here's the important bit, without taking the freezer itself.Peter247 wrote:Easy said than done , dragging all the stuff downstairs to test it out.
Re: tmp102
Nop , a big freeze is a big freeze , it`s -4.5 c outside and takes half a hour to get my car out each day .
So the snow is still there since Sunday night , and because it is not going above freezing will be that way until the sun starts shines again , welcome to the north of England.
