I have a couple of Nexus 7 screens with broken digitizers, the LCDs work fine (just the screens, the N7s have been repaired with new screen assemblies).
Has anybody any ideas on if it is possible to hook up these screens to use in display only mode with the raspi, otherwise they will just end up in landfill (which I would like to avoid if feasible).
Re: Nexus 7 LCDs
Not a way to do a direct connection.BobRocket wrote:I have a couple of Nexus 7 screens with broken digitizers, the LCDs work fine (just the screens, the N7s have been repaired with new screen assemblies).
You may however be able to remote connect (SSH, RDP etc) to the RPi over WIFI connection on your local network.
Re: Nexus 7 LCDs
Is there a model number on the displays and/or do you have the spec?
Most likely they have MIPI interface (DSI) -->not possible to connect to RPi atm.
Re: Nexus 7 LCDs
You got my attention
because I'm owner of Nexus 7 too. I looked quickly through internet. there is 2 models of Nexus 7.
- 1st model the older a.k.a. 2012 - this one is equipped in lcd part number 070WP03S - 1280x800px . Nexus 7 2012 have Nvidia Tegra 3 CPU and according to Nvidia tech spec, Tegra3 have MIPI-DSI interface...
- 2nd model the newer a.k.a. 2013 - this one have Snapdragon CPU so it's my guess it's have too MIPI-DSI - S4Pro is from bcm as so Pi SoC, so it'll have DSI too...
Overall, nice thought, but it's impossible (well nothing is really impossible...) to do it:
1. you need a datasheet for screen - probably you won't get that ever in your life...
2. you need whatever it is (source codes of Pi GPU, etc...) for adding support for this display to RPi - you'd need to have really good friends in RPi Foundation and/or in bcm...
3. You have to build interface board - this is pretty difficult taking into consideration what high frequency signals that board have to carry, nevertheless this would be the most easy thing to do
To sum it, you'd waste a lot of time, money and you'd get nothing...
I'm feel bad for braking your dream
For non-working GDrive links check my git-repo: https://github.com/saper-2/shared-stuff/
Re: Nexus 7 LCDs
If it is this display http://www.panelook.com/CLAA070WP03_CPT ... 15772.html then the spec is i.e. here (in case you have no panellook account) http://www.dragonwake.com/download/exyn ... WP03XG.pdf (but I don't know if this is the same rev/version as the screen in the NEXUS).
Based on this data the display has a 6-bit LVDS interface, data mapping info is not given so would have to be tested.
Conclusion: with the right LVDS adapter board and a suitable cable adapter it should be possible to use this display with RPi. Developing an LVDS adapter is no 'rocket science': viewtopic.php?f=45&t=157109
Re: Nexus 7 LCDs
Ordered a replacement Nexus 7 display ... let's see how far I can get ...
Re: Nexus 7 LCDs
You ordered display for N7 2012 (a.k.a. Gen1)
I'm owner of N7 2013 (aka gen2
), I took it apart (not so much
) and snapped some photos. I couldn't find any clues about display (no exact model - only asus P/N as if that would be helpful... ) nor interface. I've uploaded them on gdrive: https://drive.google.com/folderview?id= ... sp=sharing maybe you might have more luck
As for interface, true: there is no need for complex adapter board, at first I thought that this wide dual-connector FFC is a LCD interface
As for bit order I noticed in linked by you DS there are 2 signals in connector: LVBIT for changing 6/8bit per color and other one is LVFMT for bit swapping order. There is note "GND" at those signals but I don't know what to think about it...
As for N7 2013 lcd, it have 31pin connector too, and the beginning of signals might have very likely that same layout as lcd for N7-2012, only last 6 signals are the question, 3 of them will be backlight power for sure (there are 2 thick tracks on FPC cable)...
Re: Nexus 7 LCDs
Received my replacement digitizer/display unit - it's a CLAA070WP03 XG. The connector is a 0.3mm 31pin FFC.
I will design a small adapter PCB either for use with the original Nexus LVDS cable or go for a 31pin FFC to 2.xxmm adapter. The rest looks trivial to me when looking at the modules data sheet. Too bad that the digitizer will be just a cover lens later since its not possible to get this working without having details on it.
Re: Nexus 7 LCDs
tagging into this post .. as a person with such a screen (version1).
Would there be anything useful to get out of android to see what you could do with the touchscreen ?
(I would need to find where I put the nexus 7 first though, it could honestly be anywhere though
Not used it for quite some time. Yes completely routed and whatnot.)
Re: Nexus 7 LCDs
aBUGSworstnightmare (btw. good nick
) I suspected it to be 0.3mm pitch
but the connector have 2 rows of solderable pcb pins at 0.6mm spacing (I have some similar connectors for eink display).
It would be cool, but I couldn't find any datasheets for touch controller(s).
The touch controllers are:
- for N7 2012: ELAN eKTH10368WS
- for N7 2013: ELAN eKTH325BAWS (or similar),
But ELAN don't have any info about them on www. Driver code for linux for those ELANs is available so there shouldn't be much trouble to port them to Pi kernel (or even just enable... - I didn't check it - this is just assumption...). I know they works on I2C - just checked on my N7 2013:
If we had at least pinout of those controllers then it might be possible to find some replacement chip from Microchip, TI, Maxim, Atmel or others...
Well, at lest we nice and wide mounting frame
(and screen protection too
----- edit -----
The displays have FFC connector so we need also FPC. Generic "straight" cable cost as much as display itself (bare display without touch panel, on aliexpress: ~$14). 3-4 times cheaper are "original" FPC cables with FPC contacts and Board-to-Board connector. I tried to identify the board-to-board connector (Mezzanine connector) part number. I measured both: socket (receptacle - I'll call it `socket`
) on PCB and plug on FPC cable:
- PCB socket: 9.3 x 2.09 mm and height: 0.8mm - so I have to look at connectors with 0.8mm mating height.
- FFC plug: 8.6 x 1.4 mm and height: around 0.65mm
Pin pitch: 0.4mm (I'm certain. I've added to my photos few more with STM32F103 in LQFP-48 (e=0.5mm) & FFC 39x0.3mm connector - this one have 2 rows solder-able pins at 0.6mm pitch per side - at photos visible one side
I've poked around Hirose and Molex for BtB connectors matching those dimensions and I found (from the most fitting):
- Molex - pcb socket: 503772-3410 , FFC plug: 503776-3410 (I think, it will be those)
- Hirose: BM20B series 0.8mm height
- Hirose: BM14 series 0.8mm height
root@deb:/sys/devices/i2c-3/3-0010 # cat name
elan-ktf3k
----- edit -----
Re: Nexus 7 LCDs
Hi all,
the two N7 displays I have are HYDIS ones from the first generation, cheers for the data sheet and info.
Whilst I was clearing out I came across another 2 cheapo tablets, one I managed to resurrect by resoldering the power connector the other has a cracked digitiser (a common feature), the display is an AT07QTN93 so that one should work quite easily, the digitiser is not welded to the display like the nexus's so it might make a good smart mirror display.
I did find a data sheet for the Elan eKT8150 Capacitive Touch Pad Controller which might be of some use, I've put a copy here
http://www.democraticbritain.org
Re: Nexus 7 LCDs
Sorry, google do not know "AT07QTN93" - is this correct? I'll look if you give a valid symbolBobRocket wrote: Whilst I was clearing out I came across another 2 cheapo tablets, one I managed to resurrect by resoldering the power connector the other has a cracked digitiser (a common feature), the display is an AT07QTN93 so that one should work quite easily, the digitiser is not welded to the display like the nexus's so it might make a good smart mirror display.
Please, do not mix into this topic other displays - this topic is for Nexus 7 lcds
Link down: HTTP Error 403 - ForbiddenBobRocket wrote: I did find a data sheet for the Elan eKT8150 Capacitive Touch Pad Controller which might be of some use, I've put a copy here
Also, I've edited my post above with some tech info about connectors & updated photos on gdrive with better look on connectors.
Re: Nexus 7 LCDs
try this for the 8150 datasheet
http://www.datasheetarchive.com/dl/5a36 ... an+eKT8150
sorry, meant AT070TN93 similar to Tontec screen and would probably work with the control board by aBUGSworstnightmare
Re: Nexus 7 LCDs
don't know if this helps, 1st gen ME370T board layout with touch connector on p29, con5 on p23 looks like it might be the LCD connector.
https://www.google.com/url?sa=t&rct=j&q ... ATWHLW4WcA
Re: Nexus 7 LCDs
AT070TN93 is a 800x480pixel module from Innolux with 24-bit RGB interface --> can be connected to the RPi GPIO directly with a suitable adapter PCB (50pin FFC to 2.54pin pinheader). This is what I'm doing here i.e. viewtopic.php?f=41&t=154571 - no 'glue logic' required. But you will have to design a custom board for this screen!BobRocket wrote:try this for the 8150 datasheet
Re: Nexus 7 LCDs
Well done - http://www.digikey.de/product-detail/de ... ND/1987297 - schematic names Panasonic connectorBobRocket wrote:don't know if this helps, 1st gen ME370T board layout with touch connector on p29, con5 on p23 looks like it might be the LCD connector.
Re: Nexus 7 LCDs
aBUGSworstnightmare wrote:Well done - http://www.digikey.de/product-detail/de ... ND/1987297 - schematic names Panasonic connectorBobRocket wrote:don't know if this helps, 1st gen ME370T board layout with touch connector on p29, con5 on p23 looks like it might be the LCD connector.
A one hell good finding - the service manual.
I didn't know that Panasonic manufacture a BtB connectors... Link to digikey don't work, The connector is F4S : AXT5.... AXT6xxxx is "the plug" (Panasonic name it header).
AS for N7 2013 - this not help much, I checked other Panasonics connectors but none fit what I measured... Anyway I've ordered one LCD fpc for N7 2012 and 2013 , also I ordered 5pcs (for 3,22USD with cheapest shipping) the AXT530124 from aliexpress too, so around December they should arrive
Re: Nexus 7 LCDs
ME571K layout in 2 parts.
There is a repair manual out there somewhere but I haven't found it yet
Re: Nexus 7 LCDs
ME571K rhs
Re: Nexus 7 LCDs
Just for information: Started designing an adapter PCB for the Nexus 7.
Connection is as below:
LCD --> orginal FPC --> adapter PCB (ATX530124) --> Hirose DF14 series connector (to host)
Why did I choose a DF14 series connector? Simply due to the fact that quite affordable interface cables are available for this type of connector (http://www.banggood.com/20Pin-DF14-20-2 ... 77748.html) which I can use with my LVDS add-on board.
Re: Nexus 7 LCDs
Released the PCB order today.
Will operate the BL at 4.2V - similar to tablet.-
From paper to PCB ...
... postman had some nice 'bling bling' in his car today: received the PCBs! 12 days turnaround time (order to delivery) from China to Germany is not bad...
Will assemble some PCB's tomorrow and then start testing. Hopefully they will work
... so keep fingers crossed.
Re: Nexus 7 LCDs
Nice PCBs, how much did you you paid for them? They are tinned or gold-plated (can't tell form photos)?
And, yes I have my finger crossed
and hold thumbs too
From this point everything is my assumption and observation only - those are not facts proven by datasheet(s)
You have some experience with LVDS, did you know something about 6 pair of data/clock to lcd panel?
I usually found 5 or 8/10 pairs...
I found on this page that there might be 6-pair I/F: https://sites.google.com/site/lcd4hobby ... -pin-cable (on one screenshot from datasheet page).
I found on N7 2013 lcd ribbon for certain 6 routed pairs:
- equal spacing between tracks in pair & GND planes,
- both tracks of each pair seems to have equal length,
- each track of pair have as neighbor the another track from pair,
- the pair neighbor pins in CON1 are GND too...
That's, leave 4 more tracks - they're not routed in equal spacing nor to neighbor pins in CON1 (PCB BtoB connector).
I suspect that, those left 4 wires are:
1. BL_EN
2. BL_DIM (PWM??)
3. ?
4. ?
Might be DDC on 2 left (SDA & SCL) but I don't have an idea how to check this without soldering....
I have added to my google-drive-share a FPC directory with few more zoomed photos of FPC ribbons and calc (excel) file with connections on FPC from LCD to PCB connector. (Link: https://drive.google.com/drive/folders/ ... jNtbnhkcTA )
1. BL_EN
2. BL_DIM (PWM??)
3. ?
4. ?
Re: Nexus 7 LCDs
You need to distinguish between single pixel and double pixel LVDS interface (some refer to them as single - or double channel) and colour depth (6- or 8-bit). Let's take the Nexus 7 as an example. Colour depth on the Gen1 display (the one that I have on hands) is 6-bit, that's why it has 3 differential signal pairs for data Y0 to Y2 (Y0 is the upper channel in the mapping charts and Y3 is the lower one).saper_2 wrote:Hi,
And, yes I have my finger crossedand hold thumbs too
Single- or dual pixel is (let's say most of the time, there are exceptions to this as well) related with the displays resolution: single pixel (channel) LVDS is possible up to HD (1366x768) pixel.
In addition to this it needs you need to have a differential signal pair for the clock signal.
Total price for the PCB is roughly USD40 with transportation cost being higher than actual PCB cost (USD12). They are HAL only: no need to spend anther USD26 for ENIG (since I'm just using them as proof-of-concept samples).saper_2 wrote:Hi,
To me this looks like 8 differential signal pairs! The display is FHD resolution so it needs to be dual channel LVDS (odd and even channel) --> you will have 3 data channels and one clock channel for odd and even LVDS channel. This results in 8 differential signal pairs, but colour depth is 6bit only for this connection. Will be hard to tell what goes to where without having the displays data sheet...saper_2 wrote:I found on N7 2013 lcd ribbon for certain 6 routed pairs:
1. BL_EN
2. BL_DIM (PWM??)
3. ?
4. ?
By the way: the Nexus 7 Gen1 is 6-bit colour as well.
Re: Nexus 7 LCDs
... build 1st sample ..
