I can feel your excitement at the idea of dealing with me again today, so here's some more information for the whole 3fps issue I mentioned in the last reply.
If I run "avconv -t 0 -i /dev/video0 -f null /dev/null" the console shows 60fps. It's my understanding that this isn't encoding anything.
If I run any of these below (found out it doesn't have to be flv, should that help anything), I get around 3-4 fps.
- avconv -t 0 -i /dev/video0 -c:v libx264 -strict experimental -y -f flv test.flv
- avconv -t 0 -i /dev/video0 -c:v flv -strict experimental -y -f flv test.flv
This next command below shows as getting up to 45fps but the saved video still looks pretty awful and the fps must still be around 5, not 45.
- avconv -t 0 -i /dev/video0 -c:v libx264 -strict experimental -y -f h264 test.h264
Output for the libx264 flv test is:
ffmpeg version 3.2.10-1~deb9u1+rpt2 Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 6.3.0 (Raspbian 6.3.0-18+rpi1+deb9u1) 20170516
configuration: --prefix=/usr --extra-version='1~deb9u1+rpt2' --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx-rpi --enable-mmal --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --arch=armhf --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 34.101 / 55. 34.101
libavcodec 57. 64.101 / 57. 64.101
libavformat 57. 56.101 / 57. 56.101
libavdevice 57. 1.100 / 57. 1.100
libavfilter 6. 65.100 / 6. 65.100
libavresample 3. 1. 0 / 3. 1. 0
libswscale 4. 2.100 / 4. 2.100
libswresample 2. 3.100 / 2. 3.100
libpostproc 54. 1.100 / 54. 1.100
[video4linux2,v4l2 @ 0x527620] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x527620] Time per frame unknown
Input #0, video4linux2,v4l2, from '/dev/video0':
Duration: N/A, start: 6071.912862, bitrate: N/A
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 1280x720, 120 tbr, 1000k tbn, 1000k tbc
No pixel format specified, yuv422p for H.264 encoding chosen.
Use -pix_fmt yuv420p for compatibility with outdated media players.
[libx264 @ 0x52a870] using cpu capabilities: ARMv6 NEON
[libx264 @ 0x52a870] profile High 4:2:2, level 3.2, 4:2:2 8-bit
[libx264 @ 0x52a870] 264 - core 148 r2748 97eaef2 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=0:0:0 analyse=0:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=250 keyint_min=25 scenecut=0 intra_refresh=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=0
Output #0, flv, to 'newtest.flv':
Metadata:
encoder : Lavf57.56.101
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv422p, 1280x720, q=-1--1, 60 fps, 1k tbn, 60 tbc
Metadata:
encoder : Lavc57.64.101 libx264
Side data:
cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Press [q] to stop, [?] for help
frame= 158 fps=4.1 q=-1.0 Lsize= 878kB time=00:00:30.70 bitrate= 234.2kbits/s speed=0.803x
video:874kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.385400%
[libx264 @ 0x52a870] frame I:1 Avg QP:20.00 size: 68854
[libx264 @ 0x52a870] frame P:157 Avg QP: 8.93 size: 5261
[libx264 @ 0x52a870] mb I I16..4: 100.0% 0.0% 0.0%
[libx264 @ 0x52a870] mb P I16..4: 1.4% 0.0% 0.0% P16..4: 7.7% 0.0% 0.0% 0.0% 0.0% skip:90.9%
[libx264 @ 0x52a870] coded y,uvDC,uvAC intra: 28.1% 13.8% 13.4% inter: 3.4% 2.7% 2.3%
[libx264 @ 0x52a870] i16 v,h,dc,p: 76% 22% 1% 1%
[libx264 @ 0x52a870] i8c dc,h,v,p: 88% 4% 7% 0%
[libx264 @ 0x52a870] kb/s:231.42
Output for the h264 test is:
[video4linux2,v4l2 @ 0x16d4600] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x16d4600] Time per frame unknown
Duration: N/A, start: 5015.769341, bitrate: N/A
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 1280x720, 59.94 tbr, 1000k tbn, 1000k tbc
[libx264 @ 0x16d77e0] using cpu capabilities: ARMv6 NEON
[libx264 @ 0x16d77e0] profile High 4:2:2, level 3.2, 4:2:2 8-bit
Output #0, h264, to 'newtest.h264':
Metadata:
Stream #0:0: Video: h264 (libx264), yuv422p, 1280x720, q=-1--1, 59.94 fps, 59.94 tbn, 59.94 tbc
Metadata:
Side data:
Stream mapping:
frame= 1813 fps= 37 q=-1.0 Lsize= 3218kB time=00:00:30.24 bitrate= 871.5kbits/s dup=1700 drop=0 speed=0.617x
video:3218kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
[libx264 @ 0x16d77e0] frame I:8 Avg QP:14.00 size:170114
[libx264 @ 0x16d77e0] frame P:1805 Avg QP:15.46 size: 1071
[libx264 @ 0x16d77e0] mb I I16..4: 100.0% 0.0% 0.0%
[libx264 @ 0x16d77e0] mb P I16..4: 0.4% 0.0% 0.0% P16..4: 2.0% 0.0% 0.0% 0.0% 0.0% skip:97.6%
[libx264 @ 0x16d77e0] coded y,uvDC,uvAC intra: 43.4% 28.3% 19.2% inter: 1.1% 0.8% 0.2%
[libx264 @ 0x16d77e0] i16 v,h,dc,p: 61% 26% 8% 5%
[libx264 @ 0x16d77e0] i8c dc,h,v,p: 68% 12% 17% 4%
[libx264 @ 0x16d77e0] kb/s:871.45
