I tested the relays on the 3.3v pins in the GPIO header, and they worked! So I thought that I didn't need to buy any level shifters or anything. However, when I tried it on any of the controllable pins, it made a barely audible hum when depowering it, instead of a loud click when powering. This didn't make any sense: Why would it work on the 3.3v pins and not the other ones?
I got out a multi-meter and tested the voltage.
Both pins were just over 3 volts.
Next I tried the amps, and this is where I found results.
The 3.3v pin supplied more than the 250mA my meter can test
The other pins supplied around 35-40mA
HUGE difference. Is anyone else getting this? And can anyone explain why this happens?
Also, now I think I either need to get relays with a 3.3v coil, or some level shifters.
