GadgetUK
Pi B+ ID_SD and ID_SC
Mon Jul 14, 2014 7:14 am
Does anyone have more info on
ID_SD and ID_SC PINS:
These pins are reserved for ID EEPROM.
At boot time this I2C interface will be
interrogated to look for an EEPROM
that identifes the attached board and
allows automagic setup of the GPIOs
(and optionally, Linux drivers).
DO NOT USE these pins for anything other
than attaching an I2C ID EEPROM. Leave
unconnected if ID EEPROM not required.
On the new Pi B+ boards ?
ShiftPlusOne
Re: Pi B+ ID_SD and ID_SC
Mon Jul 14, 2014 7:16 am
As I understand it, you'll be able to plug in an add-on board and the pins will automatically be configured to support that board and a relevant module might be loaded. A bit like plugging in usb devices. I am not 100% on this though.
GadgetUK
Mon Jul 14, 2014 7:20 am
Thats my understanding, but the devil will be in the detail.
I'm making the assumption that it uses the P5 i2c pins
alias_neo
Mon Jul 14, 2014 8:13 am
If this is correct, it's going to be great, the pi will be able to swap drivers and pin settings by identifying the board attached through its ID chip.
This should allow the GPIO to detect which device has been attached like a USB port does.
I'm hoping this will happen very early in the boot process so that attached displays etc can get full console outputs and whatnot.
https://2byt.es - Just my two bytes - RPi - Android - Arduino - Blog
Mon Jul 14, 2014 9:24 am
PeterO
Mon Jul 14, 2014 9:37 am
Topic loop detected..... "Don't cross the beams"
PeterO
ShiftPlusOne
Mon Jul 14, 2014 9:49 am
To avoid splitting this across multiple threads...
