It also allows 3-wire operation in a limited fashion, i.e. single wire for MOSI and MISO. In 3-wire mode the message is split up into two parts, in the first part the single wire is driven as MOSI, in the second part the bus is reversed and the single wire is driven as MISO. The software provided only allows the turnaround on a byte boundary. The code contains an example of driving the MCP4131 which needs to be driven in this way (at least if you want to read from it).
There are 3 SPI functions.
- void spiInit(void) - saves current SPI state and sets up SPI mode.
- void spiTerm(void) - restores the original SPI state.
- void spiXfer(
unsigned speed, /* bits per second */
unsigned channel, /* 0 or 1 */
unsigned mode, /* 0 - 3 */
unsigned cspol, /* 0 = active low, 1 = active high */
char *txBuf, /* tx buffer */
char *rxBuf, /* rx buffer */
unsigned cnt4w, /* number of 4-wire bytes */
unsigned cnt3w) /* number of 3-wire bytes */
gcc -o minimal_spi minimal_spi.c -lrt
sudo ./minimal_spi
#include <stdio.h>
#include <unistd.h>
#include <stdint.h>
#include <string.h>
#include <fcntl.h>
#include <time.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <sys/types.h>
/* Peripherals */
#define SYST_BASE 0x20003000
#define DMA_BASE 0x20007000
#define PADS_BASE 0x20100000
#define CLK_BASE 0x20101000
#define GPIO_BASE 0x20200000
#define UART0_BASE 0x20201000
#define PCM_BASE 0x20203000
#define SPI_BASE 0x20204000
#define I2C0_BASE 0x20205000
#define PWM_BASE 0x2020C000
#define UART1_BASE 0x20215000
#define I2C1_BASE 0x20804000
#define I2C2_BASE 0x20805000
#define DMA15_BASE 0x20E05000
#define DMA_LEN 0x1000 /* allow access to all channels */
#define CLK_LEN 0xA8
#define GPIO_LEN 0xB4
#define SYST_LEN 0x1C
#define PCM_LEN 0x24
#define PWM_LEN 0x28
#define I2C_LEN 0x1C
#define SPI_LEN 0x18
#define PADS_LEN 0x1000
/* GPIOs */
#define GPSET0 7
#define GPSET1 8
#define GPCLR0 10
#define GPCLR1 11
#define GPLEV0 13
#define GPLEV1 14
#define GPPUD 37
#define GPPUDCLK0 38
#define GPPUDCLK1 39
/* System 1us clock */
#define SYST_CS 0
#define SYST_CLO 1
#define SYST_CHI 2
/* SPI */
#define SPI_CS 0
#define SPI_FIFO 1
#define SPI_CLK 2
#define SPI_DLEN 3
#define SPI_LTOH 4
#define SPI_DC 5
#define SPI_CS_LEN_LONG (1<<25)
#define SPI_CS_DMA_LEN (1<<24)
#define SPI_CS_CSPOL2 (1<<23)
#define SPI_CS_CSPOL1 (1<<22)
#define SPI_CS_CSPOL0 (1<<21)
#define SPI_CS_RXF (1<<20)
#define SPI_CS_RXR (1<<19)
#define SPI_CS_TXD (1<<18)
#define SPI_CS_RXD (1<<17)
#define SPI_CS_DONE (1<<16)
#define SPI_CS_LEN (1<<13)
#define SPI_CS_REN (1<<12)
#define SPI_CS_ADCS (1<<11)
#define SPI_CS_INTR (1<<10)
#define SPI_CS_INTD (1<<9)
#define SPI_CS_DMAEN (1<<8)
#define SPI_CS_TA (1<<7)
#define SPI_CS_CSPOL(x) ((x)<<6)
#define SPI_CS_CLEAR(x) ((x)<<4)
#define SPI_CS_MODE(x) ((x)<<2)
#define SPI_CS_CS(x) ((x)<<0)
#define SPI_DC_RPANIC(x) ((x)<<24)
#define SPI_DC_RDREQ(x) ((x)<<16)
#define SPI_DC_TPANIC(x) ((x)<<8)
#define SPI_DC_TDREQ(x) ((x)<<0)
#define SPI_MODE0 0
#define SPI_MODE1 1
#define SPI_MODE2 2
#define SPI_MODE3 3
#define SPI_CS0 0
#define SPI_CS1 1
#define SPI_CS2 2
static volatile uint32_t *gpioReg = MAP_FAILED;
static volatile uint32_t *systReg = MAP_FAILED;
static volatile uint32_t *pwmReg = MAP_FAILED;
static volatile uint32_t *clkReg = MAP_FAILED;
static volatile uint32_t *padsReg = MAP_FAILED;
static volatile uint32_t *spiReg = MAP_FAILED;
static volatile uint32_t *i2c0Reg = MAP_FAILED;
static volatile uint32_t *i2c1Reg = MAP_FAILED;
#define PI_BANK (gpio>>5)
#define PI_BIT (1<<(gpio&0x1F))
/* SPI gpios. */
#define PI_SPI_CE0 8
#define PI_SPI_CE1 7
#define PI_SPI_SCLK 11
#define PI_SPI_MISO 9
#define PI_SPI_MOSI 10
/* gpio levels. */
#define PI_LOW 0
#define PI_HIGH 1
/* gpio modes. */
#define PI_INPUT 0
#define PI_OUTPUT 1
#define PI_ALT0 4
#define PI_ALT1 5
#define PI_ALT2 6
#define PI_ALT3 7
#define PI_ALT4 3
#define PI_ALT5 2
void gpioSetMode(unsigned gpio, unsigned mode)
int reg, shift;
reg = gpio/10;
shift = (gpio%10) * 3;
gpioReg[reg] = (gpioReg[reg] & ~(7<<shift)) | (mode<<shift);
int gpioGetMode(unsigned gpio)
int reg, shift;
reg = gpio/10;
return (*(gpioReg + reg) >> shift) & 7;
/* Values for pull-ups/downs off, pull-down and pull-up. */
#define PI_PUD_OFF 0
#define PI_PUD_DOWN 1
#define PI_PUD_UP 2
void gpioSetPullUpDown(unsigned gpio, unsigned pud)
*(gpioReg + GPPUD) = pud;
usleep(20);
*(gpioReg + GPPUDCLK0 + PI_BANK) = PI_BIT;
usleep(20);
*(gpioReg + GPPUD) = 0;
*(gpioReg + GPPUDCLK0 + PI_BANK) = 0;
int gpioRead(unsigned gpio)
if ((*(gpioReg + GPLEV0 + PI_BANK) & PI_BIT) != 0) return 1;
else return 0;
void gpioWrite(unsigned gpio, unsigned level)
if (level == 0) *(gpioReg + GPCLR0 + PI_BANK) = PI_BIT;
else *(gpioReg + GPSET0 + PI_BANK) = PI_BIT;
void gpioTrigger(unsigned gpio, unsigned pulseLen, unsigned level)
usleep(pulseLen);
if (level != 0) *(gpioReg + GPCLR0 + PI_BANK) = PI_BIT;
/* Bit (1<<x) will be set if gpio x is high. */
uint32_t gpioReadBank1(void) { return (*(gpioReg + GPLEV0)); }
uint32_t gpioReadBank2(void) { return (*(gpioReg + GPLEV1)); }
/* To clear gpio x bit or in (1<<x). */
void gpioClearBank1(uint32_t bits) { *(gpioReg + GPCLR0) = bits; }
void gpioClearBank2(uint32_t bits) { *(gpioReg + GPCLR1) = bits; }
/* To set gpio x bit or in (1<<x). */
void gpioSetBank1(uint32_t bits) { *(gpioReg + GPSET0) = bits; }
void gpioSetBank2(uint32_t bits) { *(gpioReg + GPSET1) = bits; }
unsigned gpioHardwareRevision(void)
static unsigned rev = 0;
FILE * filp;
char buf[512];
char term;
if (rev) return rev;
filp = fopen ("/proc/cpuinfo", "r");
if (filp != NULL)
while (fgets(buf, sizeof(buf), filp) != NULL)
if (!strncasecmp("revision\t", buf, 9))
if (sscanf(buf+strlen(buf)-5, "%x%c", &rev, &term) == 2)
if (term == '\n') break;
rev = 0;
fclose(filp);
return rev;
/* Returns the number of microseconds after system boot. Wraps around
after 1 hour 11 minutes 35 seconds.
uint32_t gpioTick(void) { return systReg[SYST_CLO]; }
double time_time(void)
struct timeval tv;
double t;
gettimeofday(&tv, 0);
t = (double)tv.tv_sec + ((double)tv.tv_usec / 1E6);
return t;
void time_sleep(double seconds)
struct timespec ts, rem;
if (seconds > 0.0)
ts.tv_sec = seconds;
ts.tv_nsec = (seconds-(double)ts.tv_sec) * 1E9;
while (clock_nanosleep(CLOCK_REALTIME, 0, &ts, &rem))
/* copy remaining time to ts */
ts.tv_sec = rem.tv_sec;
ts.tv_nsec = rem.tv_nsec;
/*SPI */
static unsigned old_mode_ce0;
static unsigned old_mode_ce1;
static unsigned old_mode_sclk;
static unsigned old_mode_miso;
static unsigned old_mode_mosi;
static uint32_t old_spi_cs;
static uint32_t old_spi_clk;
void spiInit(void)
old_mode_ce0 = gpioGetMode(PI_SPI_CE0);
old_mode_ce1 = gpioGetMode(PI_SPI_CE1);
old_mode_sclk = gpioGetMode(PI_SPI_SCLK);
old_mode_miso = gpioGetMode(PI_SPI_MISO);
old_mode_mosi = gpioGetMode(PI_SPI_MOSI);
gpioSetMode(PI_SPI_CE0, PI_ALT0);
gpioSetMode(PI_SPI_CE1, PI_ALT0);
gpioSetMode(PI_SPI_SCLK, PI_ALT0);
gpioSetMode(PI_SPI_MISO, PI_ALT0);
gpioSetMode(PI_SPI_MOSI, PI_ALT0);
old_spi_cs = spiReg[SPI_CS];
old_spi_clk = spiReg[SPI_CLK];
void spiTerm(void)
gpioSetMode(PI_SPI_CE0, old_mode_ce0);
gpioSetMode(PI_SPI_CE1, old_mode_ce1);
gpioSetMode(PI_SPI_SCLK, old_mode_sclk);
gpioSetMode(PI_SPI_MISO, old_mode_miso);
gpioSetMode(PI_SPI_MOSI, old_mode_mosi);
spiReg[SPI_CS] = old_spi_cs;
spiReg[SPI_CLK] = old_spi_clk;
void spiXfer(
unsigned cspol, /* 0 = active low */
unsigned txCnt=0;
unsigned rxCnt=0;
unsigned cnt;
uint32_t spiDefaults;
spiDefaults = SPI_CS_MODE(mode) |
SPI_CS_CS(channel) |
SPI_CS_CSPOL(cspol) |
SPI_CS_CLEAR(3);
spiReg[SPI_CLK] = 250000000/speed;
spiReg[SPI_CS] = spiDefaults | SPI_CS_TA; /* start */
cnt = cnt4w;
while((txCnt < cnt) || (rxCnt < cnt))
while((txCnt < cnt) && ((spiReg[SPI_CS] & SPI_CS_TXD)))
spiReg[SPI_FIFO] = txBuf[txCnt++];
while((rxCnt < cnt) && ((spiReg[SPI_CS] & SPI_CS_RXD)))
rxBuf[rxCnt++] = spiReg[SPI_FIFO];
while (!(spiReg[SPI_CS] & SPI_CS_DONE)) ;
/* now switch to 3-wire bus */
cnt += cnt3w;
spiReg[SPI_CS] |= SPI_CS_REN;
spiReg[SPI_CS] = spiDefaults; /* stop */
/* Map in registers. */
static uint32_t * initMapMem(int fd, uint32_t addr, uint32_t len)
return (uint32_t *) mmap(0, len,
PROT_READ|PROT_WRITE|PROT_EXEC,
MAP_SHARED|MAP_LOCKED,
fd, addr);
int gpioInitialise(void)
int fd;
fd = open("/dev/mem", O_RDWR | O_SYNC) ;
if (fd < 0)
fprintf(stderr,
"This program needs root privileges. Try using sudo\n");
return -1;
gpioReg = initMapMem(fd, GPIO_BASE, GPIO_LEN);
systReg = initMapMem(fd, SYST_BASE, SYST_LEN);
pwmReg = initMapMem(fd, PWM_BASE, PWM_LEN);
clkReg = initMapMem(fd, CLK_BASE, CLK_LEN);
padsReg = initMapMem(fd, PADS_BASE, PADS_LEN);
spiReg = initMapMem(fd, SPI_BASE, SPI_LEN);
close(fd);
if ((gpioReg == MAP_FAILED) || (systReg == MAP_FAILED))
fprintf(stderr,
"Bad, mmap failed\n");
return -1;
return 0;
int read_mcp3202(
unsigned speed,
unsigned spi_channel,
unsigned mode,
unsigned adc_channel)
const int msglen = 3;
char txBuf[msglen];
char rxBuf[msglen];
txBuf[0] = 1;
if (adc_channel == 0) txBuf[1] = 0x80; else txBuf[1] = 0xC0;
txBuf[2] = 0;
/* speed, channel, mode, cspol, *txBuf,*rxBuf,cnt4w,cnt3w */
spiXfer(speed, spi_channel, mode, 0, txBuf, rxBuf, msglen, 0); /* SPI xfer */
return ((rxBuf[1]&0x0F)<<8) + rxBuf[2];
int mcp3202_test(int argc, char *argv[])
int i;
int speed, iters, maxsps, pf;
unsigned divider;
unsigned reading[4096];
unsigned val;
double start, duration;
uint32_t nt, micros;
int tdiff;
if (argc >= 4)
speed = atoi(argv[1]);
iters = atoi(argv[2]);
maxsps = atoi(argv[3]);
micros = 1000000 / maxsps;
if (argc > 4) pf = 1; else pf = 0;
else
fprintf(stderr, "need Speed(bps), Samples, Max sps.\n");
fprintf(stderr, "sudo ./spi 2500000 1000000 100000\n");
return 1;
for (i=0; i<4096; i++) reading[i]= 0;
/* An MCP3202 is being used for testing. Read channel 0 */
/* Max speed 2.5MHz clock, 100ksps @ 5V */
divider = 250000000/speed;
if (divider % 1) divider++;
spiInit(); /* save old SPI settings, initialise */
printf ("selected speed=%d (set=%u) iters=%d xfer=3 mingap=%d\n",
speed, 250000000/divider, iters, micros);
start = time_time();
for (i=0; i<iters; i++)
nt = gpioTick() + micros;
val = read_mcp3202(speed, 1, 0, 0);
if (pf) printf("%u\n", val);
reading[(val/10)*10]++;
do /* rate limit */
tdiff = nt - gpioTick();
} while (tdiff > 0);
duration = time_time() - start;
spiTerm(); /* restore old SPI settings */
if (reading[i]) printf("%d %d\n", i, reading[i]);
printf("%.0f sps over %.1f seconds\n", ((float)iters)/(duration), duration);
return 0;
int mcp4131_test(int argc, char *argv[])
int i;
const int msglen = 2;
const int maxset = 129;
const int maxreading = 1024;
unsigned divider;
char txBuf[msglen];
char rxBuf[msglen];
unsigned reading[maxreading];
unsigned val;
int tdiff;
if (argc >= 4)
else
return 1;
for (i=0; i<maxreading; i++) reading[i] = 0;
printf ("selected speed=%d (set=%u) iters=%d xfer=%d mingap=%d\n",
speed, 250000000/divider, iters, msglen, micros);
/* set wiper 0 position */
txBuf[0] = 0; /* write wiper 0 */
txBuf[1] = i%maxset;
spiXfer(speed, 0, 0, 0, txBuf, rxBuf, 2, 0); /* SPI xfer */
/* read position back */
usleep(1);
/* see what mcp3202 thinks */
val = read_mcp3202(1000000, 1, 0, 1);
usleep(1);
txBuf[0] = 0x0C; /* read wiper 0 */
txBuf[1] = 0;
rxBuf[1] = 0;
spiXfer(250000, 0, 0, 0, txBuf, rxBuf, 1, 1); /* SPI xfer */
if (pf) printf("%u %u (%u)\n", i%maxset, rxBuf[1], val);
do /* rate limit */
return 0;
main(int argc, char *argv[])
if (gpioInitialise() < 0) return 1;
return mcp3202_test(argc, argv);
joan@harry /ram $ gcc -o spi /code/minimal_spi.c
joan@harry /ram $ sudo ./spi 2500000 1000000 100000
selected speed=2500000 (set=2500000) iters=1000000 xfer=3 mingap=10
1960 2
1970 780
1980 249006
1990 748608
2000 1601
2010 3
82947 sps over 12.1 seconds
joan@harry /ram $ sudo ./spi 2500000 1000000 120000
selected speed=2500000 (set=2500000) iters=1000000 xfer=3 mingap=8
1960 1
1970 722
1980 248707
1990 748981
2000 1584
2010 5
83114 sps over 12.0 seconds
joan@harry /ram $ sudo ./spi 2800000 1000000 100000
selected speed=2800000 (set=2808988) iters=1000000 xfer=3 mingap=10
1950 1
1960 24696
1970 244841
1980 719757
1990 10703
2000 2
93338 sps over 10.7 seconds
joan@harry /ram $ sudo ./spi 2900000 1000000 100000
selected speed=2900000 (set=2906976) iters=1000000 xfer=3 mingap=10
1950 2
1960 74271
1970 379636
1980 546042
1990 49
95097 sps over 10.5 seconds
joan@harry /ram $ sudo ./spi 3000000 1000000 100000
selected speed=3000000 (set=3012048) iters=1000000 xfer=3 mingap=10
1940 4
1950 78
1960 254656
1970 713080
1980 32172
1990 10
98910 sps over 10.1 seconds
joan@harry /ram $ sudo ./spi 3100000 1000000 100000
selected speed=3100000 (set=3125000) iters=1000000 xfer=3 mingap=10
1940 4
1950 14047
1960 476207
1970 509603
1980 131
1990 8
98965 sps over 10.1 seconds
joan@harry /ram $ sudo ./spi 3100000 1000000 110000
selected speed=3100000 (set=3125000) iters=1000000 xfer=3 mingap=9
1950 13470
1960 476608
1970 509795
1980 126
1990 1
101066 sps over 9.9 seconds
joan@harry /ram $
joan@harry /ram $ sudo ./spi 125000000 1000000 1000000
selected speed=125000000 (set=125000000) iters=1000000 xfer=3 mingap=1
0 1000000
494387 sps over 2.0 seconds
joan@harry /ram $
