frog_pi
Re: STICKY: The I2S sound thread. [I2S works]
Wed Jun 10, 2020 12:35 pm
Hi, meanwhile I was playing with bcm2835-i2s.c and when i delay the data 8 bits like this:
 486		data_delay = slot_width - data_length + 8;
Everything works fine for 24bit audio (not for 16 bit though of course), I could use a workaround and convert the 16 to 24 bit i guess. But I'd rather make it right.
Any help or idea for where to look is much appreciated.
Greetings frog_pi
Edit:
I also tried to get 16 instead of 15 bit of data (when using 16 bit audio) with:
 486		data_delay = slot_width - data_length - 1
but that didn't help at all, it's just 15 bits in the wrong place then ^^
HiassofT
Fri Jun 12, 2020 1:34 pm
frog_pi wrote:
Mon Jun 08, 2020 10:04 am
Hi guys, I could use a little help with my overlay, I'm trying to output right justified. THe overlay gets loaded as it should, soundcard is there in alsa as expected BUT when I use 16 bit audio I get very low volume, could I be missing one data bit here?
And when I try to output 24 bit audio I get normal volume but only noise (almost threw my of the chair because i had the volume so far up from testing with 16 bit ^^), a quick scope check confirmed looks pretty much like left justified. Anyone an idea what could be the culprit?
I tested your overlay on the latest raspbian kernel (4.19.118) and couldn't reproduce this issue. The LSB was nicely aligned with the trailing frameclock edge.
Playing a 16-bit testfile with 0x8001 on the left channel and 0x7ffe on the right one:
Testing with 24bit and speaker-test also worked as it should.
Make sure you actually loaded the correct overlay and don't have any .asoundrc (or soundserver etc) which changes the format.
In general using right-justified mode with the generic spdif transmitter codec will be a bit tricky if you want to support different sample lengths as the MSB will be at different absolute positions. You'll need to use an .asoundrc file to set a fixed format (eg S24_LE) and setup your DAC for that configuration (or choose a format that matches what the DAC expects).
so long,
Hias
frog_pi
Fri Jun 12, 2020 2:54 pm
Hi, first of all thanks a ton for your effort and help!!
I checked:
-Fresh installed Pi OS 4.19.118 (so i guess there should be no soundserver installed, didn't find any either, i guess you mean something like pulseaudio)
- Correct overlay is loaded (I only compiled one on the fresh OS):
pi@raspberrypi:/boot/overlays $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: GenericRJ [GenericRJ], device 0: bcm2835-i2s-dit-hifi dit-hifi-0 [bcm2835-i2s-dit-hifi dit-hifi-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
- no alsa config file:
pi@raspberrypi:/boot/overlays $ cat ~/.asoundrc
cat: /home/pi/.asoundrc: No such file or directory
pi@raspberrypi:/boot/overlays $ cat /etc/asound.conf
cat: /etc/asound.conf: No such file or directory
pi@raspberrypi:/boot/overlays $ cat /etc/alsa/conf.d
cat: /etc/alsa/conf.d: No such file or directory
I also tried a standard asoundrc but that didn't make a difference:
pcm.!default {
        type hw
        card 0
ctl.!default {
        type hw
        card 0
Really strange alltogether ^^
But if I have to set a fixed format anyway in asoundrc, i'll leave the 8 bit delay in the bcm2835-i2s.c and set alsa to fix 24bit audio, as this works just fine. In case I find the problem I'll let you know though.
Thanks again,
greetings frog_pi
phofman
Fri Jun 12, 2020 3:09 pm
Hi Hias,
Please may I ask you a very basic question - in which DTS can I find the configuration of CLK source for the I2S peripheral, i.e. PLLD clock? I found DTS where PLLD and oscillator are the only two available for the pcm clock https://elixir.bootlin.com/linux/latest ... 35.c#L1524 , but I did not find a place where PLLD_PER is configured as source for the "PCM_MCLK" input mentioned in the RPi datasheet. I found only the GP0/1/2 clock registers which can specify the source but did not find one of them being assigned to the PCM peripheral in master mode.
Thanks a lot for your help,
Pavel.
pkuhar
Fri Jun 12, 2020 5:32 pm
I'm using a PDM microphone on RPI4b setup from instructions here.
It works, bit I get about 33% DC offset.
Does anyone have any experience or hints about this?
Checking with the microscope the mean voltage is 1.62V. so that looks ok.
bricolodu13
Fri Jun 12, 2020 7:28 pm
Hello HiassofT,
No, that's not possible. The available formats and samplerates are determined by what the I2S controller and the codec support (only formats/rates supported by both of them will be available).
Thank you for your answer.
I have Three more questions:
1/ Does anyone know of a ready to use I2S driver that would work in slave mode up to 354 KHz ?
2/ Is there any advantage to use Frame Master and Clock Slave or is it better Frams SLAVE AND Clock SLAVE ?
3/ I use Squeezelite as the I2S audio player,
I'm using Squeezelite v1.9.7-1256 along with LMS 8.0 latest build on Dietpi OS.
I'm doing Upsampling with the Sox Command inside Squeezelite
My command is:
squeezelite -a 24:4:16:0 -r 176400 -R -u vLs::0.5:28:: -p 95 -C 5 -s 127.0.0.1
I use a slaved Pi to an external bitclock at 176400 KHz in Frame Master mode (the pi is doing the WS integer clock division)
I can play my 192K - 44K1Hz wav and flac files => OK :D
I can play Deezer/Qobuz/BandCamp/SoundCloud 320K or 128K CBR, MP3 along with some web radios that are also 320K CBR, MP3 Radio like Linn or Naim => OK :D
But I can't play most of the Web radios like FIP or similar (128K CBR, Radio). They are not upsampled !
I also did a fresh install with two settings:
a) One with Pi n Master mode with i-sabre-q2m driver and Pi clok running at 176400 Khz
b) One with Pi in Slave Mode with generic driver and my hardware clock running at 176400 Khz
With Pi Master every stream are upsampled => OK
With Pi Slave, most Web Radios are not upsampled, other streams are correctly upsampled :x
EVERYTHING ELSE IS IDENTICAL.
The question is WHY ? :?:
phofman
Fri Jun 12, 2020 8:31 pm
My command is:
My 2 cents - since you have not specified the X parameter to resampling (non-integer resampling, in squeezelite IMO incorrectly called asynchronous), squeezelite cannot find any integer-based samplerate to 48kHz. The parameter -r being a single number specifies maximum samplerate, and the soundcard is queried about all available samplerates up to -r value https://github.com/ralph-irving/squeeze ... lsa.c#L272 It is possible each driver specifies different range of samplerates.
IMO adding the X parameter will fix the problem.
bricolodu13
Sat Jun 13, 2020 8:00 am
Thank you phofman, this is it ! 8-)
Still, now, I would like to be able to resync in slave mode at the Max Frequency supported by my DAC , that is 352800KHz
Does any one know a ready to use driver ?
alexxDIY
Wed Jun 17, 2020 9:35 am
Thanks for the information in this thread
I just would like to share my project - raspberry pi 24bit/384k I2S card
Here's my page regarding this project:
alexxdiy.blogspot.com
i hope it will be interesting....
phofman
Wed Jun 17, 2020 2:10 pm
Thank you for sharing your very interesting project, including all the source code and programming procedures. That is quite unusual for projects like this.
Sumesh
Thu Jul 16, 2020 10:17 am
Nice Idea and a great project. Would like hear more from you..
How do i contact you?
Regards,
Sumesh
mhelin
Sat Jul 18, 2020 12:57 pm
No I2S input?
ganzgustav22
Mon Jul 27, 2020 3:11 pm
I'm experiencing a strange problem with Pi4B, Hifiberry MiniAmp and Adafruit I2S SPH0645LM4H Mic:
After a while (maybe 5-15 minutes), the sound gets choppy and crackling.
- It only happens when the Mic is connected.
- What's even more weird is, it doesn't get better after a reboot or a power-off.
- When I power it off and leave it a while (maybe half an hour), then power it back on, the sound is good again.
I have tested this with two different Pi4s, Miniamps, Mic, sdcards, cables.
Anybody have an idea why this might be and how to further debug it?
ganzgustav22
Thu Jul 30, 2020 12:58 pm
Did more testing. Changed Rasbian back to 2020-01-13, same issue. Upgraded Firmware and Kernel to the latest versions via rpi-update. Same issue.
Then tried a Pi3B+ instead of the Pi4. At first I thought no issue. But, it turned out that after a while, it also shows the issue. There is some cracking/noise, but not as bad as on the Pi4.
Cory Parsnipson
Sat Aug 01, 2020 9:46 pm
Is it possible to run I2S pins through an I2C expander?
For context, I'm thinking about buying a Pimoroni Hyperpixel, but this thing has a shield that covers (and uses) all 40 GPIO pins. I want to keep my sound circuitry though so I need some way to get more GPIO pins.
The Hyper pixel supposedly has a I2C interface sticking out the other side that I can use for input. I think I can hook that up to a GPIO expander or two for buttons and sound. If it's relevant, I have an adafruit I2S stereo decoder feeding into two LM386 amps + speakers.
Is it possible to change the I2S pins to be on the other side of an I2C gpio expander? I'm not sure if the BCK, LRCK, or DOUT pins are somehow special (like PWM or something) where you can't just map them to any GPIO pins.
I feel like this is kind of a stupid question, but I'm not familiar enough with RPi GPIO or I2S/I2C enough to understand what I'm reading on google..
trejan
Sat Aug 01, 2020 10:45 pm
No. I2S has a similar looking name but it is completely different to I2C and you can't feed I2S data over I2C. You can't reassign the pins either as there is only 1 available mapping that fits on the GPIO header. The Hyperpixel display uses all the GPIOs on the header anyway including the additional I2C interface which it uses for the touchscreen controller.
Cory Parsnipson
Sat Aug 01, 2020 11:22 pm
Ok thanks for the answer! Gotta keep looking for a screen, I guess.. :(
Canto
Sat Aug 08, 2020 2:02 pm
I've used both.
I2S is easy to get running but complicated in the chip. The chips themselves usually have DSP engines and so can do things like equalization, filtration and a host of other things just by setting registers. The good news is that you get to control everything, the bad new is that you get to control everything. I love them.
DAC output is easy to get running but you'll need an outboard amplifier anyway. The nice thing about it is that you can put the output on a scope and see what you got. I2S chips (at least the ones I'm familiar with) do this with PWM so there is no relationship between the digital waveform and the analog one that you can just drop on a scope and look at to see what screwy thing is going on in your audio stream.
Debugging I2S means peering over analyzer traces of the bitstream. Debugging DAC means peering over scope traces.this content.
There is also the FCC to consider. So far I haven't been through FCC on the couple of products that I've done with I2S. In the distant past, the PWM output has been an issue. These new crops of I2S amps claim to have PWM designed to skate into FCC...
For your application, the biggest problem is the amplifier. Your choice probably comes down to which amp is capable of pushing enough power. What's the input of that? use it.
alanxyzhou
Tue Aug 11, 2020 9:07 pm
Has anyone figured out how to enable PDM audio recording on the Pi 4B?
LeoWolf
Fri Aug 28, 2020 8:17 am
Hi All,
I want to connect a mini DSP usb streamer to the to a raspberry pi 3 to transfer and receive audio between the pi and another device that has the USB streamer connected to the USB streamer. as a reference I used the PiBell overlay found in https://github.com/raspberrypi/linux/tr ... s/overlays and modified a little bit
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2708";
    fragment@0 {
        target-path = "/";
        __overlay__ {
            codec_out: spdif-transmitter {
                #address-cells = <0>;
                #size-cells = <0>;
                #sound-dai-cells = <0>;
                compatible = "linux,spdif-dit";
                status = "okay";
            codec_in: card-codec {
                compatible = "invensense,ics43432";
                status = "okay";
    fragment@1 {
        target = <&i2s>;
        __overlay__ {
            status = "okay";
    fragment@2 {
        target = <&sound>;
        snd: __overlay__ {
            compatible = "simple-audio-card";
            simple-audio-card,name = "PiBell";
            status="okay";
            capture_link: simple-audio-card,dai-link@0 {
                format = "i2s";
                r_cpu_dai: cpu {
                    sound-dai = <&i2s>;
                    bitclock-master = <&p_codec_dai>;
                    frame-master = <&p_codec_dai>;
                    dai-tdm-slot-num = <2>;
                    dai-tdm-slot-width = <32>;
                r_codec_dai: codec {
                    sound-dai = <&codec_in>;
            playback_link: simple-audio-card,dai-link@1 {
                format = "i2s";
                p_cpu_dai: cpu {
                    sound-dai = <&i2s>;
                p_codec_dai: codec {
                    sound-dai = <&codec_out>;
    __overrides__ {
        alsaname = <&snd>, "simple-audio-card,name";
I added the lines
to the capture and playback link because the usbstreamer needs to be the Clock master and compile it with
 dtc -@ -H epapr -O dtb -o genericsoundcard.dtbo genericsoundcard.dts
I didn't saw the PiBel card when I use aplay -l or arecord -l but if I remove the capture link portion of the code and compile I can see the card there but only for aplay -l and it seems to be working fine (I have a small issue with the bitrate) is using the Bclk and LRClock of the picopi.
Any help would be appreciated :D .
Ben123
Wed Sep 02, 2020 12:26 pm
Hello all.
Over the last month I have been working on connecting a TI ADC (tlv320adc6140) with a RPI CM3+ with mixed success. I have enabled the necessary I2C and I2S pins in the Device Tree and created a simple DT overlay. The ADC is rather new and the codec driver was only very recently released in the latest kernel update (5.8) and boasts a lot of features. The codec drivers Probe functions are called correctly and when recording with Audacity or arecord, the DAPM works and powers the appropriate parts of the ADC as expected. The driver supports the ADC as both slave or master, however both modes fail to record anything but noise.
Pins are connected as follows:
RPI - ADC
GPIO 28 (PCM_CLK) - BCLK
GPIO 29 (PCM_FS) - FS
GPIO 30 (PCM_DIN) - DOUT
GPIO 31 (PCM_DOUT) - DIN
The ADC has the option of accepting an external MCLK, however it should not be required.
When tested with an oscilloscope, with RPI as the master, a sensible BCLK and FS are generated (3MHz and 48kHz respectively), however the ADC fails to recognize the correct BCLK/FS ratio (it supports automatic clock configuration) and DOUT looks very strange.
With the ADC as master, BCLK is 2,3MHz and FS is 9kHz, however the DOUT looks better.
Here my DT overlay for running the RPI as a slave:
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2835";
    fragment@0 {
        target = <&sound>;
        __overlay__ {
            i2s-controller = <&i2s>;
            status = "okay";
            simple-audio-card,format = "i2s";
            simple-audio-card,name = "soundcard";
            simple-audio-card,bitclock-master = <&sound_master>;
            simple-audio-card,frame-master = <&sound_master>;
            simple-audio-card,cpu {
                sound-dai = <&i2s>;
            sound_master: simple-audio-card,codec {
                sound-dai = <&codec>;
    fragment@1 {
        target = <&i2s>;
        __overlay__ {
            status = "okay";
    fragment@2 {
        target = <&i2c0>;
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            status = "okay";
            codec: codec@4c {
                compatible = "ti,tlv320adc6140";
                reg = <0x4c>;
                ti,gpi-config = <1 0 0 0>;
                ti,mic-bias-source = <6>;
Here the register states (in hex) of the ADC during recording (audacity, 44.1kHz):
                         REGISTER   (DEFAULT)    CURRENT
[17607.181413] PAGE_CFG (Def: 0)- Val: 0
[17607.181867] SW_RESET (Def: 0)- Val: 0
[17607.186238] SLEEP_CFG (Def: 0)- Val: 81 CHANGED!
[17607.191802] SHDN_CFG (Def: 5)- Val: 5
[17607.197158] ASI_CFG0 (Def: 30)- Val: 70 CHANGED!
[17607.201655] ASI_CFG1 (Def: 0)- Val: 0
[17607.207089] ASI_CFG2 (Def: 0)- Val: 0
[17607.211551] ASI_CH1 (Def: 0)- Val: 0
[17607.215997] ASI_CH2 (Def: 1)- Val: 1
[17607.220393] ASI_CH3 (Def: 2)- Val: 2
[17607.224770] ASI_CH4 (Def: 3)- Val: 3
[17607.229060] ASI_CH5 (Def: 4)- Val: 4
[17607.233507] ASI_CH6 (Def: 5)- Val: 5
[17607.237848] ASI_CH7 (Def: 6)- Val: 6
[17607.242169] ASI_CH8 (Def: 7)- Val: 7
[17607.246525] MST_CFG0 (Def: 2)- Val: 82 CHANGED!
[17607.251017] MST_CFG1 (Def: 48)- Val: 48
[17607.256806] ASI_STS (Def: ff)- Val: F8 CHANGED!
[17607.261455] CLK_SRC (Def: 10)- Val: 10
[17607.266818] PDMCLK_CFG (Def: 40)- Val: 40
[17607.271357] PDMIN_CFG (Def: 0)- Val: 0
[17607.276203] GPIO_CFG0 (Def: 22)- Val: 22
[17607.280803] GPO_CFG0 (Def: 0)- Val: 0
[17607.285535] GPO_CFG1 (Def: 0)- Val: 0
[17607.289972] GPO_CFG2 (Def: 0)- Val: 0
[17607.294443] GPO_CFG3 (Def: 0)- Val: 0
[17607.298821] GPO_VAL (Def: 0)- Val: 0
[17607.303255] GPIO_MON (Def: 0)- Val: 0
[17607.307648] GPI_CFG0 (Def: 0)- Val: 10 CHANGED!
[17607.312093] GPI_CFG1 (Def: 0)- Val: 0
[17607.317532] GPI_MON (Def: 0)- Val: 0
[17607.322108] INT_CFG (Def: 0)- Val: 0
[17607.326451] INT_MASK0 (Def: ff)- Val: FF
[17607.330818] INT_LTCH0 (Def: 0)- Val: 0
[17607.335555] BIAS_CFG (Def: 0)- Val: 60 CHANGED!
[17607.340093] CH1_CFG0 (Def: 0)- Val: 0
[17607.345464] CH1_CFG1 (Def: 0)- Val: A0 CHANGED!
[17607.349889] CH1_CFG2 (Def: c9)- Val: C9
[17607.355208] CH1_CFG3 (Def: 80)- Val: 80
[17607.359752] CH1_CFG4 (Def: 0)- Val: 0
[17607.364431] CH2_CFG0 (Def: 0)- Val: 0
[17607.368794] CH2_CFG1 (Def: 0)- Val: 0
[17607.373193] CH2_CFG2 (Def: c9)- Val: C9
[17607.377715] CH2_CFG3 (Def: 80)- Val: 80
[17607.382359] CH2_CFG4 (Def: 0)- Val: 0
[17607.386971] CH3_CFG0 (Def: 0)- Val: 0
[17607.391495] CH3_CFG1 (Def: 0)- Val: 8 CHANGED!
[17607.395958] CH3_CFG2 (Def: c9)- Val: C9
[17607.401199] CH3_CFG3 (Def: 80)- Val: 80
[17607.405816] CH3_CFG4 (Def: 0)- Val: 0
[17607.410447] CH4_CFG0 (Def: 0)- Val: 0
[17607.414933] CH4_CFG1 (Def: 0)- Val: 0
[17607.419674] CH4_CFG2 (Def: c9)- Val: C9
[17607.424145] CH4_CFG3 (Def: 80)- Val: 80
[17607.428764] CH4_CFG4 (Def: 0)- Val: 0
[17607.433362] CH5_CFG2 (Def: c9)- Val: C9
[17607.437814] CH5_CFG3 (Def: 80)- Val: 80
[17607.442584] CH5_CFG4 (Def: 0)- Val: 0
[17607.447205] CH6_CFG2 (Def: c9)- Val: C9
[17607.452115] CH6_CFG3 (Def: 80)- Val: 80
[17607.456669] CH6_CFG4 (Def: 0)- Val: 0
[17607.461305] CH7_CFG2 (Def: c9)- Val: C9
[17607.465799] CH7_CFG3 (Def: 80)- Val: 80
[17607.470808] CH7_CFG4 (Def: 0)- Val: 0
[17607.475363] CH8_CFG2 (Def: c9)- Val: C9
[17607.479726] CH8_CFG3 (Def: 80)- Val: 80
[17607.484383] CH8_CFG4 (Def: 0)- Val: 0
[17607.488981] DSP_CFG0 (Def: 1)- Val: 1
[17607.493447] DSP_CFG1 (Def: 40)- Val: 40
[17607.497866] DRE_CFG0 (Def: 7b)- Val: 7B
[17607.502443] AGC_CFG0 (Def: e7)- Val: EC CHANGED!
[17607.507104] IN_CH_EN (Def: f0)- Val: F0
[17607.512563] ASI_OUT_CH_EN (Def: 0)- Val: 80 CHANGED!
[17607.517185] PWR_CFG (Def: 0)- Val: E0 CHANGED!
[17607.523650] DEV_STS0 (Def: 0)- Val: 0
If anyone has any ideas on what I might be doing wrong, any help is greatly appreciated,
Ben
WooliesVesper
Wed Nov 04, 2020 12:45 pm
Following on from some pointers from other users in this thread, I have been able to enable PDM mode recording on the RPi Zero W (which has BCM2835 SoC) and successfully recorded audio from 2 different PDM microphones. Note that this may not be the only way/best way to get PDM recording working, however it worked for me. If anyone has had experience in this feel free to point out an improved method :D
Here were the specific steps I followed:
- $ cd /linux/sound/soc/bcm (Change directory to the location which contains Linux's I2S sound source file)
- $ sudo nano bcm2835-i2s.c (Open up the I2S sound source file for editing in root mode)
- Go to line ~393/394 and write bclk_rate = 3072000 (This fixes the PCM clock rate at 3.072 MHz which is what we need for PDM microphones)
- Go to line ~590 and write "mode |= BCM2835_I2S_PDMN;" on one line, and "mode |= BCM2835_I2S_PDME" on the next line, before the
"regmap_write(dev->i2s_regmap, BCM2835_I2S_MODE_A_REG, mode) line, be sure to save this! (This ensures PDM mode is enabled and a
decimation factor of N = 32 is
selected during the I2S mode setup).
- $ make -C /lib/modules/($ uname -r )/build M=($ pwd) modules (Now that we have changed the source file, we need to use the 'make'
command to run the Makefile which will compile the changes and generate a .ko kernel object file which is what we want - this file is called
"snd-soc-bcm2835-i2s.ko")
- $ cd /lib/modules/(uname -r)/kernel/sound/soc/bcm (This puts us in the directory of the kernel which contains the existing "snd-soc-bcm2835-
i2s.ko" which needs to be replaced)
- $ sudo rm -r snd-soc-bcm2835-i2s.ko (This removes the existing kernel object so we can replace it with out newly generated .ko file)
- In the /linux/sound/soc/bcm directory, execute the command: sudo cp snd-soc-bcm2835-i2s.ko /lib/modules/([dollar sign] uname -
r)/kernel/sound/soc/bcm (This will copy over the newly generated .ko file with PDM mode enabled to where we need it)
- Reboot the RPi using $ sudo reboot and use the following command to record audio: arecord -D plughw:1 -c1 -r 48000 -f S16_LE -d 60 -t wav -
V mono -v test.wav
nivanov
Thu Dec 03, 2020 8:07 pm
I'm having this exact issue, both with I2S Amp MAX98357 and I2S Mic, SPH0645. Anyone has any ideas what I should be looking at to try to debug this issue? Any advice would be greatly appreciated.
StonedEdge
Mon Jan 04, 2021 3:46 pm
Hi all,
I am currently very new to Raspberry Pi but would like to try and attempt to get the LM49450 codec working via Pi i2s signals in i2s master mode with external MCLK oscillator (12.288mHz) - this would mean configuring the CM4 to run in i2s slave mode so that the Pi can correctly spit out audio data in time with the pulses of the clocks arbitrarily generated by the amp. I am looking to ideally use a modified simple card overlay as posted by a few members previously but I am at a loss at what I need to modify to get it working.
https://github.com/raspberrypi/linux/bl ... e-card.txt
The LM49450 is the i2c slave with a generic PIC microcontroller currently the i2s master, setting all of the clocks and volume control via firmware. I would simply like to tap into the Pi CM4's i2s digital audio signals.
Current codec settings (LM49450):
Sample rate (Fs): 96kHz
Bit depth: 32 bit
Bit-clock: MCLK=12.288MHz/2 = 6.144mHz (64*96kHz)
Word-select operating mode: Normal (i.e audio data transmitted MSB first, with the unused bits following LSB)
Is something like this likely to net me any results with the current setup (i.e simply adding "dtoverlay=superaudioboard" to config.txt) or is there any other modification I would need to add? I've literally just copy and pasted this and modified some very basic stuff like bit clock speed and am most certain this is wrong - I think I may be missing some lines for the spdif transmitter codec (hence my post). Any sort of modifications/leading me in the right direction based on the below code would be sincerely appreciated. I am a big Pi noob (and Linux noob) but excited to start learning.
/dts-v1/;
/plugin/;
	compatible = "brcm, bcm2711"; //for Pi CM4 compatibility
	fragment@0 {
		target = <&sound>;
		__overlay__ {
			status = "okay";
			simple-audio-card,name = "SuperAudioBoard";
				sound-dai = <&i2s>;
				sound-dai = <&LM49450>;
				system-clock-frequency = <6144000>;
	fragment@1 {
		target = <&i2s>;
		__overlay__ {
			status = "okay";
Kind regards,
Benjamin
sarabsethi
Thu Jan 07, 2021 10:43 am
I'm currently trying to hook up a PDM microphone to the CM4 (BCM2711).
Has anyone got this working (CM4 or RPi4), or have useful advice on how I could tweak what WooliesVesper did below on the BCM2835 for my purposes?
V mono -v test.wav
