wolfgangmob
Re: SD card sticking out ? Use RSMMC
Tue Jul 17, 2012 10:49 pm
podly wrote:
wolfgangmob wrote:Another option is a combo adapter for micro SD to SD/USB then just cut off the USB side of the adapter.
What do you mean? Any links to this kind adapter?
cheers,
Kind of hard to see it but here's one on ebay that someone has cut the USB off of to make it flush with a macbook pro.
http://www.ebay.com/itm/Norcent-2GB-mic ... 0730174578
podly
Tue Jul 17, 2012 11:02 pm
I believe your word for it, but it probably will not work. It looks like it can work as microSD adapter to SD adapter OR to USB card reader. Cutting it out will left you with a pice of junk plastic. But I could be wrong...
Mortimer
Tue Jul 17, 2012 11:11 pm
wolfgangmob
Wed Jul 18, 2012 5:07 am
Nope, not at all, this one: http://forums.macrumors.com/showthread.php?t=1040837
The last post on the page he said he cut the USB half off and it was working.
wolfgangmob
Wed Jul 18, 2012 5:09 am
podly wrote:I believe your word for it, but it probably will not work. It looks like it can work as microSD adapter to SD adapter OR to USB card reader. Cutting it out will left you with a pice of junk plastic. But I could be wrong...
The idea is to just cut off the USB part and it should work, however there is always the possible problem of it not working in the R-Pi for some random reason releating to hardwar compatibility being limited.
podly
Wed Jul 18, 2012 7:28 am
you're right, I I had to look closely. It is easy to see on this one: http://www.dealextreme.com/p/worlds-sma ... erter-5091
wolfgangmob
Wed Jul 18, 2012 7:34 am
podly wrote:you're right, I I had to look closely. It is easy to see on this one: http://www.dealextreme.com/p/worlds-sma ... erter-5091
I'm considering ordering the Norcent one since I might need a 2GB standrd microSD (non HC) card for something else, not so much for the R-Pi but rather my MacBook Pro.
Montala
Wed Jul 18, 2012 8:11 am
wolfgangmob wrote:I'm considering ordering the Norcent one since I might need a 2GB standrd microSD (non HC) card for something else, not so much for the R-Pi but rather my MacBook Pro.
If you are a MacBook Pro (as well as a RasPi) owner, I am sure you will be interested in the item mentioned by 'bircoe' on the first page of this thread? (http://www.kickstarter.com/projects/134 ... -minidrive)
wolfgangmob
Wed Jul 18, 2012 8:47 am
I'm interested but it hasn't entered production yet and the prices are on the high side making me less interested when this solution is available at the present and has had some success. I may buy one later for my MacBook Pr and then move the home made option to the R-Pi, but otherwise I have no real need for a flush SD card other than allowing for a sleeker case design.
chris2401
Fri Jul 20, 2012 8:25 am
i think he means something like this.
the sticking out side is just a bit of plastic and the usbport.
jamestyrrell
Tue Aug 21, 2012 2:45 pm
There is also, http://www.adafruit.com/products/966, but have a read of the comments of the pIO creator here, http://www.kickstarter.com/projects/443 ... i/comments. As he outlines, there may be some compatibility problems with certain cases.
angrypotassium
Mon Dec 10, 2012 12:36 pm
Some guy on ebay is making microSD to RSMMC-sized adapters.
Search for: microSD short adapter
on ebay
MattRX
Wed Dec 12, 2012 1:27 am
I have bought two of these
http://www.ebay.com.au/itm/Practical-Mi ... 4160da225a
I just split the case open, trim the USB section off the board and then cut the case down. After that I fill the gap where the USB section was, sand it smooth and colour it in with a black marker.
Works a treat. To aid removal have a loop of sticky tape hanging out the back of the adaptor.
Hope this helps
Matt
MattRX
Wed Dec 12, 2012 3:30 am
I have made two Micro SD adapters from these
http://www.ebay.com.au/itm/Practical-Mi ... 0002902103
They are quick, easy and sit about flush with most cases. When trimmed the SD adapter is 19.5mm long
Here is how I do it.
Split the case apart and remove the PCB .
SD adapter case split open
Trim the PCB. I use good side cutters and cut just along the edge of the black blob.
PCB trimmed down to size
I just trimmed the case with scissors.
Trimmed PCB in trimmed case
MattRX
Wed Dec 12, 2012 3:37 am
Part 2.
The gap left behind from the departed USB connector has been filled with a mixture of superglue and talcum powder. Be very careful here as it is very easy to push the mixture in too far and the micro SD card will no longer fit.
Gap filled
The edge cleaned up with a file and coloured black with a permanent marker
Here it is inserted into a RS branded case. Note the difficult to see stick tape to aid extraction.
Hope this helps
Matt
docwebhead
Thu Dec 13, 2012 2:08 pm
I'm going to order one of these and see if they'll work.
http://dx.com/p/2-in-1-tf-card-to-sd-ca ... ite-126299
They're in stock, the others aren't.
(Disclaimer: I'm a DX fan!)
Will post results in a month or so.
BrandtD
Thu Jan 03, 2013 12:40 am
stevewardell
Mon Jan 28, 2013 6:34 pm
I was going to order one of these https://www.modmypi.com/sd-cards-and-ad ... rd-adaptor anyone tried one?
Steve
@stevewardell
stevewardell.wordpress.com
peterburk
Tue Jan 29, 2013 3:59 pm
Inspired by this topic, I decided to cut my SD card in half. I was a little worried beforehand, so made a tutorial to reassure future case modders that it's safe to do with my brand of card!
http://www.raspberrypi.org/phpBB3/viewt ... 40&t=31609
Peter
therimmer96
Thu Jan 31, 2013 5:06 pm
Dilligaf wrote:Someone needs to manufacture and sell a "MicroSD Pidaper", basically a half height micro sd adapter, then a micro sd would sit flush.
The modmypi site sells them, i think they are under £10
Dilligaf
Thu Jan 31, 2013 6:37 pm
Did you see the date on that post? This thread is probably what inspired them to make them.
Jim JKla
Sun Feb 03, 2013 12:20 pm
jspring
Sat Mar 09, 2013 6:02 am
I bought one of these minidrives for mine: http://amzn.to/Zph6Ya
They are pretty handy, and functionally equivalent to the expensive Nifty Minidrive. You can buy 'em without the endcap so that it'll be a no-frills addition to your board (though, I got one with the cap for my Mac, and it sits flush and looks perfect).
mypifi
Sun Mar 10, 2013 4:14 pm
im just suprised no one has made a lead that comes out and you can plug the sd card into the lead so itsnot sticking out?
