Hi all,
I'd like to make small portable computer around rpi zero and need display with at least 480x320 resolution (320x240 is too small), adequate price (connecting >50USD display to 5USD computer is rather strange). I don't need ready to go solution from hardware point of view - I'm quite experienced HW guy, though not that much experienced when it comes to Linux configuration.
At first I expected to use 4,3" screen for rear parking camera from aliexpress, it wa trivial to set-up, but this one is somehow sub-optimal, to say at least. The picture is blurry, especially on higher contrast edges. Text is difficult to read, though decreasing resolution down to 400x300 seems to help a bit. But 400x300 is too low resolution for use with desktop GUI. Some windows are just running away out from desktop, yet I have poor picture quality. Seems like AV connector is not the way to go. There are some possibilities I considered:
* In the "gameboy-zero" circles the favorite display is small 2,2" 320x240 one, which is great for old games emulators, but again, not that great for GUI, because of its resolution. But cost, ease of use (fbtft and lot of documentation around the web) is just perfect.
* Adafruit PiTFT https://www.adafruit.com/products/2097 are better, but the price tag is somehow high for me, plus it is packed with things I don't need, like touch screen interface. Not sure about its compatibility with zero.
* KeDei like displays viewtopic.php?t=124961 are just awful. Proprietary kernel, slow refresh rate, though the size and price seems just OK.
Do you have any other ideas?
Re: Raspberry pi zero, cheap HVGA TFT, which one?
hello
you can look at below models and see if it can meet your requirement
http://www.neosecsolutions.com//product ... 8&cPath=17
the below product is specially for pi zero as it do not have any header , but you need to do some wiring
http://www.neosecsolutions.com//product ... 5&cPath=28
regards
tinylcd
regards
tinylcd
What about 5.7in VGA for 20EUR? http://www.pollin.de/shop/dt/Nzk1ODc4OT ... 0x480.html
A timing is here:
viewtopic.php?p=1075560#p1075560
You will need some jumper wires to connect it to the GPIO.
A timing is here:
