gsh
Re: Anybody interested in talking direct! to IDE/SATA?
Mon Oct 01, 2018 10:53 am
Probably best to look at the sources in the linux kernel
https://github.com/raspberrypi/linux/bl ... 2835_smi.c
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
fanoush
Mon Oct 01, 2018 11:42 am
Thanks a lot but that's not the point.
The point is that there is this 15 page PDF I have here, which may be more readable and helpful to people not fluent in linux kernel C code, and it got lost somewhere. So what happened with the pull request Gert mentioned? Is there something wrong with the pdf? Can I upload it somewhere?
I also found it being referenced here https://ultibo.org/forum/viewtopic.php?t=538#p5967 but the link does not work of course since gert removed his documentation fork.
Mon Oct 01, 2018 11:54 am
Not sure, but I think that document has never been officially released by Broadcom. Which makes publishing it problematic for us.
fanoush
Mon Oct 01, 2018 12:22 pm
Oh, I see. I've re-read what Gert wrote previously here https://www.raspberrypi.org/forums/view ... 5#p1239245
and it looks like the status is indeed a bit unclear.
BEB
Thu Oct 10, 2019 1:51 pm
For those still interested in this project, I have started to work on a backplane bus concept for the Raspberry Pi (called RasPiBus or RPB in short). The RPB allows up to four expansion boards to be connected on the GPIO using a high bandwidth parallel bus (with an I/O addressing range of 256 bytes). For now, I use a parallel GPIO based communication system which provides 3MB/s bandwidth (yes, 3 megabytes per second not mega bits ;) ). Using SMI, I am able to go over 6MB/s (but SMI is still at prototyping stage, since its implementation is very hard because there is no documentation available except source code and Gert Van Loo's work)
I also use this concept to interface the RPi with a Terasic DE0 Nano FPGA board, acting as a coprocessor for the RPi.
My plans are to publish source code and protocol specifications as soon as I will have a stable release.
BEB
Mon Oct 28, 2019 8:50 pm
After some problems, I have been able to compile the original source code from Gert on my 3B+.
First of all, I have found an issue in the original code which prevents it to run on the 3B+
#define BCM2708_PERI_BASE        0x20000000
must be replaced by
#define BCM2708_PERI_BASE         0x3F000000
to work on the 3B+
Following code
.    for (TestCount=0; TestCount<10000000; TestCount++)
        if (smi_direct_write(0, TestCount, 0)==0)
            fprintf (stderr, "smi_direct_write timed out...\n");
shows a transfer rate of 1.5MB/s (for an 8 bits bus, so double if setup_smi() uses SMI_RW_WID16)
smi_write_block() and smi_read_block() functions provide better data rate, as bytes are transferred in bursts with exact timing programmed in setup_smi(). With 168ns for nWE pulse width, 168ns for nWE HOLD and 72ns for nWE SETUP, this gives a data rate of 2.4MB/s during bursts (I see an idle period of around 1 us between each call, coming from the preparation code in the function.
I have checked that nWE and nCS are exactly the same as programmed in the timing register, so I think it can be safely expected that higher data rates can be achieved with narrower pulses (168ns is quite a large value for modern components. Smaller values can be used safely with 3.3V FPGA)
mikronauts
Mon Oct 28, 2019 10:10 pm
if you can make a pointer for the smi window base address, it should be much faster than using a kernel function for each access
must be replaced by
to work on the 3B+
Following code
