First, download the ISP tool STM32Loader from https://github.com/coocox/stm32loader. This tool, original version by Ivan A-R , is written in Python script which will talk to the STM32 bootloader to upload and download firmware. It’s recommended of you to use Python 2.6 or 2.7, and the installation details won’t be described here.
Usage of STM32Loader:
./stm32loader.py [-hqVewvr] [-l length] [-p port] [-b baud] [-a addr] [file.bin]
-h This help
-q Quiet
-V Verbose
-e Erase
-w Write
-v Verify
-r Read
-l length Length of read
-p port Serial port (default: /dev/tty.usbserial-ftCYPMYJ)
-b baud Baud speed (default: 115200)
-a addr Target address
The Raspberry Pi can program the STM32 via the serial port (JP7-TX1 and JP7-RX1) when the Embedded Pi is in ISP mode, refer to section 3.6.1 in Embedded Pi User Manual.
To use this mode, you need to follow the steps below:
1、Set BOOT0 to 1 (high level), and BOOT1 to 0 (low level) – which has been done on hardware. In this case, you only need to press the BOOT0 button to enter this mode when Embedded Pi is powered on.
2、Connect the UART interface on Raspberry Pi to the UART1 interface on Embedded Pi with wires (connect Embedded Pi JP7-TX1 with Raspberry Pi P1-D10, JP7-RX1 with P1-D8), as shown in the figure below.
3、Open a Terminal session, 'cd' to wherever you downloaded the STM32Loader and then issue the following command to download bin file to the Embedded Pi
sudo python stm32loader.py -e -w -v Test.bin
Install PySerial
Whatever your operating system is, download the .tar.gz installation package for PySerial 2.6, i.e. pyserial-2.6.tar.gz, from https://pypi.python.org/pypi/pyserial.
If you are using Windows system, you need to decompress the file into a folder. It is not a normal zip file, so you may need to use a tool such as 7-zip (http://www.7-zip.org/).
If you are using a Mac or Linux computer, then open a Terminal session, 'cd' to wherever you downloaded the pyserial-2.6.tar.gz and then issue the following command to unpack the installation folder
$ tar -xzf pyserial-2.6.tar.gz
sudo python setup.py install
When the installation is finished, issue the following command to download bin file to the Embedded Pi
A prompt of “Verification OK” will appear after successful programming, as shown in the figure below:
Reset the STM32 and the LED on the Embedded Pi will blink.
If the program is not downloaded successfully, react according to the prompt appears in the Command Prompt / Terminal session:
If a prompt of “None” always appears, redo step 1 (press BOOT0 to reset the STM32).
If an error prompt like “NACK” appears, retry the download command.
Hope you all enjoy playing with the Embedded Pi. Please feel free to post a question or share your story with the Embedded Pi on our Embedded Pi Forum. Come join us to make the Pi better!
