mba
Re: LIRC GPIO driver for homebrew adapter
Mon Aug 13, 2012 3:28 pm
No problem, glad that I could help.
I can't seem to edit my previous post and correct the missing sudo, but ok if thats the only problem I guess you'll figure it out.
But anyway this is not the most elegant solution, maybe a debian package or if the patch from aron could get accepted into the main tree, it would be a bit more user-friendly.
@Aron are you still looking at updating the driver getting it accepted?
AMOTE - a LIRC client for Android. Build your own Android-based universal remote.
klims
Mon Aug 13, 2012 10:38 pm
@MBA - are you able to send commands with irsend using the instructions you posted?
I'm having some trouble with this. I get the error:
Irsend: could not connect to socket
Irsend: no such file or directory
Cheers
klims
Tue Aug 14, 2012 11:14 am
It seems like my problem was lircd not being started.
The directory /var/run/lirc is never created as expected in the /etc/init.d/lirc file and so lircd cannot start.
I'm not sure if the lirc script is not running or the mkdir command is not working.
If I run the mkdir command manually and start lircd I can use the irsend command.
Any ideas?
mba
Tue Aug 14, 2012 7:01 pm
hmm, the mkdir in the init script was actually just a quick work-around because the /var/run gets emptied on each reboot. Are there symbolic links to /etc/init.d/lirc in the right rcX.d folders? If so the lircd should be started on reboot, then its a matter of the folder not being created for some reason.
Try removing the mkdir lines in the script and replace them with
sudo mkdir -p /var/run/lirc
klims
Wed Aug 15, 2012 11:56 am
I don't think I have the symbolic links right :-(
When I try to run the command "update-rc.d lirc defaults 20" as suggested in the lirc file I get the error:
insserv: script lirc is not an executable regular file, skipped!
Can anyone tell me what rcX.d folder/file should have a symbolic link in?
mba
Wed Aug 15, 2012 12:41 pm
maybe it has lost its executable flag somehow? Try running
sudo chmod +x /etc/init.d/lirc
and then call
sudo update-rc.d lirc defaults
update-rc.d should place a symbolic link in the default rcX.d folders, so you don't have to do it manually.
Note: its actually wrong in my installation steps when I say to call insserv, I have learned afterwards that you should not call this directly, instead (as you have found in the lirc script) you should call update-rc.d.
klims
Thu Aug 16, 2012 11:15 am
Spot on mba!
chmod +x allowed me to run update-rc.d and got lircd running on startup.
While lirc seems to be running OK, I see a message on startup complaining about the fact that kernel expects /dev/lirc0 while is configured is /dev/lirc/0
Thanks again for the help mba
mba
Thu Aug 16, 2012 1:55 pm
Thats odd, does it complain about not finding /dev/lirc0 when you start lircd?
the contrib/lirc.rules should create the /dev/lirc/0 and when lird is started from /etc/init.d/lirc it should use /dev/lirc/0
does your /etc/init.d/lirc script contain --device=/dev/lirc/0 both in and start and restart cases?
Dilligaf
Tue Aug 21, 2012 4:16 am
Don't know it aaron is still monitoring this thread but only one small thing that stops this from being perfect. I really miss the flashing led feedback I get from my normal IR receiver, is there a possibility to code in an optional LED feedback pin? A gpio pin that momentarily grounds when the IR receiver receives a signal could be wired to an LED providing visual feedback when a signal is received. If not, I'm sure I'll survive :) Thank you for this awesome piece of code.
Mike
cleverca22
Tue Aug 21, 2012 4:15 pm
simplest answer, wire an led directly on the same pin as the reciever module
if that doesnt work, it can easily be patched to eat another pin
mba
Tue Aug 21, 2012 7:41 pm
I hate to be cross-posting but maybe this could interest some of you reading on this LIRC gpio driver thread.
My personal goal with having a LIRC server and IR blaster connected to the Raspberry Pi was to develop an universal remote for my Android phone. This way I can control my amplifier, tv and other IR based hifi components in my livingroom. See my project details here http://www.raspberrypi.org/phpBB3/viewt ... 35&t=15258
mba
Wed Aug 22, 2012 7:08 pm
Is it just me or is the IRs left 'on' all the time. I think the fix with GPIO_CLEAR_PIN is actually setting the pin high all the time after a transmission. If I replace it with GPIO_SET_PIN the IRs are turned off independent of the last bit of the transmitted code.
Maybe the ouput has pull-up enabled? Or it is inverted?
klims
Wed Aug 22, 2012 9:48 pm
mba wrote:Is it just me or is the IRs left 'on' all the time. I think the fix with GPIO_CLEAR_PIN is actually setting the pin high all the time after a transmission.
Nope not just you. I see the same behaviour, although I figured it was probably just because I hand't implemented your fix correctly.
TarjeiB
Thu Aug 23, 2012 1:13 pm
Is this code in the 3.2 kernel now or do I have to patch it?
mba
Fri Aug 24, 2012 8:07 pm
hmm, I will take a look at things with a oscilloscope when I get some time, the curcuit I built shouldn't invert the signal, and as far as I can measure with a multimeter the gpio pin 0 I am using is somewhat high when the driver has finished transmitting. Also when insmodding the driver at first the leds are driven high, which is not good as I am heavily overdriving the leds.
psypi
Thu Sep 06, 2012 10:26 pm
I've just run an update on wheezy and I now think I'm on 3.2.27.
This seems to have broken lirc
I have followed the 33 step guide in this post to rebuild lirc but have got into trouble.
step 30 did not work; it could not find lirc_dev.ko to copy, the file location now is..
/lib/modules/3.2.27+/kernel/drivers/media/rc/lirc_dev.ko - so I have chaged the command accordingly
There is also a 3.2.27-cutdown+ folder in /lib/modules/ so I have copied it to a similar location within this branch, and completed the remaining steps.
I still can't get lirc working again, is the method above valid or will it need a slightly different patch.
dmesg - reports - lirc_dev: disagrees about version of symbol module_layout
PS - I didn't uninstall lirc before attempting to rebuild it, but I did delete the ~/lirc build directory
psypi
Thu Sep 06, 2012 10:42 pm
Ah, just spotted in step 4 I should have got the 3.2.27 version of the tar.gz
I'll give that a go
feeling a bit twp.
bobguk
Fri Sep 07, 2012 6:46 pm
great set of instructions. I am having trouble in getting the transmit side to work.
pi@raspberrypi ~ $ sudo irsend SEND_ONCE TECHNISAT_ST3004S ARROW_LEFT
returns :-
irsend: command failed: SEND_ONCE TECHNISAT_ST3004S ARROW_LEFT
irsend: hardware does not support sending
I have tried compiling with the --with-transmitter switch but have no idea what to try next. All ideas welcome
Chinasaur
Mon Sep 24, 2012 9:09 pm
Hey guys, I know you've done some nice work getting a GPIO version together, but since I'm not using my USB ports I wonder if anyone has tried something like: http://www.huitsing.nl/irftdi/
Will still probably need some LIRC patching, so seems worth keeping the threads together? Thanks!
the.hcd
Thu Sep 27, 2012 9:30 pm
Hi all,
I've followed the instructions on the latest raspbian
root@raspberrypi:/lib/modules/3.2.27+/misc# uname -a
Linux raspberrypi 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l GNU/Linux
and have ended up getting something built,
however, I get
Sep 27 23:16:54 raspberrypi kernel: [ 5516.526943] lirc_rpi: disagrees about version of symbol module_layout
when I try to insmod.
I guess there is something wrong in the early stage:
I've tried changing the refernce to the 3.1.9 to 3.2.27
sudo wget -O raspberrypi-linux-3.2.27.tar.gz https://github.com/raspberrypi/linux/tarball/rpi-patches
sudo tar xzf raspberrypi-linux-3.2.27.tar.gz
sudo ln -s /usr/src/raspberrypi-linux-775d4ce /lib/modules/`uname -r`/build
cd /usr/src/raspberrypi-linux-775d4ce
I'm not sure what version /usr/src/raspberrypi-linux-775d4ce is....
but the makefile seems to think its 3.1.9
ie:
https://github.com/raspberrypi/linux/bl ... s/Makefile
VERSION = 3
PATCHLEVEL = 1
SUBLEVEL = 9
EXTRAVERSION = +
NAME = "Divemaster Edition"
Has anyone confirmed this? Or am I doing something stupid :)
selectnone
Mon Oct 01, 2012 10:56 pm
I'm a bit puzzled myself - I'm trying to get Lirc working on the latest Raspbian but haven't had any luck building it - with aron or mba's instructions...
Does anyone know if any of this stuff is going to be included in Raspbian or Lirc by default? That'd make this all a whole lot easier!
bitbitbit
Wed Oct 03, 2012 5:51 am
Hi there....
I'm getting error messages when running ./autogen.sh
./autogen.sh: 4: ./autogen.sh: autoreconf: not found
./autogen.sh: 7: ./autogen.sh: automake: not found
cat: configure: No such file or directory
Creating setup-driver.sh ...
rpi: There is no param type, but default parameter is none, should be OK
How should I fix it??
By the way, I have a remote control, how do I know what frequency it gives out and how can I configure Pi to "read" each remote button?..
Thanks!!
the.hcd
Wed Oct 03, 2012 8:53 am
Hi bitbitbit, you need to apt-get the dependencies before you can build. (check the 33 steps instructions)
sudo apt-get install libtool
sudo apt-get install autoconf
sudo apt-get install git
after compiling, you install and configure with irrecord.
Although you probably don't need to compile the lirc_gpio module as you are not using a IR receiver via GPIO input. In the latest release the lirc module should work. jsut configure it as described in http://www.lirc.org/
naicheben
Wed Oct 03, 2012 6:47 pm
I have problems getting lirc_rpi to work on raspian.
In Raspian (kernel 3.2.27) the drivers for lirc are located in drivers/staging/media/lirc
The patch looks for the files in drivers/staging/lirc
I changed the patch to match the new location. But was it really nessesary? :?:
To activate the module in the Kernel I run make menuconfig and opened:
Device Drivers -> Staging Drivers -> Media staging drivers -> Linux Infrared Remote Control IR ...->
and marked Homebrew GPIO as a module (m)
Now I did make modules and this will take some time ....
selectnone
Wed Oct 03, 2012 10:26 pm
naicheben wrote:I have problems getting lirc_rpi to work on raspian.
Ahah, that sounds promising! I'll see if I can get that going myself
