vodor48
Re: Debian ARM on Raspberry Pi
Fri Mar 23, 2012 6:34 pm
Thx rurwin!
It's Work!:)
Joe Schmoe
Fri Mar 23, 2012 7:22 pm
Note, incidentally, that the "you're a windows person, we'll give you a Linux virtualbox to run on your windows system, then you run QEMU under Linux (as God intended it to be run) to run the Pi simulation" really isn't necessary anymore.
If I can get it to run  effectively directly under Windows (using QEMU for Windows), then anyone can.  It wasn't really that hard.  I was a little daunted at first, but really it's no harder running QEMU under Windows than it is to run it under Linux.
rmm200
Tue Mar 27, 2012 3:01 am
The Debian package includes Geany, but not "make" or "xterm" which Geany uses. I suggest including those two packages also. Kind of cool seeing Geany open an xterm window and showing my Ruby execution. apt-get install works for both.
Chris.Rowland
Wed Mar 28, 2012 11:16 am
I'm having a problem with the root password both using the GUI and using the su command.
In both cases I get a password prompt but nothing I have tried works.  It gives the authentication failure message.  I thought the default root password was suse.
This is using the debian6-17-02-2012.img image, zImage_3.1.9 and qemu-windows-1.0.1 - on a Windows system.
sudo works and does not require a password.
Thanks for any help,
grumpyoldgit
Wed Mar 28, 2012 11:19 am
id = pi
password = suse
Has worked for me.
grumpyoldgit
Wed Mar 28, 2012 11:20 am
I don't think you need su.
grumpyoldgit
Wed Mar 28, 2012 11:44 am
Debian is like Ubuntu. You don't get direct access to root. The account is locked. Just sudo. I am sure someone can explain this better than me.
grumpyoldgit
Wed Mar 28, 2012 11:51 am
Actually, sudo su will get you there.
Chris.Rowland
Wed Mar 28, 2012 12:29 pm
Is this what stops applications run from the LXDE GUI from getting root access?
grumpyoldgit
Wed Mar 28, 2012 12:36 pm
Perhaps. I seem to recall having difficulties installing software on a couple of occasions.
jojopi
Wed Mar 28, 2012 1:21 pm
The sudo security model is superior because it does not depend on the secrecy of a shared password.  Also, it allows precise control of which users and groups can run what commands, and it has good logging.
But if you do want a root password, you can set one with "sudo passwd root".
In any case, it is really not recommended to log in to the GUI as superuser.  Log in as a regular user and escalate privileges only when required.
Chris.Rowland
Wed Mar 28, 2012 1:42 pm
I'm not trying to log onto the IDE as a superuser I enter the user name and password (pi/suse). This give me a prompt with a $ which I think means normal user.
I type startx and get the LXDE desktop.
Then, in the LXDE desktop I select  - Gparted
And I get a window headed "Enter the administrative password" (sic) There is a place to type a password.
What do I type there?
It looks like this:
<img src="image/png;base64,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
rurwin
Re: Debian ARM on Raspberry Pi
Wed Mar 28, 2012 2:03 pm
You type your password: suse
Chris.Rowland
Wed Mar 28, 2012 2:19 pm
And I get  the form back with a line:
"Incorrect password... try again".
After three tries I get a form - "Failed to run /usrsbin/gparted as user root."
grumpyoldgit
Wed Mar 28, 2012 2:52 pm
Interestingly I don't. What are you trying to do?
I suspect I have the same setup; Debian Squeeze in Quemu.
It's running on Lubuntu 11.10, whether that makes any difference, which I doubt.
Wed Mar 28, 2012 3:02 pm
Have you tried password : raspberry
Chris.Rowland
Wed Mar 28, 2012 3:14 pm
just tried it, exactly the same, incorrect password.
But I'm in!
I used the line that jojopi suggested, "sudo passwd root" and entered a password. That one works.
Total power is mine!
Thanks everyone.
rurwin
Wed Mar 28, 2012 7:54 pm
That's broken.
Gparted seems to want to escalate permissions itself and expects the root password. On a Debian system there is no such thing; the root password hash is "*" which is not the hash of anything -- nothing you can type will be a valid root password.
Gparted should have invoked some GUI form of sudo and so taken your user password. The workaround would have been to give the command "sudo gparted".
Your workaround -- to create a root password -- is also good, although it leaves your computer infinitesimally less secure and may lead to confusion when you are asked for a password.
jojopi
Wed Mar 28, 2012 9:20 pm
It is not GParted itself.  LXDE's menu system is using GKSu as a wrapper on graphical applications that need privilege.  GKSu supports using either su or sudo to gain privilege, but it is defaulting to su, which is the wrong choice for this image.
To fix it, run the following command and then restart LXDE:gconftool-2 -\-type bool -\-set /apps/gksu/sudo-mode true
Note that this is a per-user setting, and it is the setting for the unprivileged user that is effective, so the configuration change should not be sudo'd.
Now the menu system will start privileged applications without asking for a password, just as sudo does.  Unless you also remove "Defaults exempt_group = users" from sudoers, in which case both will ask for your password, not root's.
error404
Wed Mar 28, 2012 9:44 pm
You may run into similar issues with other packages, as Debian default is to set a root password and use su, not sudo.
vtraveller
Thu Mar 29, 2012 9:31 am
I don't know if anyone is interested, but I've just worked out how to get an rt2870 WiFi USB dongle working with debian.  Please excuse my nativity but until yesterday I'd never played with linux, rpi or debian.
As far as I can tell the distribution ends up with the wrong firmware (a 4k version of rt2870.bin rather than an 8k version).  If you replace the .bin file with a suitable good one, wifi leaps into life.
Here's a quick rune summary of what I did (sudo / su permitting):
# Install wireless
vi /etc/apt/sources.list
change "deb http://ftp.us.debian.org/debian squeeze main" to "deb http://ftp.us.debian.org/debian squeeze main contrib non-free"
aptitude update && aptitude install firmware-ralink wireless-tools
aptitude install wicd
cp /mnt/myusb/rt2870.bin /lib/firmware
reboot
# Connect to a WiFi network
startx
run wicd
# Connect at start-up
vi /etc/network/interfaces
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "mynetworkname"
wpa-psk "mysecretpassphrase"
Hope it helps - caused me a little bit of a headache.  Same headache appears in the Fedora remix except all that needs patching there is rt2870.bin and then a reboot.
Apologies if this isn't useful / involved egg sucking.
Thu Mar 29, 2012 9:52 am
Just for completeness, there are other firmwares for other wifi adapters...
For a 3Com I have
sudo apt-get install zd1211-firmware
For a Sumvision N dongle
sudo apt-get install firmware-realtek
Also, if you are using a WPA network on the command line, you may need to install wpasuplicant, and do some jiggery pokery including setting a psk key and creating a conf file. Then grab a DHCP lease using dhclient (I think).
vtraveller
Thu Mar 29, 2012 10:20 am
True about the wpasuplicant.  I think wicd does a chunk of the magic for you.  Certainly I had everything I needed after installing it.
Thu Mar 29, 2012 10:56 am
Yes, I think wicd does a lot of the hard lifting, otherwise there are quite a few command lines to type in, at least for setup.
Return to “Debian”
